Nimbus 2 load factor limits?
Old December 15th 15, 05:36 AM posted to rec.aviation.soaring
Surge
Default Nimbus 2 load factor limits?
Does anyone know what the load factor limits are for the Nimbus 2?
It's not stated in the manufacturer's manual which I find rather strange. Surely these limits would have been measured and verified during type certification?
Searching the Internet didn't reveal anything either and it seems that there are other owners who don't know those figures either.
e.g. http://www.glidingwa.com.au/Private%...2/Page%20X.htm
Old December 15th 15, 08:10 AM posted to rec.aviation.soaring
Jock Proudfoot
2?
+5.3g and -2.65g at VA
+4.0g and -1.5g at VNE
http://wwwapps.tc.gc.ca/saf-sec-sur/...celn/c_d.aspx?
lang=eng&amp%3baprv_num=G-
113&amp%3bISU_NUM=3&amp%3bSTART_DATE=2003-04-
14&amp%3bAUTH_DESC=&amp%3bDESC=&amp%3bFRGN_NUM=&
amp%3baprv_type=TA&amp%3bPARTS_NUM=&amp%3bid_num=8
86
Cheers ...Jock
Old December 15th 15, 08:27 AM posted to rec.aviation.soaring
Bengt Aronsson[_3_]
Well, according to the tcds linked from german CAA website (
https://www2.lba.de/data/bb/Segelflug/sp_0286_01.pdf ) its certified to
german LFS requirements without deviations. The min required load factors
then is +5.3 / -2.65g at max maneuvering speed, lineary decreasing to +4.0
/ -1.5g at Vne.
Airbrakes out requirements are +3.5 / -0g.
certification?
Old December 15th 15, 11:21 AM posted to rec.aviation.soaring
Surge
/ -1.5g at Vne.
Thank you very much.
That railway line, main spar looks like it could take a lot more abuse than the certified limits.
Old December 15th 15, 12:09 PM posted to rec.aviation.soaring
Bruce Hoult
/ -1.5g at Vne.
I'm sure Ray Lynskey's N2 got an awful lot of high speed (and often high altitude) abuse on mountain ridges and in rotor. It survived it.
Old December 15th 15, 01:46 PM posted to rec.aviation.soaring
Chris Rollings[_2_]
The figures quoted are the JAR22 Certification requirements of that era.
It was necessary to demonstrate that, at least in theory, it could take 50%
in excess of that, and in practice most types even exceeded that. However
that was when they were new.
to
factors
+4.0
/ -1.5g at Vne.
Old December 15th 15, 02:29 PM posted to rec.aviation.soaring
WAVEGURU
Does the aging of fiberglass weaken it? Learn something new every day here on RAS.
Boggs
Old December 15th 15, 07:16 PM posted to rec.aviation.soaring
Boggs
Looking at the chemistry, polymerization should continue as the glider ages. With more cross-links, the structure should be getting stronger with age (unlike you and I, Gary).
Torque and P-factor Marten Kemp Piloting 3 October 28th 13 04:13 AM
How Much Load for a Load Test? Brian Whatcott Home Built 13 July 6th 09 06:07 PM
Pucker Factor SOS[_3_] Piloting 0 May 31st 08 11:21 PM
DC-3/C-47 Limit Load Factor Dale General Aviation 6 July 2nd 06 04:28 AM
gpa a factor after graduation? sibersmith Military Aviation 28 November 26th 03 05:06 PM
