New Butterfly Display Software 3.2
Old May 28th 13, 06:15 AM posted to rec.aviation.soaring
Andy[_1_]
Default New Butterfly Display Software 3.2
I missed this update until this evening and have just loaded it and found what appears to be a bug.
When selected target altitude and altitude rate are negative they are shown with a large black minus sign. However, when either is positive it is displayed with a much smaller blue plus sign. Surprised no one has mentioned this yet.
Unrelated, but can the clock display that appears when there is no target be made fixed pitch instead of proportional. If fixed pitch is not available can you please fix the position of the hours, minutes, and seconds display fields. Having the display keep jumping in position is irritating and potentially distracting.
thanks,
Andy
Old May 28th 13, 06:49 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Steve Koerner wrote, On 5/27/2013 7:39 AM:
It is my wish that on the radar screen, the symbol used for ADS-B
targets and Flarm targets be distinguishable. I realize that you
don't have many pixels to work with but you could consider something
like making the glider arrowhead distinctive by making the two sides
of the arrowhead concave while leaving the ADS-B target arrowheads
with straight sides.
I agree - make it easy to distinguish ADS-B and Flarm targets.
Have the "beep" when the butterfly is replaced by a target.
I'd like the "beep!" to be louder.
The menu (long push on the button) only shows Volume in flight. Make it
show the full menu in flight. I'd especially like to change between
select and nearest modes, and the way is now, I can not change between
Stealth and No Stealth.
I'm using the Core with the rectangular display that comes with it.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Old May 29th 13, 07:42 PM posted to rec.aviation.soaring
Mike the Strike
What beep? I suspect it is at a frequency above my audible range!
Mike
Old May 30th 13, 04:17 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Marc - Butterfly Avionics wrote, On 5/21/2013 11:19 PM:
Hi,
we have released a new software version 3.2 for the PowerFLARM
displays/Butterfly displays that increases font-size by 40% (which is
a lot). Some other minor changes are included as well.
• Better readability, larger fonts • Shows installed PowerFLARM®
licenses • Support for latest FLARM® error codes • Shows next XPDR
target in list view • minor improvements and bugfixes
We have received (negative) feedback from some of you regarding
readability. Although we can not change issues that come from
screen/sunglass polarization we tried to improve the situation with
font-readability and now have way larger fonts that are easier to
read.
One more comment: the blue dot and blue "circling" arrow don't show up
very often, even when a glider has been circling in a thermal for
several turns. That's on a Core with the latest updates.
email me)
Old June 4th 13, 03:29 AM posted to rec.aviation.soaring
Since the update to 3.2, I can no longer tell which way a arrow is pointing,( direction of flight).
It did make the fonts bigger which I appreciate, but it made the small box the arrow is in too dark to see which way the target is pointing.
Please help. At a contest now and would like to know the direction of the other traffic.
Thanks
Kevin Anderson
Old June 4th 13, 09:40 PM posted to rec.aviation.soaring
Andy[_1_]
On Jun 3, 7:29*pm, wrote:
Please help. *At a contest now and would like to know the direction of the other traffic.
It's easy to go back a version you like better. Just make sure only
one version is in the root directory of the the media.
Andy
Old March 2nd 15, 02:08 PM posted to rec.aviation.soaring
Saw this post http://glidersource.com/cgi-bin/post.cgi?id=662 on Glider Source. Every time I see the Butterfly sold as if it looks like this in real life I think , "man was I ripped off". I dislike getting ripped off by false advertising
so BUYER BEWARE!!
WH1
  #28
Old March 2nd 15, 05:36 PM posted to rec.aviation.soaring
Ramy[_2_]
I am using the exact same butterfly display as in the pic and am happy with it. One of the best investment I made for my panel for an extra $150. Certainly not filling like I was ripped off! What exactly is your issue?
Ramy
  #29
Old March 3rd 15, 01:22 PM posted to rec.aviation.soaring
The picture shows a back lit display with good colors. It is really a dull gray display - if you Google Flarm Display - and then images - you will see several bright pictures and one dull gray display in a panel - the dull one is what you get.
Not a big deal just - it is not like the picture - the pictured one is more like the I believe the LX display which is back lit, bright and much easier to see.
WH1
  #30
Old March 3rd 15, 05:33 PM posted to rec.aviation.soaring
Ramy[_2_]
The display may not be backlighted but it is as bright as needed and as easy to read as any other display in my cockpit.
I have many hours of flying with the butterfly in panel display under any lighting conditions and never had an issue reading the display. I had issues early on with the external rectangular display due to polarization issue.
There is definitely room for some improvement in the butterfly display in my wishlist, making it brighter is not one of them.
Ramy
Flarm Butterfly display [email protected] Soaring 10 May 6th 13 05:40 PM
PowerFLARM core external display software update kirk.stant Soaring 5 January 28th 13 08:56 PM
Updating Software on Butterfly 57 mm version 2.1 display w/o Cable? 3Y Soaring 7 December 31st 12 12:50 PM
Butterfly external display questions Andy[_1_] Soaring 30 October 15th 12 07:20 AM
Question: Display symbology for wind vector in flight software Tuno Soaring 2 December 17th 09 04:14 PM
