FlarmView and FlarmNet- will they work together?
Old April 11th 15, 05:22 PM posted to rec.aviation.soaring
Matt Herron Jr.
Default FlarmView and FlarmNet- will they work together?
I have a FlarmView display connected to my PowerFLARM brick. It seems that the FlarmNet database is now encrypted and the version for use with FlarmView is no longer posted. Does anyone know;
1) if FlarmView will ever again be compatible with FlarmNet?
2) where I can get the last unencrypted rev of the FlarmNet database so I can be kind of up to date.
3) If SeeYou on the Oudie can(or will) use the encrypted database?
Or do I have this all wrong?
Matt H
Old April 11th 15, 05:47 PM posted to rec.aviation.soaring
Karl Kunz[_2_]
Matt, the FlarmNet site has a LXNav download but says "for FlarmView a special converter software is required". It does not tell you where the converter software is available that I can see.
http://www.flarmnet.org/index.php/en/downloads
Matt H
Old April 11th 15, 08:31 PM posted to rec.aviation.soaring
The file Converter is built into the Flarmview with the last update.
See this thread.
https://groups.google.com/forum/m/#!...ng/GcdPjHoxsyc
Old April 11th 15, 11:11 PM posted to rec.aviation.soaring
Paul Remde
Hi Matt,
The FlarmNet files for LXNAV work great in the FlarmView and SeeYou Mobile.
They are available now and work great.
The FlarmView requires that the file first be converted to a .flx file. A
..fln to .flx converter is built into the latest FlarmView software. You
just save the .fln file to the microSD memory card and plug it into the
FlarmView. Then go to the menu and files menu and it will be very
intuitive.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
_________________________________
"Matt Herron Jr." wrote in message
Matt H
Display Comparison Ultimate Le 57, V7, LXNAV FlarmView Richard[_9_] Soaring 1 November 23rd 14 02:13 AM
New FlarmView Flarm Config Menu? [email protected] Soaring 0 February 27th 14 05:06 PM
LXNAV Flarmview [email protected] Soaring 2 September 29th 13 01:47 AM
FlarmNet Brad[_2_] Soaring 6 August 26th 12 06:35 PM
