VOR off by 30 degrees
Old July 8th 08, 06:22 AM posted to rec.aviation.owning
EK
Default VOR off by 30 degrees
If the VOR is off by 30 degrees, is the adjustment in the indicator or the
radio?
Old July 8th 08, 07:26 AM posted to rec.aviation.owning
Alan[_6_]
In article m "EK" writes:
radio?
It depends on the radio and indicator. Some do decoding and
adjustment in the indicator, some in the radio.
One of those little details that an avionics show owner warned
me about -- and why some radios would not work with the display
indicators I had, while others would.
Alan
Old July 8th 08, 02:21 PM posted to rec.aviation.owning
EK
Thanks, Alan:
KX-170 was replaced with MX-170B. Glideslope Indicator is KI-208.
_______________EK.
An eye for eye only ends up making the whole world blind.~ M.K. Gandhi.
"Alan" wrote in message
In article m "EK"
writes:
radio?
Alan
Old July 10th 08, 11:38 PM posted to rec.aviation.owning
Robert M. Gary
On Jul 8, 6:21*am, "EK" wrote:
Thanks, Alan:
_______________EK.
If you take the knob off there is a spline screw behind it that you
can adjust it with. If its an old head it may just go right back to
being off 30 degrees on the next flight though. Those heads are older
than many pilots on the airport.
-Robert
Old July 11th 08, 01:46 AM posted to rec.aviation.owning
Blueskies
On Jul 8, 6:21 am, "EK" wrote:
Thanks, Alan:
_______________EK.
-Robert
How to you pull the VOR head from the panel? I have one with a broken 'rubber band' so I cannot adjust the OBS...its a
KI???
Old July 11th 08, 06:51 PM posted to rec.aviation.owning
Robert M. Gary
KI???
The head just screws into the panel and drops down behind it.
Depending on what you have installed you may have to remove other
stuff to get it out (I have a Mooney so any removal requires lots of
moving stuff around). I'm not sure if you can get a new band for it
though. The old King heads that are driven by the KX-170B/MX-170B/etc
don't have any new parts made. You may find someone who bought a bunch
when they stopped making them but those guys are running out quick.
Its not unusual to have to dump those heads because you can't find a
part. Usually your best bet is to buy a dead one on eBay and get parts
off it.
-Robert
Six Degrees of Separation ON Topic Errol Groff Home Built 1 August 25th 06 04:36 PM
F-14 approach AoA, is it really 15 degrees? sttp Naval Aviation 14 June 29th 06 12:33 AM
50 degrees rich of peak lardsoup Piloting 16 June 28th 05 08:42 AM
How can a compass suddenly go out by 20 degrees? Bob Chilcoat Owning 25 February 21st 04 10:58 PM
Precession of 10 degrees in 10 minutes too much? Jay Moreland Instrument Flight Rules 11 August 15th 03 01:05 AM
