Spring prepapration advice
Old March 11th 15, 03:23 PM posted to rec.aviation.soaring
Default Spring prepapration advice
The corner of my Ventus landing gear door got bent and needs to be glued back to its former shape.
What epoxy should I use (I need a very small amount)
Need to clamp the piece while drying. What material to use so the clamp doesn't stay glued to the door....?
Dan
Old March 11th 15, 03:52 PM posted to rec.aviation.soaring
Dan
For this you could use a slow curing epoxy from your local hobby shop. I would not recommend 5 minute epoxy from your local hardware store.
Poly film placed over the repair before clamping will allow removal and can help make the shape better.
Good luck
UH
Old March 11th 15, 07:04 PM posted to rec.aviation.soaring
A Ventus door is glass right? I am trying to understand what "bent" means in this context. Is it that the resin is fractured leaving a corner of the door attached by some glass weave or does it mean a piece has broken off? For any large fix, you need to know what you are doing. Several on the forum can help in that case like JJ.
Old March 11th 15, 07:42 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Dan
Good luck UH
The heat-shrink film used to wrap CDs, cigarettes, etc makes a good epoxy
release film. IIRC clingfilm also works, but do test it before using it
in anger.
Epoxy: 24hour epoxy gives a tougher result than the 5 minute epoxies,
which tend to be brittle when cured. However if your gear door shows
signs of delamination, one of the laminating epoxies would be better
because its relatively thin and so can be worked in to saturate the
delaminated/fractured area. The better hobby stores will stock it in
fairly small amounts: look for Z-poxy or SP113.
When I bought my Libelle, the front of its gear goods were decidedly moth-
eaten so I repaired the damaged front edges and corners:
- made a thin (1/32") ply laminated former that matched the outside curve
(a good quality cardboard lamination would also do since you'll only
use it once)
- covered that with release film (see above).
- cleaned up the more ragged door edges with knife, Dremel and sandpaper,
removing paint etc within 1/2" of the cleaned-up edges.
- taped and clamped the former onto the door
- used laminating epoxy/glasscloth/fibreglass mat to build up an
oversized section to replace the missing door area.
- let it harden thoroughly.
- took off the former and put a layer of 35gsm/1 oz/ft twill weave glass
cloth on the outside so it overlapped the bared area of the door and a
similar layer of thicker classcloth on the inside. This vastly
strengthens the join while leaving a nice surface to paint on the
outside
- then cut off the excess so the repaired doors were a nice fit in the
fuselage.
- painted the doors and refitted them.
I realise your repair is different, but working laminating epoxy into the
bent/damaged area, clamping it to a former to keep it straight while it
cures and then putting 100gsm/3 oz/ft glass cloth on the inside of the
door to cover the repaired crease should make a good job. This requires
laminating epoxy. Ordinary tubes of 24 hour epoxy are far too thick and
gooey for anything to do with glass-cloth: try using it with classcloth
and you'll just end up with a mega-sticky, epoxy-soaked ball of glasscloth
stuck to your hands.
A good hobby store (either online or highstreet) should have laminating
epoxy and glass cloth in fairly small quantities or, if you have a nearby
sailplane repair shop, they may let you have a small amount of epoxy and
some glasscloth offcuts. If all fails, try:
Aerospace Composite Products http://www.acp-composites.com/
or
Composite Structures Technology http://www.cstsales.com/
Both are in California and are extremely knowledgeable about
composite structures, materials and how to repair them.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old March 11th 15, 10:25 PM posted to rec.aviation.soaring
Agree. ACP is good stuff. They sell everything he will need from mylar to peel-n-ply, glass and excellent laminating resin. This is all aircraft grade stuff in reasonable quantity. While MGS is the best, its only available by the gallon from Aircraft Spruce. going this route, fix it once and be done.
May want to post-cure too.
But with either hobby grade epoxy or CA+kicker(quick fix), likely not a lasting fix IMO.
Old March 12th 15, 11:39 AM posted to rec.aviation.soaring
On Wednesday, March 11, 2015 at 8:51:33 PM UTC-4, Dan Marotta wrote:
I've always had good luck with wax paper as the release agent.* You
probably already have some in the kitchen.
Perfect for making finishing harder. Use the plastic wrap next to the wax paper instead.
UH
Old March 12th 15, 02:26 PM posted to rec.aviation.soaring
lasting fix IMO.
Some hobby laminating epoxys may be junk but I've always had good results
with Z-poxy and SP113. I don't remember which one I used for my gear
doors but for sure it was one of those: probably the SP113 because the
repaired area is pale coloured. Z-poxy tends to be amber coloured while
SP113 is water-white.
That repair was done in winter 2006/7. The doors still looked great when
I checked them during the glider's annual inspection on the 2nd of this
month.
org |
Old March 12th 15, 02:30 PM posted to rec.aviation.soaring
It is exactly like that: "the resin is fractured leaving a corner of the door attached by some glass weave" .
Dan
Old March 12th 15, 02:42 PM posted to rec.aviation.soaring
I've always had good luck with wax paper as the release agent.Â* You
wax paper instead.
UH
Beeswax furniture polish is also good: its my favourite release agent if
I'm laying up small items on moulds made from car body filler. A couple
of coats, applied fairly liberally and rubbed down when works for me.
A single coat of the John Lewis Partnership beeswax polish (a thick
paste) applied to a scrap piece of bare, unvarnished, veneered shelving
and allowed to dry before I laid up a couple of layers of glasscloth
wetted out with SP113 directly on the polish was enough to cause an
immediate release after the epoxy had hardened. I stuck a knife blade
under one edge and the whole test patch, about 50mm x 50mm, popped right
off the wood.
As always, try any release agent on some scrap material before using it
for the real job. This advice probably applies in spades to furniture
polish: I always use the John Lewis Partnership beeswax polish but I can
well imagine that other brands may give different results.
org |
DISCUS B Gas Spring Mike J. Soaring 1 May 18th 14 12:52 PM
Canopy gas spring LS4, USA [email protected] Soaring 3 October 30th 12 12:01 PM
spring trim metrics Brad[_2_] Soaring 2 February 2nd 09 01:48 PM
TOST Tow Spring Pad for Cub [email protected] Soaring 0 January 21st 08 04:08 AM
Windsocks , Spring Special GASSITT General Aviation 0 April 2nd 04 03:05 PM
