Alternative magnetic compass
Old October 30th 15, 09:20 PM posted to rec.aviation.soaring
Andrzej Kobus
Default Alternative magnetic compass
On Friday, October 30, 2015 at 5:00:02 PM UTC-4, jfitch wrote:
On Friday, October 30, 2015 at 1:03:52 PM UTC-7, Mike the Strike wrote:
I should also remind everyone that GPS-derived bearings only work when you are moving with respect to the ground. Just remember this if you're stationary or even moving backwards in wave.
Mike
There are GPS compasses that do not depend on motion for operation. Doubt anyone has one in a glider though.
I don't think there is such a thing as GPS compass, regardless if you are moving or not. GPS is measuring your position, it has nothing to do with measurement of magnetic field.
  #42
Old October 30th 15, 09:31 PM posted to rec.aviation.soaring
Dave Doe
, says...
A sailplane's Flight Manual usually requires a magnetic compass (or an
aviation compass)as minimum equipment. Well, panel space has become
less available and you are seeing fewer sailplanes with panel or
glare-shield mounted 2.25 Airpath C2xxx or PAI-700 aircraft specific
compasses.
Anyone have a "point" to an off panel compass that might meet FAA
scrunity? Unfortunately the Cook compass manufactured by COBB-SLATER
Instruments Co. Ltd is no longer available.
http://compassmuseum.com/aero/aero.htm#COOK
Probably, a magnetic compass is the last instrument used by a
competition pilot. Most competition sailplanes have 3 or more separate
GPS engines and it is very simple to have them on independent battery
sources. What would be the "penalty" if your sailplane failed a FAA
"courtesy" ramp inspection because it lacked a magnetic compass?
Does a F-35 Lighting II joint strike fighter has a magnetic compass?
I'm sure it does, but it'll be an electrical one - that is, one using a
magnetometer.
Makes me wonder, how would such a, cheap but obviously not FAA approved
device go, for gliders...
https://duckduckgo.com/?q=arduino%20magnetometer&t=lm
Duncan.
  #43
Old October 30th 15, 09:43 PM posted to rec.aviation.soaring
You can determine orientation (including direction) by using difference in 3D position of two GPS receivers (actually their antennae) mounted at a fixed displacement from each other. It's a bit more complicated than it sounds, as ideally, the two GPS receivers will have synchronized clocks and be using the same satellites for their position solutions. So, the receivers used are quite specialized.
  #44
Old October 30th 15, 10:49 PM posted to rec.aviation.soaring
Andrzej Kobus
You are right, with two receivers and antennas far apart to mitigate the errors it is possible. Not something that one would want to mount in an aircraft.
  #45
Old October 31st 15, 12:13 AM posted to rec.aviation.soaring
Been done. Check out Septentrio.
http://www.navtechgps.com/assets/1/7...0415_41_DS.pdf
  #46
Old October 31st 15, 12:22 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
aircraft.
You could get a reliable heading with a fluxgate (solid state) compass
but not, as you say, with a single GPS receiver.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
  #47
Old October 31st 15, 12:41 AM posted to rec.aviation.soaring
Casey Cox
On Wednesday, October 28, 2015 at 10:32:51 AM UTC-4, wrote:
A sailplane's Flight Manual usually requires a magnetic compass (or an aviation compass)as minimum equipment. Well, panel space has become less available and you are seeing fewer sailplanes with panel or glare-shield mounted 2.25 Airpath C2xxx or PAI-700 aircraft specific compasses.
Grob Astir CS does not require as minimum equipment.
https://www.dropbox.com/s/yjlrf96sbf...%20PM.png?dl=0
  #48
Old October 31st 15, 12:47 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Please correct me if I am wrong, but doesn't the Butterfly S and the LX90XX with compass option both have fluxgate compass? One would think with these instruments we would not have to have a whiskey compass, that just takes panel/glare-shield space.
org |
  #49
Old October 31st 15, 11:38 AM posted to rec.aviation.soaring
Perhaps LXNAV has the best chance of approval as the new LXNAV Compass module is advertised as a magnetic compass and sold as a separate (add-on) feature. A better job of "wordsmanship" than Air Avionics' Butterfly S.
If only the sailplane manufactures would release a Technical Bulletin stating these devices satisfy intention. But in today's world of government oversight and manufacture's liability risk, a snowball in hell has a better chance.
  #50
Old October 31st 15, 03:29 PM posted to rec.aviation.soaring
jfitch
org |
The Butterfly S doesn't have a compass option, it has the compass as a standard feature. The issue might be whether regulations require a TSO'd compass.
Need help! Magnetic Compass Errors! kha0z Piloting 14 January 3rd 09 03:20 AM
Why are headings still magnetic? Mxsmanic Piloting 87 September 11th 06 05:34 PM
compass turns with high mounted compass (Cessna 152) Ray Instrument Flight Rules 22 April 7th 05 07:39 AM
Aircraft Magnetic Compass Quilljar Simulators 5 July 11th 04 03:08 PM
Do you use your magnetic compass? Roger Long Piloting 42 May 25th 04 12:08 PM
