TT21 Stuck in Configuration Mode
Old February 25th 11, 02:53 PM posted to rec.aviation.soaring
Frank Paynter[_2_]
Default TT21 Stuck in Configuration Mode
I installed a TT21 last fall and *thought* I had it configured and
working properly. I fired it up this morning in preparation for the
start of the soaring season, and it came up in configuration mode
instead of the normal operating mode. I ran through the configuration
sequence again, turned it OFF when prompted, but it still comes up in
config mode when I apply power.
As a possible data point, I still have all zeros in for the system
Mode S 'address' - could this be the problem? If so, how does one go
about acquiring an address?
TIA,
Frank (TA)
Old February 25th 11, 03:35 PM posted to rec.aviation.soaring
Grider Pirate
working properly. *I fired it up this morning in preparation for the
instead of the normal operating mode. *I ran through the configuration
Mode S 'address' *- could this be the problem? *If so, how does one go
TIA,
Frank (TA)
Frank,
Your address is part of your aircraft registration information. You
can get it he
http://registry.faa.gov/aircraftinqu...m_Inquiry.aspx
You will need to convert it to hexidecimal for input into the TT21.
I seem to recall some talk of the TT21 not working without the
address, so this may be your problem.
Old February 25th 11, 04:27 PM posted to rec.aviation.soaring
Frank Paynter[_2_]
TIA,
Frank (TA)
Frank,
Your address is part of your aircraft registration information. *You
can get it hehttp://registry.faa.gov/aircraftinqu...m_Inquiry.aspx
Yep - that was it - got the S-mode address from the FAA site, used the
Octal to Hex converter on the Trig website, entered it, and viola -
I'm in normal operating mode!
Thanks for the timely - and completely accurate/helpful - response.
Frank (TA)
Old February 25th 11, 04:31 PM posted to rec.aviation.soaring
Grider Pirate
TIA,
Frank (TA)
Frank,
Frank (TA)- Hide quoted text -
- Show quoted text -
Can I quote you on my performance review??
Old February 25th 11, 11:56 PM posted to rec.aviation.soaring
Frank Paynter[_2_]
TIA,
Frank (TA)
Frank,
Sure, but quoting me might have the opposite of the intended
effect ;-)
Frank (TA)
Trig TT21 Transponder ... reports? Grider Pirate Soaring 105 March 29th 18 01:10 AM
Trig TT21 transponder draws only 125 mA! Steve Koerner Soaring 5 March 15th 10 09:59 PM
TRIG TT21 Transponders Tim Mara[_2_] Soaring 12 September 26th 09 02:01 AM
Trig TT21 in Experimental Aircraft Paul Remde Soaring 5 July 5th 09 03:15 AM
New transponder mode S vs. mode C Tom N. Soaring 39 November 7th 06 07:40 AM
