LX5000 stuck in cruise mode
Old October 21st 15, 06:36 PM posted to rec.aviation.soaring
Alan D
Default LX5000 stuck in cruise mode
Anyone have this issue - the cruise/climb switch on my LX5000 does not change the setting any more (vario stuck in cruise), the auto settings do not work. The switch itself is working so this has to be a software issue. Any ideas on how to fix it.
Old October 21st 15, 07:21 PM posted to rec.aviation.soaring
Luke Szczepaniak
There is a setting in there somewhere for the SC switch to be
on/off/taster - you can try playing with those. Are you sure there
isn't a short somewhere down the line from the switch? If you are sure
it is not the hardware you can try resetting the unit to factory
defaults - the password should be some where in the manual....
Good luck
Luke
Old October 22nd 15, 09:58 AM posted to rec.aviation.soaring
Hi Alan
check the Vario priority switch as per below, it might be the problem
The cable marked VAR PRIOR may be connected to a simple ON /OFF switch and may be installed in the instrument pannel. If the switch is closed the LX5000 will always be in the vario-mode, regardless of the position of the flap switch or the setting of the automatic speed command.
Transponder: Mode-C or Mode-S? Morteza Ansari Soaring 27 April 17th 19 06:02 AM
LK8000 Portrait mode in PC sim mode kirk.stant Soaring 22 December 28th 11 03:25 PM
TT21 Stuck in Configuration Mode Frank Paynter[_2_] Soaring 4 February 26th 11 12:56 AM
New transponder mode S vs. mode C Tom N. Soaring 39 November 7th 06 08:40 AM
LX5000 help Ted Wagner Soaring 1 April 29th 04 04:27 AM
