F4U inverted gull wings
Old July 8th 04, 12:54 AM
hobo
no useful info wrote:
Considering the few inches of ground clearance any of those props
provided, does anyone have a good idea of how often the propeller was
damaged by (bad) landings?
I would speculate that after the first negative result the props ground
clearance would increase by several inches.
  #43
Old July 8th 04, 04:39 PM
no useful info
In article , hobo
no doubt, the question is, how frequently did this first negative result
happen.
  #44
Old July 10th 04, 04:26 PM
Peter Stickney
(Tracy White) writes:
I'm not sure if it is the answer - but fitting gull wings (whether
inverted or not) means that the wing root joins the fuselage at approx
90 deg - therebye eliminating the need for a large, drag-producing
wing-to-fuselage fillet.
Uhhh no. The fillets were there to DECREASE drag.
That's only true up to a point - A wing/fuselage joint that isn't at
right angles produces quite a bit of Interference Drag, as the
differing airflows try to sort themselves out. Filleting can ease
that transition.
You only need fillets on high or low-winged a/c
Fillets are used to smooth out airflow and thus decrease drag. The air
over a wing is moving at a higher velocity than the air over the
fuselage, and when the streams mix you get turbulence and drag. The
fillets work to counteract this interaction and the drag it causes.
True as far as it goes, but fillets also add wetted area, and increase
Parasite Drag. They're only drag reduction tools when they are
required, and only if used in moderation. It's all a balancing act,
after all - the designer is balancing out the drag increase casued by
the fillet itself, vs. the reduction in interference drag. The
decision made with the Corsair was to reduce the Interference Drag by
acheiving, as much as possible, a wing-fuselage joint perpendicular to
the fuselage, (The inverted gull wing) with a minimum of filleting,
thus reducing Parasite Drag.
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
  #45
Old July 11th 04, 04:56 AM
DJFawcett26
The
Actually, the major driver for the inverted gull was finding a way to make
clearance for the HUGE prop so runways and carrier decks didn't get chopped up.
All the drag reduction trades and benefits were a natural fall out of the
design.
Keep in mind, the wings could have been put have been put at the 90 and 270
position and achieved the same benefit. But the prop would have went chop,
chop. Also, the inverted gull was not the best actor in stability and control.
I am not saying that ultimately it was not good, but even then the spins and
the recoveries were an occurence to behold.
  #46
Old July 11th 04, 03:14 PM
Steven P. McNicoll
"DJFawcett26" wrote in message
chopped up.
design.
270
chop,
chop.
The F6F had the same engine and similar propeller but didn't go chop chop
without the inverted gull wing.
  #47
Old July 11th 04, 06:03 PM
Peter Stickney
(DJFawcett26) writes:
The
Sorry, but the evidence points in the other direction. There was
nothing particularly outstanfing wrt teh Corsair's propeller diamter -
13'1" for the 3-blade prop, and 13'2" for teh 4-blade - the F6F
Hellcat - no inverted gull wing - low mid-wing, in fact, had no
problems operating in the same environment. - in fact, around the
boat, it was a much better airplane than the Corsair.
The Vought TBU Seawolf, intended to be the successor of the TBF/TBM
Torpedo Bomber, had a mid-wing, and a 13'3" diameter prop.
The low-winged Martin AM-1 attack airplane had a 14'8" diameter
propeller.
The mid-wing P-47 had a 13'2" prop. (And in fact, was flown off of,
but not landed on, carriers in the Pacific, during several of teh
Island-hopping invasions.)
The low-wing Hawker Typhoon & Tempest had a 14' diameter propeller.
The fact is, given the expected speed range of the airplanes, and the
propeller RPM (_Not_ Engine RPM - these are geared engines, all with
a of between 1200 - 1500, a 13' propeller diameter gives the best
advance ratio range for efficiency.
As demonstrated by the small selection of examples above, it was
certainly possible to design an airplane to fit the Corsair's
requirements without resorting to in inverted gull wing to make it
work.
design.
And in fact, it was, on larger aircraft (The TBU, which, interestingly
emough, was the Vought project that followed the Corsair), without any
problems. Stbility wasn't a problem for the Corsair - the objective
numbers Cnalpa, Cnbeta - the Stability deriviatices show that it was
in the middle range for contemprary fighters. Teh stall behavior was
worse than that of the Wildcat & Hellcat, but better than the SBD
Dauntless, the Fw 190, or the P-51. Much of the of Corsair's Torque
Roll tencency at low speeds was corrected by a cuff on the leading
edge of the inboard right wing.
From contemporary reports, and objectively obtained data by the NACA,
not any more so than otehr WW 2 fighters, and much less than some.
(You do _not_ want to spin a P-51 with a full fuselage tank, for
example, or a Spitfire with the drop tank in place.)
Pete Stickney
  #48
Old July 11th 04, 07:46 PM
DJFawcett26
I understand exactly what you are saying, the evidence is somewhat in support.
But this is not an issue of evidence, it is an issue of knowing several of the
guys that were on the test program. Witnesses are far better than
circumstantial evidence. Also, you have to take into account the geometry of
the aircraft you specify. There is a significant difference in configuration.
Just remember, what appears obvious may not at all be the obvious.
  #49
Old July 11th 04, 07:47 PM
DJFawcett26
Look at the geometry, that in itself is the telling tale.
  #50
Old July 12th 04, 03:42 PM
ANDREW ROBERT BREEN
The
It's a story which has been around a long time, though - pretty much
as long as the Corsair itself. Norman Hanson was given that as the
reason for the "bent-wing" when he visited Voights in 1943 prior
to picking up the RN's first back of Corsair Is*, so someone at the
factory obviously thought that was the reason. It's possible that the
bent wing was needed to get the big prop. /and/ some other bit of
configuration that Voights thought desirable (which Grumman didn't
adopt for the Gannet/Hellcat or Hawker for the Tiffie).
* source is originally direct - Hans was a family friend - but is
included in his (regrettably out of press) book, "Carrier Pilot".
Andy Breen ~ Interplanetary Scintillation Research Group
http://users.aber.ac.uk/azb/
"Time has stopped, says the Black Lion clock
and eternity has begun" (Dylan Thomas)
All I Wanted For Christmas Were Inverted Spins [email protected] Aerobatics 3 December 29th 04 07:40 PM
VP-II wings available in Oregon, USA (Or, "How I was coconuted...") Roberto Waltman Home Built 2 October 29th 04 04:21 PM
inverted spin recovery explanation Alan Wood Aerobatics 18 August 19th 04 03:32 PM
Double covering fabric covered wings [email protected] Home Built 9 May 9th 04 08:39 PM
Crooked or Wavy Trailing Edges of Wings and Control Surfaces Larry Smith Home Built 3 October 24th 03 02:31 AM
