Alternative magnetic compass
Old October 28th 15, 02:32 PM posted to rec.aviation.soaring
Default Alternative magnetic compass
A sailplane's Flight Manual usually requires a magnetic compass (or an aviation compass)as minimum equipment. Well, panel space has become less available and you are seeing fewer sailplanes with panel or glare-shield mounted 2.25 Airpath C2xxx or PAI-700 aircraft specific compasses.
Anyone have a "point" to an off panel compass that might meet FAA scrunity? Unfortunately the Cook compass manufactured by COBB-SLATER Instruments Co. Ltd is no longer available. http://compassmuseum.com/aero/aero.htm#COOK
Probably, a magnetic compass is the last instrument used by a competition pilot. Most competition sailplanes have 3 or more separate GPS engines and it is very simple to have them on independent battery sources. What would be the "penalty" if your sailplane failed a FAA "courtesy" ramp inspection because it lacked a magnetic compass?
Does a F-35 Lighting II joint strike fighter has a magnetic compass?
Old October 28th 15, 02:53 PM posted to rec.aviation.soaring
Dan Marotta
A poor showing during a ramp inspection (we're not happy until you're
not happy) would likely result in your aircraft being grounded until you
show compliance.
I'll bet the F-35 has a "whiskey" compass and I'll further wager that
the flight manual says something along the lines of, "Flying by use of
the magnetic compass is an emergency procedure." At least that's the
way it was back in the '70s.
Dan, 5J
Old October 29th 15, 03:21 PM posted to rec.aviation.soaring
jfitch
you're not happy) would likely result in your aircraft being
grounded until you show compliance.
that the flight manual says something along the lines of, "Flying by
use of the magnetic compass is an emergency procedure."* At least
that's the way it was back in the '70s.
Dan, 5J
I wonder how many sailplanes have the required magnetic deviation card for their required compass.
Old October 29th 15, 03:31 PM posted to rec.aviation.soaring
Dave Nadler
Wrong question! How many have actual values, and how many have
made up nonsense to satisfy the inspector?
See ya, Dave
Old October 29th 15, 03:39 PM posted to rec.aviation.soaring
Dan Marotta
Snip
/Snip
Shhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh.....
Dan, 5J
Old October 28th 15, 07:40 PM posted to rec.aviation.soaring
JS
If you're glider is registered as EXP, look for a PZL compass. Might fit in an odd "corner" of the panel.
Old October 28th 15, 09:19 PM posted to rec.aviation.soaring
Dave Springford
I sell a TSO'd compass that is similar to the PZL compass. The SIRS Navigator.
You can find it he
http://www.foxonecorp.com/index.php/...uments/compass
Also have the standard Airpath and a panel mount SIRS compass as well. The Navigator is nice as a glareshield mount because it is smaller than the Airpath.
Typical mount in a glider involves removing the mounting arm and top plate from the compass and then screwing the compass to the instrument panel glareshield at the bottom. There is a slide on slide off "foot" at the bottom of the compas. This reduces the height of the unit by about 1/2 inch.
Dave Springford
www.foxonecorp.com
Old October 29th 15, 04:03 AM posted to rec.aviation.soaring
SoaringXCellence
In the US you might check your glider Type Data Certificate. The Libelle H301 does not require a compass unless you are intending to do cloud flying, which is, of course, not permitted in the US contests. (However it is still possible to have a glider certificate with instrument privileges, but I haven't figured out how to take the test!)
Old October 29th 15, 04:12 AM posted to rec.aviation.soaring
SoaringXCellence
Oops, I stand corrected, the TCDS for the Libelle requires a compass, HOWEVER, the pilot manual says that the compass is only required for cloud flying.
Old October 29th 15, 03:37 PM posted to rec.aviation.soaring
Dan Marotta
From the LAK-17a Flight Manual:
For cloud flying the following additional equipment is required:
- variometer;
- magnetic compass compensated in the sailplane;
- turn and bank indicator, non-icing;
- transceiver;
- parachute, automatic or manual opening type;
- thermometer for outside air;
- non-icing airspeed system.
The minimum equipment must correspond with national regulations.
I've been instrument rated for about 41 years and I don't know what a
non-icing turn and bank indicator is or how it works. Could someone
enlighten me, please? And let's not forget the pitot /and/ static
heat! Maybe total energy probe heat, as well. There's a mag compass
mounted at the far forward end of my glare shield (probably from the
factory) with a nice, flat black aluminum hood over it. It's below the
level of the plexiglass and unobtrusive and I practically never look at
it. Instead, I use that mountain 100 miles distant to orient myself.
Dan, 5J
Need help! Magnetic Compass Errors! kha0z Piloting 14 January 3rd 09 03:20 AM
Why are headings still magnetic? Mxsmanic Piloting 87 September 11th 06 05:34 PM
compass turns with high mounted compass (Cessna 152) Ray Instrument Flight Rules 22 April 7th 05 07:39 AM
Aircraft Magnetic Compass Quilljar Simulators 5 July 11th 04 03:08 PM
Do you use your magnetic compass? Roger Long Piloting 42 May 25th 04 12:08 PM
