Cobra Trailer Tow Chain Attach Points
Old July 9th 16, 05:39 PM posted to rec.aviation.soaring
jfitch
Default Cobra Trailer Tow Chain Attach Points
On Saturday, July 9, 2016 at 7:38:36 AM UTC-7, Craig Reinholt wrote:
State safety chain requirements differ. Here is a summary by state.
http://www.expediter.com/natm%20pdf%...Laws-Table.pdf
When in doubt, go to your state DOT website and see what is required.
That suggests that if you license your trailer in the right state, you don't need chains.
In California, you need chains and they must be short enough to keep the tongue off the ground.
Old July 10th 16, 04:20 AM posted to rec.aviation.soaring
AS
Thanks for that link! I had no idea that there was such a bewildering variety of regulations.
So what is one to do while on a trip from one state that has hardly any requirements through one that requires QE2 style anchor chains? Could one get cited for violating that state's laws?
Uli
AS
Old July 10th 16, 03:06 PM posted to rec.aviation.soaring
Dan Marotta
My guess is that, as long as you're compliant with the laws of the state
in which the trailer is registered, you'll be OK just passing through or
visiting. Too bad it's not the same for speed limits (think California
where you have to drop 20 mph when towing a trailer). But I never
played a lawyer on TV, either.
Uli
AS
Dan, 5J
Old July 11th 16, 02:18 PM posted to rec.aviation.soaring
Oscar-Hotel-Mike
Thanks for all the comments but I don't think that my initial question was answered.
To paraphrase - What part of a Cobra trailer should the chains be attached to? Where are your chains attached?
Thanks, John
Old July 11th 16, 02:39 PM posted to rec.aviation.soaring
K m
Thanks, John
OHM,
I have (And just restored) a 1999 Cobra and the chain attach point coincides with your picture. If you have further questions contact Alfred Spindleburger at Cobra. He has been helpful throughout my restoration. If you contact him early in the day (US) he will still be in the office (In Germany) and usually will get right back to you.
Old July 11th 16, 02:41 PM posted to rec.aviation.soaring
K m
Thanks, John
OHM,
I meant to write , If you email him early in the day he will get right back to you.
Old July 11th 16, 06:27 PM posted to rec.aviation.soaring
Based on experience, if the trailer tongue/drawbar snaps where it enters the trailer (stress concentration), the brake actuator rod does a fine job of keeping the trailer behind the tow vehicle, although the trailer swings pretty wildly back and forth.
If the front mounting point of the tongue fails, the rear mounting mount can remain attached but the front of the trailer settles onto, yes, the brake actuator rod. In this case, everything looks normal (except the trailer is riding a bit tail high) until the smoke starts pouring off the wheels from the brakes being full on.
All of this assumes the coupler is still attached to the ball, of course. A break or disconnect at that point (or if the trailer hitch itself fails--I have some experience with that, too) makes you glad you used chains.
Chip Bearden
ASW 24 "JB"
New Cobra trailer - - which top? Ben[_6_] Soaring 34 February 19th 15 09:43 PM
2013 Cobra trailer price list needed for TA trailer sale [email protected] Soaring 0 June 22nd 13 02:42 PM
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! flyingmr2 Soaring 4 November 16th 10 02:11 AM
COBRA TRAILER Gordon Schubert[_2_] Soaring 0 February 10th 09 04:15 AM
Cobra Trailer Soaring 1 September 28th 03 01:14 PM
