New Coating
Old March 14th 16, 07:01 PM posted to rec.aviation.soaring
Muttley
Default New Coating
Hi
Guess how long it will be before we all put this stuff on our gliders??
https://youtu.be/IPM8OR6W6WE
No more waxing or Bugwipers!!
Muttley
Old March 14th 16, 08:14 PM posted to rec.aviation.soaring
Matt Herron Jr.
Default New Coating
On Monday, March 14, 2016 at 12:01:03 PM UTC-7, Muttley wrote:
Hi
Muttley
I will coat my underwear with that stuff for low saves!
Old March 14th 16, 10:18 PM posted to rec.aviation.soaring
Giaco
Default New Coating
On Monday, March 14, 2016 at 3:01:03 PM UTC-4, Muttley wrote:
Hi
Muttley
Mind=Blown
The day they sell this in rattle cans will be the day i go bankrupt...
Old March 14th 16, 10:21 PM posted to rec.aviation.soaring
Default New Coating
Hi
Muttley
Soooo..... buy RainEx...... seems to be "the same/similar"......
Yes, it's cool..... but not the 1st (from what I've seen before).
Old March 15th 16, 12:07 AM posted to rec.aviation.soaring
Doug[_7_]
Default New Coating
Hey Muttley, any chance you're the same Muttley from theach C2 forum?
Old March 15th 16, 06:26 AM posted to rec.aviation.soaring
Default New Coating
From the MSDS sheet, ingredients by weight:
acetone: 96 - 98%
silica: 2 - 4%
proprietary additive: 1%
I'll let someone else test the effects of that on their gelcoat for a number of years first...
Old March 15th 16, 10:09 AM posted to rec.aviation.soaring
Muttley
Default New Coating
sorry must be another Muttley!
Old March 15th 16, 12:20 PM posted to rec.aviation.soaring
ND
Default New Coating
i actually was pretty interested in that. imagine ducking through a band of rain and having your wings be dry almost instantly after you exit. i bet the bugs would streak way back though...
Hi
Muttley
Old March 15th 16, 12:36 PM posted to rec.aviation.soaring
Default New Coating
First, I would like to see laminar airflow studies on glider airfoils. There is the assumption this will not affect the laminar flow or increase it. Maybe the opposite.
Old March 15th 16, 01:54 PM posted to rec.aviation.soaring
Default New Coating
acetone: 96 - 98%
silica: 2 - 4%
Sounds like a very good material for removing wax protecting the finish.
UH
removing transparency coating Brad[_2_] Soaring 13 September 22nd 09 02:13 AM
Penalitel anit-corrosion coating Jon Woellhaf Owning 2 June 27th 07 06:11 PM
Coating aluminum Lou Home Built 23 December 24th 05 04:11 AM
How to identify fabric/coating process used? Wallace Berry Home Built 7 October 7th 05 07:14 PM
Suitable coating for spring-steel wire? Wright1902Glider Home Built 6 February 9th 04 04:12 PM
