Standard Airworthy Certificated Gliders in the US
Old July 17th 14, 04:21 AM posted to rec.aviation.soaring
GM
Default Standard Airworthy Certificated Gliders in the US
On Wednesday, July 16, 2014 6:38:56 AM UTC-4, Matt G. wrote:
GM;886150 Wrote:
Can anyone give me some pointers on how to research the FAA database to
find out if a glider has a standard airworthiness certificate or must be
registered in the experimental category?
Thanks,
Uli
If looking up a glider by N-number, you can simply look at the
registration to determine what category airworthiness cert it has. Under
the "Airworthiness" section, look for "classification". It will be
either "Standard" or "Experimental". This is the easiest way to tell for
a particular glider, since some models have ended up in both the
standard and experimental categories over the years.
Matt G.
Hi Matt,
thanks for your reply. My question was more general and aimed at particular models rather than a specific glider which is already registered in the US.
Uli
Old July 17th 14, 05:15 AM posted to rec.aviation.soaring
Darryl Ramm
Thanks,
Uli
Matt G.
Hi Matt,
Uli
So why don't you just ask the question for he specific glider you are interested in?
Old July 18th 14, 02:44 AM posted to rec.aviation.soaring
GM
Hi Matt,
Uli
Simple - I don't want to tip off my friends about what I intend to get ..... ;-)
Using XCOM and Flight Line radios in certificated gliders Paul Remde Soaring 11 August 21st 11 02:34 PM
Drones To Be Certificated For GA? hierophant[_2_] Piloting 36 April 22nd 11 10:14 PM
Considering Refinishing Club/Standard Class Gliders for part time job [email protected] Soaring 8 January 3rd 09 08:21 PM
How are avionics technicians certificated? Jim Stewart Piloting 7 March 18th 07 02:45 AM
Motor gliders in Standard and 15-meter class? wiktor256 Soaring 0 July 23rd 05 08:51 AM
