Gap seals effectiveness study?
Old June 12th 17, 06:38 AM posted to rec.aviation.soaring
Bret Hess
Default Gap seals effectiveness study?
Hi, we see lots of mylar gap seals and read lots of discussion of them. Does anyone know of an engineering study that quantifies their effect on sailplane wings or other wings? Nothing pops up quickly in Google. I'm wondering how much science there is to this practice.
I'm hoping for more than anecdotal comments. Saying that top racers all use them doesn't tell us much because so do almost everyone.
Old June 12th 17, 12:07 PM posted to rec.aviation.soaring
To put things simple (may be too simple): think how the wing works, lower pressure on the upper surface than on the below surface, if you open a hole the air pass-by
Carlo
Old June 12th 17, 01:54 PM posted to rec.aviation.soaring
Juliet11[_2_]
Look up any of Richard Johnson's flight tests before and after seals, especially the LS-4. Or any other modern sailplane. There was as much as a 5 point difference.
Old June 12th 17, 03:33 PM posted to rec.aviation.soaring
Tango Whisky
Le lundi 12 juin 2017 07:38:22 UTC+2, Bret Hess a écritÂ*:
There is quite a number of gliders which require the seals in place to be airworthy.
Apart from the obvious loss of performance without seals, the air flow escaping through this area might induce flutter (which in turn will induce a loss of performance of 100%).
Bert "TW"
Old June 12th 17, 06:46 PM posted to rec.aviation.soaring
Thanks. I read the two LS-4 articles, but the "after" wasn't conclusive: Different plane, different probe positions, and Dick doesn't make much of a conclusion on if the performance was better, or just measured to be better.
Is there another one where he does the same plane with the only difference the mylar seals?
Old June 12th 17, 06:51 PM posted to rec.aviation.soaring
The air flow escaping through this area might induce flutter (which in turn will induce a loss of performance of 100%).
Bert "TW"
Are you talking about the exterior mylar seals or the fabric "S" seals in the joint? Once the fabric seals are in place I don't think air escaping is the real issue, more of turbulence due to the dip in the sahpe, but I suppose that could aid flutter.
Old June 12th 17, 08:09 PM posted to rec.aviation.soaring
A lot depends on the airfoil and condition of surfaces. For a 1-26 that needs paint, not much difference. On a modern airfoil with 90-95% laminar flow, it makes a bigger difference.
Most really need the internal seals, then various amounts of need for external Mylar seals.
Keep in mind, I don't think they EVER hurt performance.
Old June 12th 17, 10:29 PM posted to rec.aviation.soaring
If there is an effect on performance or handling, this will be different from glider to glider. It may do nothing, improve performance or even be needed to prevent flutter. There were a lot of quantitative studies done for various gliders, especially the newer ones. For which type do you need this information?
Old June 13th 17, 01:03 AM posted to rec.aviation.soaring
Disagree, a properly sealed 1-26 has almost 5 mph slower stall, and a crisper roll than one that is not sealed.
Kevin
92, formerly 192
Old June 13th 17, 05:55 AM posted to rec.aviation.soaring
Bret Hess
Bert "TW"
I see now that some gliders don't have seals internal to the joint, and depend only on these exterior seals, so you're right about the flutter problem.
Measuring the effectiveness of a sandblaster? Michael Horowitz Home Built 17 June 14th 09 12:50 PM
Instructor Effectiveness Ol Shy & Bashful Piloting 43 September 21st 08 03:20 PM
Ground effect effectiveness Tony General Aviation 14 January 10th 07 11:17 PM
Ground effect effectiveness Tony Piloting 20 January 10th 07 11:17 PM
Effectiveness/clarity of throat mic? Gary G General Aviation 1 October 11th 05 01:44 AM
