Tow Plane Mirrors.
Old December 31st 15, 06:13 PM posted to rec.aviation.soaring
Tim Taylor
Default Tow Plane Mirrors.
Just thinking outside the box. Why not put an all internal back-up camera system in the plane?
Old December 31st 15, 06:36 PM posted to rec.aviation.soaring
Likely because you're looking at something ~200' away, makes it hard to see from a camera/system designed for ~12' away.
Hmmm..... since you're tapping into the airplane electrical, wonder if that trips a "more paperwork" issue.....
Old January 4th 16, 05:28 PM posted to rec.aviation.soaring
On Monday, December 28, 2015 at 8:40:00 AM UTC-8, Dan Marotta wrote:
Our Pawnee has automotive rearview mirrors attached to the wing
struts and motorcycle mirrors attached to the cross member above the
instrument panel.* Of course the Pawnee has a back window; does your
182?* The mirrors on the struts are pretty much useless since they
have a small field of view, are mounted far away from the pilot, and
are ground adjustable only.* Our Ag Wagon has a remote controlled
(via mechanical cable) automotive mirror mounted to the side of the
fuselage just forward of the door.* It's quite useful.* Maybe you
can get field approval for a mirror mounted just forward of the door
with the control mounted to the panel.* You might need one on each
side of a 182.
On 12/28/2015 8:29 AM,
Hi all,
We have two Cessna 182's towplanes and need a mirror solution.
Does anyone have any suggestions?
Thanks,
Noel
Dan, 5J
Thanks Dan, I think the only way an in-cockpit mirror would work if it was glare-shield mounted. The 182 sits pretty nose forward, being a tricycle gear
Old January 4th 16, 05:29 PM posted to rec.aviation.soaring
On Monday, December 28, 2015 at 10:58:46 AM UTC-8, Tom (2N0) wrote:
Is it just me but I can never see much out of those mirrors. I think that white blur is a glider still attached...
Why not have a camera and monitor just like my SUV has? I am a pro at backing up now that I just look at the TV!
Perhaps with some sort of ipad viewing... zoom would be nice.
Old January 4th 16, 05:31 PM posted to rec.aviation.soaring
On Monday, December 28, 2015 at 5:50:10 PM UTC-8, wrote:
For C182 see - good detail, measurements and pics.
https://missions.capnhq.gov/ops/dot/...rror/index.cfm
Best recolection Achorage AK CAP has the 337.
BTW, with big truck mirrors the tow pilot can actually see way more compared to the popular bullet shape car mirrors on many Pawnees. Barely any difference drag and yaw.
Thanks the latest link is he https://missions.capnhq.gov/ops/dot/...rror/index.cfm
I believe that this bracket has to be fabricated just as in the Air Cadet Glider Cessna 182 towplanes.
I'm in the process of sending them an email.
Old January 4th 16, 05:32 PM posted to rec.aviation.soaring
On Wednesday, December 30, 2015 at 7:53:42 AM UTC-8, wrote:
The CAP link above does include a copy of the FAA field approval for the mirrors shown. This will make approval far easier and I am aware of at least one 182 owner who used this for his approval. Alaska Wing of CAP has three gliders in their fleet.
Happy New Year all--
Skip
Skip, is it true that the brackets were individually fabricated?
Old January 4th 16, 05:35 PM posted to rec.aviation.soaring
On Thursday, December 31, 2015 at 8:00:06 AM UTC-8, Curt Cole wrote:
At 15:04 31 December 2015, Tony wrote:
With the FAA now OK with you strapping go-pros on your plane, as long as
they don't fall off of course, why on earth would you need a 337 to strao
a
mirror to a wing strut?
And with that in mind, here's a link to a sturdy clamp which has been
getting good field reviews, especially among the "off-road" airplane
community--Supercubs and such. It's intended for action cameras but it
looks like it would adapt easily to a mirror:
https://www.cloudbaseengineering.com/product/100-0002/
I have no experience with this product, nor connection to the company. The
other Cessna variant I've seen is using a couple of large gear (hose)
clamps to strap a truck mirror to a C-180 strut over felt padding. Not in
pilot's line-of-sight, but worked sorta OK.
Very interesting, thanks!
Inspection Mirrors RST Engineering Owning 7 January 27th 07 08:09 PM
towplane mirrors Curt Cole Soaring 3 May 28th 04 02:40 PM
PepBoy Mirrors Nyal Williams Soaring 2 March 15th 04 11:36 AM
PepBoy Mirrors Nyal Williams Soaring 0 March 14th 04 04:29 PM
Smoke, mirrors and the GBU - 12 Xenia Dragon Military Aviation 14 September 3rd 03 04:09 AM
