Spring prepapration advice
Old March 12th 15, 08:21 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default Spring prepapration advice
On Thu, 12 Mar 2015 07:30:56 -0700, crosscountryboxco wrote:
It is exactly like that: "the resin is fractured leaving a corner of the
door attached by some glass weave" .
To me that's a two or three stage job for laminating resin plus a few
square inches of good quality glasscloth.
1) Wet out the fracture with the resin (you can thin it with methanol
if you must but be aware that will weaken the bond) and clamp it to
a former to hold it straight while it cures.
Don't forget the release film.
2) Sand off any lumps on the inside of the door and bond on a layer of
close weave cloth using laminating resin. 100 gsm/3 oz/ft cloth
should do the trick.
3) If the corner was just hanging by a thread, carefully sand off the
gelcoat etc on the outer surface and bond on a layer of light fine
weave cloth, 35 gsm/ 1-1.25 oz/ft weight. There is lighter cloth
but the thread count is low. You'll get a better finish with 35gsm
cloth. Then prepare and glasscloth surface and paint the outer
surface of the door.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old March 13th 15, 01:40 PM posted to rec.aviation.soaring
Thanks for your advice.
I will get the laminating resin from ADC and follow all your advice.
Dan
org |
Old March 13th 15, 07:26 PM posted to rec.aviation.soaring
On Fri, 13 Mar 2015 06:40:04 -0700, crosscountryboxco wrote:
Oops -that should read:
weave cloth, 35 gsm/ 1-1.25 oz/ft weight. There is lighter cloth but
Then prepare new glasscloth surface. Use fine sandpaper (180-200 grit on
a sanding block) to get a smooth surface on the glasscloth and feather
its edges before painting it.
The nice thing about good quality 35gsm cloth is that the epoxy usually
fills the weave pretty well. This means you don't need to sand it much to
get rid of the fabric effect after the epoxy has cured.
org |
DISCUS B Gas Spring Mike J. Soaring 1 May 18th 14 12:52 PM
Canopy gas spring LS4, USA [email protected] Soaring 3 October 30th 12 12:01 PM
spring trim metrics Brad[_2_] Soaring 2 February 2nd 09 01:48 PM
TOST Tow Spring Pad for Cub [email protected] Soaring 0 January 21st 08 04:08 AM
Windsocks , Spring Special GASSITT General Aviation 0 April 2nd 04 03:05 PM
