New Butterfly Display Software 3.2
Old May 22nd 13, 07:19 AM posted to rec.aviation.soaring
Marc - Butterfly Avionics
Default New Butterfly Display Software 3.2
Hi,
we have released a new software version 3.2 for the PowerFLARM displays/Butterfly displays that increases font-size by 40% (which is a lot). Some other minor changes are included as well.
• Better readability, larger fonts
• Shows installed PowerFLARM® licenses
• Support for latest FLARM® error codes
• Shows next XPDR target in list view
• minor improvements and bugfixes
We have received (negative) feedback from some of you regarding readability.. Although we can not change issues that come from screen/sunglass polarization we tried to improve the situation with font-readability and now have way larger fonts that are easier to read.
Please read this manual if you wish to install the update:
http://www.butterfly.aero/support/CL32_EN.pdf
Please find the update files he
http://www.butterfly-avionics.com/in...upport-english
Thanks a lot for your feedback and always happy landings
Marc
The Butterfly Team
Old May 22nd 13, 08:17 AM posted to rec.aviation.soaring
kirk.stant
On Wednesday, May 22, 2013 8:19:05 AM UTC+2, Marc - Butterfly Avionics wrote:
Hi,
We have received (negative) feedback from some of you regarding readability. Although we can not change issues that come from screen/sunglass polarization we tried to improve the situation with font-readability and now have way larger fonts that are easier to read.
Marc
Marc, that is great! Your team's fast response to a customer comment is greatly appreciated - us older gliderguiders have a tough time reading the "small print" on many digital displays, something young designers may not appreciate - yet!
Cheers,
Kirk
66
Old May 22nd 13, 01:38 PM posted to rec.aviation.soaring
Dave Nadler
Thanks Marc !
I flew with v3.2 at the 18-meter nationals last week,
and it does help readability - do install it !
Best Regards, Dave
Old May 22nd 13, 03:47 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Marc - Butterfly Avionics wrote, On 5/21/2013 11:19 PM:
Hi,
• Better readability, larger fonts • Shows installed PowerFLARM®
licenses • Support for latest FLARM® error codes • Shows next XPDR
target in list view • minor improvements and bugfixes
read.
Thanks a lot for your feedback and always happy landings Marc The
Butterfly Team
The bigger, bolder font in the previous 3.1 update seems very easy to
read. Does this bigger font in 3.2 reduce the "radar" display size? I
don't want that any smaller.
I'd like the alarm sound made at least twice as loud on the display for
the core. It's not just the vision that degrades as one becomes an older
gliderguider.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Old May 22nd 13, 04:34 PM posted to rec.aviation.soaring
Hi Eric,
the radar stays identical, only the fonts are increased in size. To be honest, we use a modification of our old fonts (sw version 2.2 and lower) that may only be familiar to our european users.
best,
Marc
Old May 22nd 13, 05:41 PM posted to rec.aviation.soaring
John Carlyle
Marc,
I do intend to load v3.2, but out of curiosity, is it possible to reload an older version of firmware if you don't like the newer version?
-John, Q3
On Wednesday, May 22, 2013 11:34:51 AM UTC-4, Marc - Butterfly Avionics wrote:
best,
Marc
Old May 23rd 13, 06:21 AM posted to rec.aviation.soaring
Yes john, this is nor problem. You can always upgrade-downgrade to any desired version.
Because of this reason please make sure than only one .bfn file is on your USB-Stick/microSD-Card when updating through PowerFLARM.
Old May 23rd 13, 12:49 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
On Wednesday, May 22, 2013 2:19:05 AM UTC-4, Marc - Butterfly Avionics wrote:
Hi,
Marc
The Butterfly Team
Thanks, this will help.
Is there a backlight in this display? If there is, an additional, enormously helpful tweak would be to crank up the illumination during alerts.
T8
Old May 23rd 13, 05:40 PM posted to rec.aviation.soaring
Hi, having issues with the download from he http://www.butterfly-avionics.com/in...upport-english
when I download it, it comes as a .zip file when I then extract the files I get a .exe file then if I try and run it, I get a error reading com ports. Is ther a place just to get the .BFW and .BFN update files? They are fairly small files and don't really need to be compressed. This happens with both the flarmnet and display updates. Or am I or Freaking windoze 7 doing something wrong?
Thanks CH
Old May 23rd 13, 06:59 PM posted to rec.aviation.soaring
bumper[_4_]
Thanks CH
Right click on the center part of the links (Update file for PowerFlarm).
Choose "save link as".
Select your usb or sd location.
Save
Note: don't click on the link to open it or your computer may save it as a txt file.
Works for me! (and I hate computers)
bumper
Flarm Butterfly display [email protected] Soaring 10 May 6th 13 05:40 PM
PowerFLARM core external display software update kirk.stant Soaring 5 January 28th 13 08:56 PM
Updating Software on Butterfly 57 mm version 2.1 display w/o Cable? 3Y Soaring 7 December 31st 12 12:50 PM
Butterfly external display questions Andy[_1_] Soaring 30 October 15th 12 07:20 AM
Question: Display symbology for wind vector in flight software Tuno Soaring 2 December 17th 09 04:14 PM
