Standard Airworthy Certificated Gliders in the US
Old July 16th 14, 04:01 AM posted to rec.aviation.soaring
GM
Default Standard Airworthy Certificated Gliders in the US
Can anyone give me some pointers on how to research the FAA database to find out if a glider has a standard airworthiness certificate or must be registered in the experimental category?
Uli
Old July 16th 14, 04:19 AM posted to rec.aviation.soaring
Bill T
Most any aircraft or glider will have a "Type Certificate Data Sheet" on file with the Federal Aviation Administration. You can search for the TCDS by Make/Model on FAA.gov. The TCDS will have the registration category listed. Some may change by serial number.
A copy of the TCDS should be part of the aircraft records.
BillT
Old July 16th 14, 04:30 AM posted to rec.aviation.soaring
GM
BillT
Thanks Bill! I wasn't familiar with that terminology. Found the db for the TCDSs.
Uli
Old July 16th 14, 11:38 AM
Matt G. Matt G. is offline
Junior Member
First recorded activity by AviationBanter: Jul 2012
Quote:
Uli
If looking up a glider by N-number, you can simply look at the registration to determine what category airworthiness cert it has. Under the "Airworthiness" section, look for "classification". It will be either "Standard" or "Experimental". This is the easiest way to tell for a particular glider, since some models have ended up in both the standard and experimental categories over the years.
Old July 16th 14, 03:50 PM posted to rec.aviation.soaring
Bob Kuykendall
standard and experimental categories over the years...
Be cautious about what you learn by doing that; the FAA's records sometimes contain errors about certificate type. For example, I think that there is at least one Russia sailplane for which the certificate type is shown as "Standard" despite the absence of an actual type certificate.
Thanks, Bob K.
Old July 16th 14, 05:46 PM posted to rec.aviation.soaring
Frank Whiteley
Uli
Matt G.
Not always. I've found the information lacking on more than one record. Of note, one was the SZD-54 Perkoz in the winch accident a couple of years ago.
Frank Whiteley
Old July 17th 14, 04:21 AM posted to rec.aviation.soaring
GM
Uli
Matt G.
Hi Matt,
thanks for your reply. My question was more general and aimed at particular models rather than a specific glider which is already registered in the US.
Uli
Old July 17th 14, 05:15 AM posted to rec.aviation.soaring
Darryl Ramm
Uli
Matt G.
Hi Matt,
Uli
So why don't you just ask the question for he specific glider you are interested in?
Old July 18th 14, 02:44 AM posted to rec.aviation.soaring
GM
Hi Matt,
Uli
Simple - I don't want to tip off my friends about what I intend to get ..... ;-)
Old July 16th 14, 06:10 AM posted to rec.aviation.soaring
Doug Mueller
database to
be
Uli
Uli,
go to http://www.faa.gov
in the search bar type in (TCDS)
From there click on the link on the left side current model/By Make
Click on the letter at the top of the manufacturer name. It will give
alphabetical order.
If it is not listed then it could be under a different type certificate.
Check back here if you have a specific manufacturer not listed.
Best of Luck, Doug
Using XCOM and Flight Line radios in certificated gliders Paul Remde Soaring 11 August 21st 11 02:34 PM
Drones To Be Certificated For GA? hierophant[_2_] Piloting 36 April 22nd 11 10:14 PM
Considering Refinishing Club/Standard Class Gliders for part time job [email protected] Soaring 8 January 3rd 09 08:21 PM
How are avionics technicians certificated? Jim Stewart Piloting 7 March 18th 07 02:45 AM
Motor gliders in Standard and 15-meter class? wiktor256 Soaring 0 July 23rd 05 08:51 AM
