Cobra Trailer Tow Chain Attach Points
Old July 8th 16, 04:13 PM posted to rec.aviation.soaring
Oscar-Hotel-Mike
Default Cobra Trailer Tow Chain Attach Points
I just purchased a glider housed in a 2002 Cobra trailer. It came with only one chain (I always use two crossed chains) and the chain is attached to one of the bolts that connects the tongue to the trailer (big honking steel U strap over the tongue inside the trailer). According to the owner this was installed at the Cobra factory.
Here is a picture of the chain's external attachment points. Note that I upgraded to grade 10 bolts replacing the original Cobra bolts.
https://dl.dropboxusercontent.com/u/...r%20Chains.jpg
The question is, is this a good/best attachment point for chains? It would seem that a sharp jolt puts a high lateral force on the bolt at the weakest "threaded portion". I also saw this same setup in the linked picture at https://groups.google.com/forum/#!ms...8/FKmbkTjMBAAJ.
I see other Cobra owners with chains attached via a shackle to the V shaped bracket holding the jockey wheel/post. While this is a beefy bracket, is that a good place? Is another chain location even better?
PS - Is is true that Europeans don't even use chains? Seems just CRAZY to me as you would have a deadly unguided missile if it were to come off the ball.
Thanks, John
Old July 8th 16, 04:34 PM posted to rec.aviation.soaring
JS
Thanks, John
Believe it's not that chains are not used, but they are not legal in Europe..
Nor is a crude 4-wire electrical system sharing brake and turn lights.
All Euro trailers have brakes. American regulations were created for trailers without brakes. Now that is crazy!
That attach point is good, if the bolts are tight and not rusty. It will distribute the load to the same place as in normal use.
Old July 8th 16, 04:43 PM posted to rec.aviation.soaring
Thanks, John
I use 2 chains bolted to the primary structure independent of tongue mounting with the solid portion of the 1/2 inch bolt going through the chain and the lock nut on the inside.
FWIW
UH
Old July 8th 16, 05:30 PM posted to rec.aviation.soaring
Thanks, John
FWIW
UH
In the UK braked (i.e. pretty much all) trailers and caravans must have a break away cable that applies the hand brake if the trailer coupling comes off the ball. The cable is attached to a point on the towbar by a clip that is strong enough to apply the hand brake but weak enough to brake away allowing the vehicle and trailer to separate and leaving the trailer to stop on its own.
I wouldn't fancy being followed by an uncoupled unbraked trailer attached by a strong chain
Old July 8th 16, 05:32 PM posted to rec.aviation.soaring
Thanks, John
FWIW
UH
In the UK braked (i.e. pretty much all) trailers and caravans must have a break away cable that applies the hand brake if the trailer coupling comes off the ball. The cable is attached to a point on the towbar by a clip that is strong enough to apply the hand brake but weak enough to break away allowing the vehicle and trailer to separate and leaving the trailer to stop on its own.
Old July 8th 16, 07:03 PM posted to rec.aviation.soaring
Casey[_2_]
I think this is matter of opinion. And my opinion is based on trailer actually coming off ball and the chains allowing the trailer tongue to rest on chains. In my case, applying the brake had trailer tongue going under the hitch and the trailer hitting the back bumper. This was not a glider trailer but a utility trailer. Light weight trailers are not required to have a brake but are required to have safety chains. Redundancy is always better in my opinion and I would rather for chains to keep tongue from catching and catapulting or piercing something as first safety than have a braking system to take effect if the chains fail. I would think chains failing would be a less likelihood than a braking system failing. Chains have very little maintenance while the small cable, braking system, and actual brakes are a little more complex and require all to work properly.
Old July 9th 16, 02:39 AM posted to rec.aviation.soaring
Dave Springford
Of course, another point of interest is that the speed limit when towing a trailer in Germany is 80 km/hr (50 mph) (even on the autobahn), unless you meet more stringent specifications in which case the car and trailer must have 100 km/hr (60 mph) decals affixed and then 100 km/hr is allowed.
As well as the slower towing speeds than the 70-80 mph most people seem to fly along at in North America, the Europeans are also towing with much smaller cars than the typical Yukon, F-150 that most use here.
Having a trailer chained to your Ford Focus could get rather exciting if the ball attachment comes loose at 60 mph!
Old July 9th 16, 06:21 AM posted to rec.aviation.soaring
Thanks, John
My understanding of the U.S. use of chains is to keep the trailer somewhat inline behind the towing vehicle in the event of a separation from correct connection between the trailer and the tow vehicle. I was indirectly involved with a 30' fishing boat/trailer equipped with a 2" hitch being incorrectly hooked to a 1-7/8" ball on the truck, resulting in a decoupling on the 405 freeway near LAX some decades ago. The tally was one Sigalert and a very beat up tailgate on the pickup truck, but no other vehicles involved, because the trailer stayed behind the truck. With two, 150 hp Yamaha outboards on the back of the boat, pitch-pole prevention was not a concern, and really isn't with any other trailer size/type. Have been out of the boat biz for a long time, but I don't recall any trailers from the major manufacturers who rigged trailers with chains so short as to keep the trailer tongue from touching the ground in the event of an uncommanded uncoupling. In an uncoupling, the chains are for safety to other vehicles, your tow vehicle is a sacrificial anode.
Old July 9th 16, 12:30 PM posted to rec.aviation.soaring
Casey[_2_]
I don't know if it is written anywhere but just from my general up bringing towing horse trailers, utility trailers, campers, and boats, we always crossed the chains. In the event of trailer separating from hitch, the crossed chains allowed the trailer tongue to rest on the chains. The case of the utility trailer coming uncoupled from the ball was when I borrowed a utility trailer and it did not have a safety pin. I was only using in my neighborhood so the first time in all my towing I did not use a safety pin. The road was rough, the safety latched popped up and then the coupler popped off the ball. It probably is not needed to cross the chains and may have started when chains were too long. But the brake-away brake is sure to help with pitch polling. A disconnected trailing traveling down the road by itself could easily have the coupler dig into the side of the road and kinetic energy allow the trailer to pitch pole. And I can see now why chains are not required and brake-away brakes are for the UK, since they use smaller vehicles.
I've seen many accidents involving trailers along interstates and my speculation is probably due to loss of control by swaying. I have pulled trailers to their limit until they swayed and its no fun. At least I knew at what speed to stay well below until the swaying would start. Some trailers sway at a much slower speed than others due to heavy in the rear, not enough tongue weight, or improper placement of axle. I am very pleased with my 1975 Pfeiffer trailer and the way it pulls. It does pull even better now with a little more weight in the front when I added a spare tire and small tool box.
Old July 9th 16, 03:38 PM posted to rec.aviation.soaring
Craig Reinholt
State safety chain requirements differ. Here is a summary by state.
http://www.expediter.com/natm%20pdf%...Laws-Table.pdf
When in doubt, go to your state DOT website and see what is required.
New Cobra trailer - - which top? Ben[_6_] Soaring 34 February 19th 15 09:43 PM
2013 Cobra trailer price list needed for TA trailer sale [email protected] Soaring 0 June 22nd 13 02:42 PM
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! flyingmr2 Soaring 4 November 16th 10 02:11 AM
COBRA TRAILER Gordon Schubert[_2_] Soaring 0 February 10th 09 04:15 AM
Cobra Trailer Soaring 1 September 28th 03 01:14 PM
