Tow Plane Mirrors.
Old December 28th 15, 03:29 PM posted to rec.aviation.soaring
Default Tow Plane Mirrors.
Hi all,
We have two Cessna 182's towplanes and need a mirror solution.
Does anyone have any suggestions?
Noel
Old December 28th 15, 04:39 PM posted to rec.aviation.soaring
Dan Marotta
Our Pawnee has automotive rearview mirrors attached to the wing struts
and motorcycle mirrors attached to the cross member above the instrument
panel. Of course the Pawnee has a back window; does your 182? The
mirrors on the struts are pretty much useless since they have a small
field of view, are mounted far away from the pilot, and are ground
adjustable only. Our Ag Wagon has a remote controlled (via mechanical
cable) automotive mirror mounted to the side of the fuselage just
forward of the door. It's quite useful. Maybe you can get field
approval for a mirror mounted just forward of the door with the control
mounted to the panel. You might need one on each side of a 182.
On 12/28/2015 8:29 AM, wrote:
Hi all,
Noel
Dan, 5J
Old January 4th 16, 05:28 PM posted to rec.aviation.soaring
struts and motorcycle mirrors attached to the cross member above the
instrument panel.* Of course the Pawnee has a back window; does your
182?* The mirrors on the struts are pretty much useless since they
have a small field of view, are mounted far away from the pilot, and
are ground adjustable only.* Our Ag Wagon has a remote controlled
(via mechanical cable) automotive mirror mounted to the side of the
fuselage just forward of the door.* It's quite useful.* Maybe you
can get field approval for a mirror mounted just forward of the door
with the control mounted to the panel.* You might need one on each
side of a 182.
Hi all,
Noel
Dan, 5J
Thanks Dan, I think the only way an in-cockpit mirror would work if it was glare-shield mounted. The 182 sits pretty nose forward, being a tricycle gear
Old December 28th 15, 06:58 PM posted to rec.aviation.soaring
Tom (2N0)
Is it just me but I can never see much out of those mirrors. I think that white blur is a glider still attached...
Why not have a camera and monitor just like my SUV has? I am a pro at backing up now that I just look at the TV!
Old January 4th 16, 05:29 PM posted to rec.aviation.soaring
Perhaps with some sort of ipad viewing... zoom would be nice.
Old December 29th 15, 01:50 AM posted to rec.aviation.soaring
For C182 see - good detail, measurements and pics.
https://missions.capnhq.gov/ops/dot/...rror/index.cfm
Best recolection Achorage AK CAP has the 337.
BTW, with big truck mirrors the tow pilot can actually see way more compared to the popular bullet shape car mirrors on many Pawnees. Barely any difference drag and yaw.
Old December 30th 15, 12:04 AM posted to rec.aviation.soaring
In one of my former clubs, the Rallye towplane had two internally mounted Starfighter mirrors.
Like the ones in this F-104:
https://www.flickr.com/photos/mark08...pool-cockpits/
Old December 30th 15, 03:01 AM posted to rec.aviation.soaring
Stephen Damon
Is it true that all tow planes in Canada have to have mirrors? Would some of our Canada Brothers and Sisters share info and Pictures Please?
Old December 30th 15, 12:50 PM posted to rec.aviation.soaring
PGS
Nice mirrors, but is the rest of the F-104 available?
Old December 30th 15, 03:53 PM posted to rec.aviation.soaring
The CAP link above does include a copy of the FAA field approval for the mirrors shown. This will make approval far easier and I am aware of at least one 182 owner who used this for his approval. Alaska Wing of CAP has three gliders in their fleet.
Happy New Year all--
Skip
Inspection Mirrors RST Engineering Owning 7 January 27th 07 08:09 PM
towplane mirrors Curt Cole Soaring 3 May 28th 04 02:40 PM
PepBoy Mirrors Nyal Williams Soaring 2 March 15th 04 11:36 AM
PepBoy Mirrors Nyal Williams Soaring 0 March 14th 04 04:29 PM
Smoke, mirrors and the GBU - 12 Xenia Dragon Military Aviation 14 September 3rd 03 04:09 AM
