ASW 19 aileron weight and balance information
Old November 22nd 15, 02:28 PM posted to rec.aviation.soaring
Default ASW 19 aileron weight and balance information
I am looking for the weight and balance specs for the control surfaces for an ASW 19. Ailerons, elevator, and rudder. In theory, that ought to be in the maintenance manual. Which I don't have. If you have this manual, or even the specs for the control surfaces could you let me know?
Thanks!
John Swanson.
Swanson43537. At. Yahoo dot com.
Old November 22nd 15, 06:38 PM posted to rec.aviation.soaring
Gordon Walker[_2_]
Rudder without horn balance 6.61 to 7.50 lbs weight
6.94 to 9.55 in/lb max play 5.0 mm
Rudder with horn balance, 7.28 to 8.16 lbs weight
7.81 to 10.41 in/lb max play 5.0 mm
Elevator 4.36 to 6.39 lbs weight
5.21 to 7.81 in/lb max play 3.0 mm
Aileron 6.61 to 7.94 lbs weight
7.59 to 9.33 in/lb max play 3.5 mm
It is in the flight & operations manual for ASW 19b
Regards
Gordon
Old November 22nd 15, 10:27 PM posted to rec.aviation.soaring
Thanks! Do you have a copy of the manual? The manual disappeared from mine years ago before I owneed it. (but not the logbooks, thank goodness). The copy that everyone I've contacted so far has is only the flight manual, ending on page 19. The table of contents references the operations manual, but I've never been able to locate the missing pages.
Old November 22nd 15, 11:03 PM posted to rec.aviation.soaring
Gordon Walker[_2_]
You have e-mail
PA-32 Weight and Balance John Doe Owning 14 May 23rd 06 01:03 AM
L23 weight and balance Tony Verhulst Soaring 5 December 31st 05 01:54 AM
Weight & Balance DVD jon Home Built 0 October 8th 05 05:39 PM
Weight and Balance Dale Larsen Home Built 2 June 23rd 04 05:11 PM
Weight and balance.. Bart Rotorcraft 9 August 19th 03 02:57 AM
