I didn't mention that, with the Pfeiffer, the fold out ramp included
tracks which allowed the dollies to be rolled out exposing the entire spar. No bending over required. Of course, some folks could bang their shins if they weren't used to it... Dan Marotta On 11/20/2014 8:03 AM, Papa3 wrote: On Wednesday, November 19, 2014 8:57:37 PM UTC-5, wrote: On Wednesday, November 19, 2014 7:41:04 PM UTC-5, Dan Marotta wrote: The Pfeiffer tube trailer that my Mosquito came in had an excellent back door design. The door was hinged on the right side and, when swung open had brackets for rigging tools, grease, rear jack crank, etc. There was a ramp hinged at the middle and bottom which folded up before closing the door. When swung up, the ramp secured the wingtips with padded cuffs. I thought it was a great design, much better than the home built trailers, but you did have to bend over to get inside. Dan Marotta On 11/19/2014 3:19 PM, Bill D wrote: Also very good for tripping and shin banging if you are not used to it. UH One of the biggest problems I've noticed is that the wing spars have to come out past the end of the tube trailer before you can lift them. That involves some combination of ramps, free-floating dollies, or back breaking lifting. The only time I've actually hurt my back assembling/disassembling a glider was helping a friend to stabilize an LS3 wing that was about to tip over. In a Cobra/Komet, the dolly is captive in the trailer and the root of the spar is easily accessible to lift and start swinging the wing around. I'm sure a good design could be built for the tube trailer, but I haven't seen one yet. NOTE: I have seen the Shirenewton (I think) trailers where the wings go in tip-first, but that means a lot more maneuvering to get the spar to the fuselage. So, the bottom line: Clamshell trailers seem to require the least awkward lifting, fewest steps, and provide the most stable platform for assembly/disassembly IMO. P3 |
On Thursday, November 20, 2014 8:04:06 AM UTC-7, Papa3 wrote:
On Wednesday, November 19, 2014 8:57:37 PM UTC-5, wrote: On Wednesday, November 19, 2014 7:41:04 PM UTC-5, Dan Marotta wrote: The Pfeiffer tube trailer that my Mosquito came in had an excellent back door design.* The door was hinged on the right side and, when swung open had brackets for rigging tools, grease, rear jack crank, etc.* There was a ramp hinged at the middle and bottom which folded up before closing the door.* When swung up, the ramp secured the wingtips with padded cuffs.* I thought it was a great design, much better than the home built trailers, but you did have to bend over to get inside. Dan Marotta On 11/19/2014 3:19 PM, Bill D wrote: Also very good for tripping and shin banging if you are not used to it. UH One of the biggest problems I've noticed is that the wing spars have to come out past the end of the tube trailer before you can lift them. That involves some combination of ramps, free-floating dollies, or back breaking lifting. The only time I've actually hurt my back assembling/disassembling a glider was helping a friend to stabilize an LS3 wing that was about to tip over. In a Cobra/Komet, the dolly is captive in the trailer and the root of the spar is easily accessible to lift and start swinging the wing around. I'm sure a good design could be built for the tube trailer, but I haven't seen one yet. NOTE: I have seen the Shirenewton (I think) trailers where the wings go in tip-first, but that means a lot more maneuvering to get the spar to the fuselage. So, the bottom line: Clamshell trailers seem to require the least awkward lifting, fewest steps, and provide the most stable platform for assembly/disassembly IMO. P3 P3, et al, The following link is to a PDF of BF's tube trailer one man rigging system. I believe the trailer is a Minden Fab. The glider is an LS-3. Bob did not design or build the system, it came with the glider and works wonderfully. The pictures were taken on a day when the wind was gusting to 25kts from front to back of trailer. I originally created this for a LAK12 group, so references to LAK12 are included. I made a similar steel model for my LAK-12 factory trailer. I think Bob still has the LS-3, but is flying a DG-800B presently. http://www.coloradosoaring.org/riggi...um_example.pdf Frank Whiteley |
![]() "Frank Whiteley" wrote in message ... On Thursday, November 20, 2014 8:04:06 AM UTC-7, Papa3 wrote: On Wednesday, November 19, 2014 8:57:37 PM UTC-5, wrote: On Wednesday, November 19, 2014 7:41:04 PM UTC-5, Dan Marotta wrote: The Pfeiffer tube trailer that my Mosquito came in had an excellent back door design. The door was hinged on the right side and, when swung open had brackets for rigging tools, grease, rear jack crank, etc. There was a ramp hinged at the middle and bottom which folded up before closing the door. When swung up, the ramp secured the wingtips with padded cuffs. I thought it was a great design, much better than the home built trailers, but you did have to bend over to get inside. Dan Marotta On 11/19/2014 3:19 PM, Bill D wrote: Also very good for tripping and shin banging if you are not used to it. UH One of the biggest problems I've noticed is that the wing spars have to come out past the end of the tube trailer before you can lift them. That involves some combination of ramps, free-floating dollies, or back breaking lifting. The only time I've actually hurt my back assembling/disassembling a glider was helping a friend to stabilize an LS3 wing that was about to tip over. In a Cobra/Komet, the dolly is captive in the trailer and the root of the spar is easily accessible to lift and start swinging the wing around. I'm sure a good design could be built for the tube trailer, but I haven't seen one yet. NOTE: I have seen the Shirenewton (I think) trailers where the wings go in tip-first, but that means a lot more maneuvering to get the spar to the fuselage. So, the bottom line: Clamshell trailers seem to require the least awkward lifting, fewest steps, and provide the most stable platform for assembly/disassembly IMO. P3 P3, et al, The following link is to a PDF of BF's tube trailer one man rigging system. I believe the trailer is a Minden Fab. The glider is an LS-3. Bob did not design or build the system, it came with the glider and works wonderfully. The pictures were taken on a day when the wind was gusting to 25kts from front to back of trailer. I originally created this for a LAK12 group, so references to LAK12 are included. I made a similar steel model for my LAK-12 factory trailer. I think Bob still has the LS-3, but is flying a DG-800B presently. http://www.coloradosoaring.org/riggi...um_example.pdf Frank Whiteley Oops, winds were 12-15kts on the day. Bob said the rig is good to 25kts unassisted. Mea culpa, Frank |
One of the biggest problems I've noticed is that the wing spars have to come out past the end of the tube trailer before you can lift them. That involves some combination of ramps, free-floating dollies, or back breaking lifting. The only time I've actually hurt my back assembling/disassembling a glider was helping a friend to stabilize an LS3 wing that was about to tip over. _______________________________________ True, but unnecessary with a good design. The approach I would take is to use a captive wing root trailer dolly that allows the wing to swing like a gate away from the fuselage after it's been rolled off the trailer. Add a castering wing-tip dolly (think tail-dolly) and you wouldn't have to carry the tip. Add a one-man dolly which is attached to the wing after it's been swung out and you just have to release the root from its dolly and walk it to the fuselage without the sashay out past the rudder. A rig like this allowed me to rig a Twin Lark's massive wings solo in less than 10 minutes with zero lifting. _____________________________________ In a Cobra/Komet, the dolly is captive in the trailer and the root of the spar is easily accessible to lift and start swinging the wing around. I'm sure a good design could be built for the tube trailer, but I haven't seen one yet. ________________________________ Yes, they're excellent designs and a joy to use but anything can be improved. Bill D |
Aside fromm easier to remove wings from a clam shell as already mentioned the clam shell trailer is a lot smaller (lower profile). since it can close down over the profile of the glider and wings.
I suspect this makes them pull better in general but then my Schreder Style tube trailer pulls great. Agree the rear door system could still use some improvement. Brian HP16T |
At 15:03 20 November 2014, Papa3 wrote:
On Wednesday, November 19, 2014 8:57:37 PM UTC-5, wro= te: On Wednesday, November 19, 2014 7:41:04 PM UTC-5, Dan Marotta wrote: The Pfeiffer tube trailer that my Mosquito came in had an excellent back door design.=A0 The door w= as hinged on the right side and, when swung open had brackets for rigging tools, grease, rear jack crank, etc.=A0 There was a ramp hinged at the middle and bottom which folded up before closing th= e door.=A0 When swung up, the ramp secured the wingtips with padded cuffs.=A0 I thought it was a great design, much better than the h= ome built trailers, but you did have to bend over to get inside. =20 Dan Marotta On 11/19/2014 3:19 PM, Bill D wrote: =20 Also very good for tripping and shin banging if you are not used to= it. UH =20 One of the biggest problems I've noticed is that the wing spars have to com= e out past the end of the tube trailer before you can lift them. That invo= lves some combination of ramps, free-floating dollies, or back breaking lif= ting. The only time I've actually hurt my back assembling/disassembling a= glider was helping a friend to stabilize an LS3 wing that was about to tip= over. =20 In a Cobra/Komet, the dolly is captive in the trailer and the root of the = spar is easily accessible to lift and start swinging the wing around. I'm= sure a good design could be built for the tube trailer, but I haven't seen= one yet. =20 NOTE: I have seen the Shirenewton (I think) trailers where the wings go in= tip-first, but that means a lot more maneuvering to get the spar to the fu= selage. =20 So, the bottom line: Clamshell trailers seem to require the least awkward = lifting, fewest steps, and provide the most stable platform for assembly/di= sassembly IMO.=20 P3 Someone must have specified their Shirenewton trailer for tip first loading of the wings because every modern glider one I have seen (including the one I owned until last year for a D2cT) has had root first loading. Iain Evans also makes excellent dollies and rigging gear. Mine had rotating wing root dollies so the wing could be rotated flat for easy one man rigging - far far easier than with the Cobra trailer + OMRA for my new glider - although the Cobra looks a lot cooler and is famously excellent for towing. John Galloway. |
50 shades of grey glider, whose glider is that in the movie trailer | SF | Soaring | 23 | October 16th 14 05:10 AM |
shipping glider to NZ-advice on securing glider in trailer | November Bravo | Soaring | 6 | November 1st 06 02:05 PM |
F.S. 3-glider trailer | Nigel Pocock | Soaring | 0 | September 29th 06 11:29 AM |
glider trailer Q | Ken Ward | Soaring | 10 | August 28th 06 04:27 PM |
glider trailer Q | Steve Leonard | Soaring | 1 | August 28th 06 05:29 AM |
