Cad drawing for ASW27 or ASG29 instrument panel
Old July 24th 14, 02:09 AM posted to rec.aviation.soaring
Default Cad drawing for ASW27 or ASG29 instrument panel
Good add Bill - I'd forgotten that my shop wouldn't let me laser cut the panel directly if I couldn't give them the chemical composition of the epoxy being used - out of fear of toxic fumes. That necessitated the use of a template router. If you can get a shop to let you laser cut the fiberglass directly you cut out the intermediate step and it all goes much faster. Also a lot easier to cut square holes and fine details that way.
Same process as the water jet - just a different tool.
Old December 28th 18, 07:35 PM posted to rec.aviation.soaring
Hello,
I just purchased a 29. Thinking about a new panel. Does anybody still have the files ? I like the process of fitting it using the plastic first. I don’t like reinventing the wheel. Any help would be appreciated. Thank you
Thanks!
Jake
Old December 28th 18, 10:19 PM posted to rec.aviation.soaring
Afandi Darlington
I have one, I’ll email it tomorrow.
At 19:35 28 December 2018, wrote:
Hello,
anybody still
have=
I=
don=E2=80=99t like reinventing the wheel. Any help would be
appreciated.
Thank you
Thanks!
Jake
Old December 28th 18, 10:26 PM posted to rec.aviation.soaring
Chris Wedgwood[_2_]
On Friday, December 28, 2018 at 7:35:46 PM UTC, wrote:
Hello,
I just purchased a 29. Thinking about a new panel. Does anybody still have the files ? I like the process of fitting it using the plastic first. I don’t like reinventing the wheel. Any help would be appreciated.. Thank you
Thanks!
Jake
Theres a drawing of all the different ASG29 panels on the Schleicher website
Old December 29th 18, 12:28 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Here's a link to a .DWG file.
https://drive.google.com/open?id=113...4zNb2IFuOZWkH_
Andy Blackburn
9B
________________________
Hello,
Thanks!
Jake
Old December 29th 18, 07:25 PM posted to rec.aviation.soaring
Gary Wayland
On Thursday, January 20, 2011 at 5:09:34 PM UTC-5, Larry Goddard wrote:
Trying to help a friend with instrument layout for a new panel. Anyone
have a cad drawing of one of these?
Larry
Zero One
I have one for the ASW27 in DWG. How do I get it to you?
Gary
"SQ"
ASW27b
Old December 30th 18, 07:19 PM posted to rec.aviation.soaring
Gary Wayland
Larry
Zero One
Larry, Not only do I have the CAD file, I have many instruments that have the back measurements. So, you can move them around at will in the cad file to see if they are going to fit in the panel. The fronts don't mean much in this job other than looking what will be in the air.
The SN-10 comes to mind. Some instruments have inlarged backs beyond the standard.
I will send all I have with it if you like.
I do have DropBox if you want them. I can post the link
Gary
ASW27b
27-148
"SQ"
PIK-20D Instrument panel Solo Soaring 5 February 15th 09 06:50 PM
CAD drawing for DG instrument panel... Marc Ramsey Soaring 5 April 7th 06 07:12 AM
Instrument Panel ccwillwerth Home Built 7 February 9th 06 02:15 PM
DG-300 instrument panel [email protected] Soaring 14 January 29th 06 02:48 PM
LS 6 b instrument panel John Brenann Soaring 4 November 19th 05 04:37 AM
