airworthiness certificate
Old February 5th 17, 02:01 AM posted to rec.aviation.soaring
Del Jensen
Default airworthiness certificate
I am shopping for a glider. Today I looked at a 304 That is in very good shape, current on its annual. The type is experimental. The certificate in the cockpit stipulates that the glider is to be operated from a single airfield. Is this normal? Will faa hassle me were I to purchase and register it and wish to fly out of a different field? Do airworthiness certificates typically specify that an aircraft only fly out of one location?
Many thanks for any enlightenment.
Old February 5th 17, 02:24 AM posted to rec.aviation.soaring
Dan Marotta
You'll need to submit a Program Letter to your local FSDO. This letter
will describe the ship, list its home field (your base of operations),
the types of flights planned, i.e., "fly at the Seniors Competition", 30
practice flights of 4 hours duration to maintain currency, etc. You can
work out with your FSDO representative what is required in your letter.
You'll have to submit a new letter each year. It's not a big deal.
Send me your email address and I'll send you a copy of letter which
worked for my experimental glider.
Dan
Dan, 5J
Old February 5th 17, 02:34 AM posted to rec.aviation.soaring
Dan Marotta
No need to send your email - I emailed you a copy of a previous Program
Letter to update to your needs should you buy the glider.
letter will describe the ship, list its home field (your base of
operations), the types of flights planned, i.e., "fly at the Seniors
Competition", 30 practice flights of 4 hours duration to maintain
currency, etc. You can work out with your FSDO representative what is
required in your letter. You'll have to submit a new letter each
Dan
Dan, 5J
Old February 5th 17, 04:17 AM posted to rec.aviation.soaring
Del Jensen
Many thanks Dan. I was little bit concerned over whether I could take the glider somewhere on an occasional basis (e.g., Parowan). You've set my mind at ease.
Del
Old February 5th 17, 05:01 AM posted to rec.aviation.soaring
Del
I am pretty sure a program letter won't override any limitations in the airworthiness certificate. You need a new airworthiness certificate. But I could be wrong . . .
Old February 5th 17, 02:21 PM posted to rec.aviation.soaring
Assuming it is licensed Experimental- Exhibition and Air Racing you should be able to get your local FSDO to provide new operating limitations that conform to the latest standards. Operating limitations are a prt of the airworthiness certificate. Current standards allow for operating at sites other than home base as long as they are on your annual program letter.
UH
Old February 5th 17, 03:38 PM posted to rec.aviation.soaring
Dan Marotta
Glad to have been of assistance.
Del
Dan, 5J
Old February 7th 17, 01:26 AM posted to rec.aviation.soaring
Del
You are right that the program letter does not override limitations in the AW certificate and associated docs.
Whether a new AW certificate is needed depends on what the old one says.
If it is very old you may not have to do a program letter and can fly most anywhere. After the California jet fighter crash the Feds tightened up a lot.
Old February 8th 17, 01:05 AM posted to rec.aviation.soaring
Del Jensen
Thanks for the heads up on that. Do you know of a link or reference to the guide document?
Del
Old February 8th 17, 01:52 AM posted to rec.aviation.soaring
Casey[_2_]
A specific place is required for phase one testing.
FAA Revoking Standard Airworthiness Certificate DG-505 NG Soaring 32 February 16th 17 02:23 PM
Export certificate of airworthiness Greg Arnold[_2_] Soaring 2 December 27th 10 06:10 AM
Airworthiness Certificate Replacement? [email protected] Soaring 6 June 26th 08 07:11 PM
USA Glider Experimental Airworthiness Certificate charlie foxtrot Soaring 4 April 15th 06 05:04 AM
Exhibition/Racing Airworthiness Certificate Question bsquared Soaring 5 June 22nd 04 06:24 PM
