LS7 Main Wheel / Landing Gear question
Old June 4th 13, 07:41 PM posted to rec.aviation.soaring
Gianni Isotope
Default LS7 Main Wheel / Landing Gear question
After removing the main wheel of my LS7 to service the brake pads/drum and then
replacing the wheel, bushing and right-side spacer, I noticed that the tire is
not exactly centered between the two landing gear forks, but is shifted about
1/4 inch to the right side, away from the side with the brake lever. The tire
also seems to be slightly off-center relative to the CG tow hook. Also, the tire
barely clears two inwardly-facing bolts attached to the right side landing gear fork.
I didn't notice any off-center arrangement before I removed the wheel, but I
probably wasn't looking at it that carefully. It may have been there all along -- wish I took photos.
Does anyone know if this is normal/acceptable, or cause for concern?
Jordan
LS-4 Landing Gear question [email protected] Soaring 4 April 12th 07 08:03 PM
Experimental Landing Gear Design Question Dick Home Built 5 October 15th 06 07:37 PM
Landing gear - stupid question... Capt. Geoffrey Thorpe Soaring 9 December 3rd 05 11:31 AM
Bonanza Model 35 Landing Gear Question Eric Ulmer Owning 1 November 8th 03 02:58 PM
Wanted- 20 series Learjet main landing gear DANIEL R. KARSHIN Aviation Marketplace 0 July 28th 03 05:55 PM
