Flarmnet problems on Flarmview
Old May 2nd 16, 04:23 PM posted to rec.aviation.soaring
Karl Kunz[_2_]
Default Flarmnet problems on Flarmview
Just installed a Flarm Core with a Flarmview2 display. Installed the Flarmnet file after running it thru the converter required by LXNav and not getting IDs. My partner also installed the same file on his Flarmview1 with the same result. Is anyone else having this same problem?
Old May 2nd 16, 06:45 PM posted to rec.aviation.soaring
Tango Eight
What did you name the converted file? IIRC it must be flarm.flx. The converter will happily allow you to give the file other names, which won't work..
best,
Evan Ludeman
Old May 2nd 16, 09:40 PM posted to rec.aviation.soaring
Karl Kunz[_2_]
I noticed in Flarmview-1 manual it is as you stated but in the Flarmview-2 manual it just says -
ï‚· Please visit http://www.flarmnet.org
ï‚· Download file for LXNAV (LX8000, LX8080, LX9000) or click on following link: http://www.flarmnet.org/files/lxfile.php
ï‚· FLN type file will be downloaded.
ï‚· Copy flarm.fln file to SD card of FlarmView2.
It does not mention the conversion program or renaming ???
best,
Evan Ludeman
Old May 2nd 16, 09:51 PM posted to rec.aviation.soaring
Karl Kunz[_2_]
I did try with and without the conversion process (.fln and .flx) but still not working.
best,
Evan Ludeman
Old May 3rd 16, 02:50 AM posted to rec.aviation.soaring
Karl:
Play with changes in the baud rate. I had the same problem and finally getting the correct baud rate on flarmview fixed it. Interestingly, after I did the 2015 software update the same problem came back - and it was fixed the same way.
Roy
Old May 3rd 16, 04:36 PM posted to rec.aviation.soaring
Karl Kunz[_2_]
Thanks Roy I'll give that a try. I had thought of that but given that the rest of the functions worked figured it wasn't the problem.
Karl:
Roy
Old May 3rd 16, 10:37 PM posted to rec.aviation.soaring
Ramy[_2_]
Karl:
Roy
Karl, I suspected earlier there was an issue but last weekend I saw all the tail numbers. I assume you left the micro SD card in, otherwise this will be the reason as I am pretty sure the micro SD card needs to always be in to retain configuration and flarmnet data.
Ramy
Old May 4th 16, 10:59 AM posted to rec.aviation.soaring
Karl Kunz[_2_]
Yes I left the card in and was seeing all the targets but not seeing the tail numbers. The instructions for ins
Karl:
Roy
Ramy
Old May 4th 16, 11:12 AM posted to rec.aviation.soaring
Tango Eight
http://www.lxnav.com/contact.html
best,
Evan
Old May 6th 16, 05:39 PM posted to rec.aviation.soaring
Karl Kunz[_2_]
I did send LXNav a query but got a terse response which only quoted there manual which sucks by any measure. So far not impressed with LXNav. They really need to get a good technical writer with good english skills to write their manuals.
best,
Evan
FlarmView and FlarmNet- will they work together? Matt Herron Jr. Soaring 3 April 11th 15 11:11 PM
New FlarmView Flarm Config Menu? [email protected] Soaring 0 February 27th 14 05:06 PM
LXNAV Flarmview [email protected] Soaring 2 September 29th 13 01:47 AM
PF Portable and Flarmnet Andy[_1_] Soaring 0 October 5th 12 02:55 PM
FlarmNet Brad[_2_] Soaring 6 August 26th 12 06:35 PM
