Can you assume wings weight is max T/O weight - max non lifting parts ?
I am trying to find the wing weight for my ventus C Dan |
On Wednesday, December 28, 2016 at 6:56:22 PM UTC-8, wrote:
Can you assume wings weight is max T/O weight - max non lifting parts ? I am trying to find the wing weight for my ventus C Dan There may be too many variables for that formula. Try a set of scales? Jim |
On Wednesday, December 28, 2016 at 8:56:22 PM UTC-6, wrote:
Can you assume wings weight is max T/O weight - max non lifting parts ? I am trying to find the wing weight for my ventus C Dan When I weighed my std Cirrus, I also weighed just the fuselage and stabilator, being Very Careful not to let it fall over. I could do some math and get just the wing weight from that. 'nonlifting' Parts weight was more helpful to me. Scott |
On Wednesday, December 28, 2016 at 9:56:22 PM UTC-5, wrote:
Can you assume wings weight is max T/O weight - max non lifting parts ? I am trying to find the wing weight for my ventus C Dan No. Try the math and see. You'll be off by 2x (water ballast). You can measure wing weight with two bathroom scales and get close. Evan |
To find weight of wings - subtract weigh of Non lifting parts (NLP) from
empty weight of glider, both of which you should have from the last weighing schedule. Paul At 02:56 29 December 2016, wrote: Can you assume wings weight is max T/O weight - max non lifting parts ? I am trying to find the wing weight for my ventus C Dan |
On Wed, 28 Dec 2016 18:56:20 -0800 (PST),
wrote: Can you assume wings weight is max T/O weight - max non lifting parts ? I am trying to find the wing weight for my ventus C Dan Do you have the original paperwork delieved with your ship? My factory Weight and Balance sheet shows 62.7 kg for the right wing and 62.9 kg for the left wing (138.2 lbs / 138.7 lbs). This for Ventus cT SN 95 (SN 346 C model)/ Bob |
Fiberglass cloth weight vs 'finished' weight | Fred the Red Shirt | Home Built | 12 | April 5th 08 04:24 PM |
Glider Weight/Wing Loading and determing speed for best L/D for a given weight | 65E | Soaring | 3 | January 26th 06 09:26 PM |
lifting off... | Richard Lamb | Home Built | 0 | May 17th 04 05:57 AM |
Empty/Gross weight Vs. Max. Pilot weight | Flyhighdave | Soaring | 13 | January 14th 04 04:20 AM |
Weight of snow on wings | Michael Horowitz | Home Built | 10 | January 4th 04 10:58 PM |
