"All-terrain" main wheel dolly
Old December 16th 14, 05:39 AM posted to rec.aviation.soaring
Bastoune
Default "All-terrain" main wheel dolly
All - I am looking for an "all-terrain" wheel dolly for a 15M glider main wheel. I am familiar with the GoJack type products (http://www.zendextool.com/gojak/ ) but unfortunately, the size of the casters will not handle gravel surface. Tires will probably have to be 10" pneumatic to do the job on gravel.
I am looking for pictures of a DIY solution, an existing products, or ideas on how to go about it. The wheel dolly needs to be multidirectional and be able to handle a gravel/unimproved hangar floor. Thanks for any ideas or leads!
Bastoune
Old December 16th 14, 02:36 PM posted to rec.aviation.soaring
Papa3[_2_]
Bastoune
Something like the below but with the casters replaced? Looks like they should be removable. I could see building a simple ramp/chock combination to allow you to roll the glider into the higher dolly.
http://www.tractorsupply.com/en/stor...ster--6-in-dia
http://www.tractorsupply.com/en/stor...e?cm_vc=-10005
Old December 17th 14, 02:15 PM posted to rec.aviation.soaring
Tango Eight
Bastoune
These guys could figure it out --
http://www.cynergyergonomics.com/tra...otorized-dolly
but it might be cheaper to do some paving :-).
Evan Ludeman / T8
Old December 17th 14, 02:51 PM posted to rec.aviation.soaring
Bob Kuykendall
Cynergy, I like that. It sounds like the warm fuzzy intersection of cynicism and lethargy.
Old December 17th 14, 04:22 PM posted to rec.aviation.soaring
I can do both but can't decide which to do first.
UH
Old December 17th 14, 04:45 PM posted to rec.aviation.soaring
Frank Whiteley
Bastoune
We had a 'glider spoon' at the old Enstone GC. It was used on an uneven surface to stack gliders in the quonset style hangar from the end. I built a couple locally, one for my self and another for the club as we had gravel floors. Most gliders were on dollies, which only moved in and out sideways.. The hangar floor and ramps were paved a few years ago, so now castering dollies are in use. A 'glider spoon' has two 10 or 12 inch wheels, a round ring with a dish or chains for the main wheel and a long handle. The glider is lifted and jockeyed with the handle. One person can lift a two-seater like a Grob-103 or an L-23. Indeed, the spoon has been used on a few occasions to rescue the two-seaters with flat main wheels from the runway and return them to the hangar for repair, sometimes a few hundred yards without too much effort. Haven't found a picture yet.
Frank Whiteley
Old December 17th 14, 10:35 PM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
Smile
UH
Closely related to "I'd be a procrastinator if I could just get around to it"
Old December 18th 14, 06:52 AM posted to rec.aviation.soaring
Bastoune
All,
Thanks for the inputs.
Frank - If I picture what you are describing, the glider is rolled onto a dish that somehow holds the main wheel. There are two 10" wheels that are offset from the dish and connected to a handle. By applying pressure down on the handle, the dish is lifted (almost like a hand truck) and the glider becomes mobile. I assume that this contraption is all metal, correct? How long was the handle approximately? Thanks B.
Old December 18th 14, 12:09 PM posted to rec.aviation.soaring
John Galloway[_1_]
At 06:52 18 December 2014, Bastoune wrote:
All,
Thanks for the inputs.=20
d=
of=
on
be=
lon=
We used these for many years for hangar packing too. The whole thjng
was steel and the handles were around 12 feet. The main wheel sat in a
ring. There were many trailing edge dings to the wings over the years from
the handles so we switched to main wheel dollies.
John Galloway
Old December 18th 14, 01:03 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
All,
a
d=
of=
on
be=
lon=
fro
John Galloway
I saw one of them when I was at Portmoak in September, can't remember
exactly where but probably around the original hangar.
LS7 Main Wheel / Landing Gear question Gianni Isotope Soaring 3 June 5th 13 05:05 PM
Wing wheel dolly ASM Soaring 0 November 16th 12 04:40 AM
ASW-24 Main Wheel Removal Lauren Rezac Soaring 5 March 19th 12 04:20 PM
Glider Main Wheel Dolly Jim[_18_] Soaring 0 March 9th 11 04:19 PM
main wheel dollies, plans? [email protected] Soaring 1 July 18th 07 06:55 AM
