So for race tasking it is a bad idea to call a task that has pilots do an out and return, 180° U-turn and turn back into oncoming traffic.
So a 0° angle between incoming and outgoing traffic certainly is bad. What angle is sufficient to be relatively safe, 30, 40, 60? And does this vary with the size of the turnpoint, 1 mile, 5 mile, 15 mile? I think to make this easier to task for a CD this way it would help to have a lot bigger turnpoint list than the typical 30 points. With more points you can add steering points that create a safe turn without adding more distance than you want. Chris |
I agree with Don. I prefer to keep all turns at least 60 degrees. 45 should be the absolute minimum and should only be used as a last resort. The bigger the turn area the greater the angle should be. The scariest I have ever flown was a big ring at Uvalde with a cloudstreet that bisected the turn area. Everyone lined up on the street and flew it in and out. Nothing like 45 gliders at cloudbase at 110 knots flying out and back on one street. This was pre-Flarm and I was afraid to pull up because of the loss of forward visibility. The midair at Uvalde was event that really made most tasking committees realize that nearly 180 degree (0 degree) turns must be avoided.
| Flaps 40 Degrees | Ken Kose | General Aviation | 3 | February 14th 09 02:10 AM |
| VOR off by 30 degrees | EK | Owning | 5 | July 11th 08 07:51 PM |
| Angles | Maple1 | Aviation Photos | 2 | August 22nd 07 08:16 PM |
| Flap angles | DeltaDeltaDelta | Piloting | 34 | May 18th 04 01:09 AM |
| Best Software and Hardware for Turn Area Task? | Snead1 | Soaring | 29 | August 13th 03 05:12 PM |
