LX9070 Flarm not speaking
Old June 4th 16, 09:34 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Default LX9070 Flarm not speaking
Have a LX9070 and a PowerFlarm brick. The PF is turning on can see the red light when new software was loaded and can see a green light when it is on.. There are connections from Flarm to the LX9070 they appear solid, but when I go to the setup page on the LX9070, Hardware then Flarm all I see is a baud rate of 19200 and Ext.(PC). The Freq (should be North America, is blank) serial number and Version are blank. I did have another pilot say my Flarm was working as he got a Flarm warning, but I am not sure it was the Flarm or the transponder setting off his Flarm. I receive no data of the LX9070.
Does anyone know if there are other settings that would keep the Flarm from showing on the LX9070. As stated above all the indications are the Flarm is powering on.
Any help would be appreciated.
Kind regards,
Jon
Old June 5th 16, 01:00 PM posted to rec.aviation.soaring
Andrzej Kobus
On Saturday, June 4, 2016 at 4:34:54 PM UTC-4, Jonathan St. Cloud wrote:
Have a LX9070 and a PowerFlarm brick. The PF is turning on can see the red light when new software was loaded and can see a green light when it is on. There are connections from Flarm to the LX9070 they appear solid, but when I go to the setup page on the LX9070, Hardware then Flarm all I see is a baud rate of 19200 and Ext.(PC). The Freq (should be North America, is blank) serial number and Version are blank. I did have another pilot say my Flarm was working as he got a Flarm warning, but I am not sure it was the Flarm or the transponder setting off his Flarm. I receive no data of the LX9070.
Kind regards,
Jon
Most likely your baud rate specified for the PF port is different than the rate specified in the LX. Put a USB stick in the PF and PF will write the boot sequence into the log on USB. Then open that file in a notepad and see what is your baud rate setting for that port. Enter that baud rate in LX and you should be fine.
Old June 5th 16, 07:53 PM posted to rec.aviation.soaring
Dave Springford
Jon,
The flarm needs to be configured to send data out via either (or both) of the RJ or DB9 port. This is done in the flarm config file
Assuming you are using the standard LX-PFcore connection cable connecting to the flarm DB9 port, then put this code in the config file. It's what works with my core and 9000.
# configure D-SUB 9 port
$PFLAC,S,NMEAOUT2,63
If using the RJ port then use:
# configure PF core RJ-45 / PF portable port
#$PFLAC,S,NMEAOUT1,63
#$PFLAC,S,BAUD1,2
Dave Springford
www.foxonecorp.com
LX9070 settings Jonathan St. Cloud Soaring 1 May 18th 16 06:24 AM
Lx9070 V80 and Butterfly electronic and pnuemantic compensation Jonathan St. Cloud Soaring 2 May 5th 16 06:47 PM
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 3 April 10th 16 04:13 AM
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 0 April 8th 16 08:57 PM
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm [email protected] Soaring 28 March 12th 16 04:31 AM
