LX9070 settings
Old May 17th 16, 03:04 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Default LX9070 settings
I have a LX9070 and noticed that when I chose the glider ASG-29E polar, the wing area is listed as 34 sqft and wing loading 2.2 lb/sqft. When I adjust the proper wing area save it and go back to check the data it has reverted to 34 sqft wing area. These should be per-programed polar data. How do I get the correct input?
Thank you
Old May 18th 16, 06:24 AM posted to rec.aviation.soaring
Surge
Thank you
Have you asked LXNav for assistance?
They usually respond within a day or two.
This is a real stab in the dark but did you try renaming the glider?
Maybe the code keeps loading the default pre-loaded polar for your glider because the names match and by changing the glider name to something else it will save your settings to a different internal "glider profile"?
LX-Nav S80 settings Mark628CA Soaring 11 July 8th 16 08:11 AM
Lx9070 V80 and Butterfly electronic and pnuemantic compensation Jonathan St. Cloud Soaring 2 May 5th 16 06:47 PM
Nav radio settings in FMC Mxsmanic Piloting 5 January 10th 07 08:39 PM
ATC Altimeter Settings O. Sami Saydjari Instrument Flight Rules 81 April 11th 05 08:07 PM
L-nav Settings Ventus 2ct-18 Oliver Peters Soaring 4 July 18th 03 04:14 AM
