DC-3/C-47 Limit Load Factor
Old June 26th 06, 08:09 PM posted to rec.aviation.misc
Default DC-3/C-47 Limit Load Factor
Anyone know what they are? Any idea where to look to find the info?
I've looked at the TDC and didn't see it listed.
TIA
Old June 27th 06, 02:58 AM posted to rec.aviation.misc
TIA
Dale,
Talked to a guy who has an old Army Flight Manual, and one of Warren
Woods', too. He described a graph in the Army book that showed a limit
of 3.0 G's at 26000 lbs, sloping to 2.5 G's at 30600 lbs, and then
extending into the "caution" zone up to about 36000 lbs.
The Woods manual listed several configurations, from flaps 0 to flaps
45, and various angles of attack. Basically, these values ranged from
+/- 2.83 G's, down to +0.44 G's, all at 26900 lbs.
These values seem consistant with CAR 4b, which it was probably
certified under. 4b states a minimum of 2.5 Gs.
I suspect these figures are in reality *very* conservative, as no one
I've ever talked to has heard of a -3 falling out of the sky due to load
induced structural failure.
Happy Flying!
Scott Skylane
Old June 27th 06, 04:31 AM posted to rec.aviation.misc
Thanks Scott!
Yeah, sounds conservative to me..especially after seeing the way they're
built. That gives me a start though.
Thanks again.
Old June 27th 06, 02:13 PM posted to rec.aviation.misc
During the Berlin Airlift, a C-47 took off with a full load of
X sheets of Perforated Aluminum Planking, for extending the destination
runway.
Turned out it was X sheets, but Perforated STEEL Planking....
and it still flew..
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old June 28th 06, 12:06 AM posted to rec.aviation.misc
runway.
and it still flew..
I don't think you can get a C-47 overgross. I do know you can get it
out of cg. I've seen one spin. It's a fascinating sight.
Michael
Old June 28th 06, 03:10 AM posted to rec.aviation.misc
runway.
and it still flew..
Michael
From the 'outside' maybe...I'd use another word to describe the
view from the 'inside...'
-Gord.
(use gordon in email)
Old July 2nd 06, 04:28 AM posted to rec.aviation.misc
Stache
Dale,
I have placed all the CAR's on my web site: http://www.stacheair.com/
CAR-4 has the limitations and is pretty close to Part 25. The type
certificate data sheet calls Army Technical Orders 01-40NC-82 and
01-40NC-86, which should have the limit load requirement.
You can contact Technology Transition Office Wright Patterson AFB
(800)203-6451 who can track down the correct manual to give the load
limits. I have use this office on several projects I have worked on.
Stache
F/A-18 external stores load [email protected] Naval Aviation 3 December 27th 04 07:59 AM
If I make it stronger Jdandy Home Built 9 August 30th 04 08:22 PM
Stupid question about flight testing and "the envelope" Scott Ferrin Military Aviation 12 January 7th 04 03:56 AM
Va: maneuvering speed ad nauseam Koopas Ly Piloting 14 November 29th 03 05:07 PM
