F4U inverted gull wings
Old July 12th 04, 09:23 PM
ANDREW ROBERT BREEN
hobo wrote:
(ANDREW ROBERT BREEN) wrote:
It's a story which has been around a long time, though
I read something about the Corsair having the first fully retracted and
enclosed landing gear in order to reduce drag. The same article said the
Maybe for Voight.. but plenty of aeroplanes had fully retracting 'carts
long long before. I'd guess the first would probabllt have been the
I-16, kicking on fofr a good 10 years before, but even such latecomers
as Hawker's Hurricane and Willi Messerschmidt's Bf109 had fully-retracting
undercarriages in 1934-ish.
Given that Voight were a clearly competant outfit - the Corsair being one
of the best aerial weapons* of WW2 - I doubt if they'd missed this one.
shorter gear resulting from the gull wing was necessary for the gear to
fully retract. The article said that if long gear was retracted sideways
it would reach into outer parts of the wing that were too narrow and if
Hmm. Not sure about that. Grumman managed the dame tricj with a deeper
fuselage. Hawker offered a navalised Typhoon at one point (a lovely
thought, given the rep. of the early Sabres , so they obviously figured
that it was possible to combine a 14' prop and folding wings without
bending the latter (come to that, what was the diameter of the prop on the
Sea Fury?).
My suspicion is that the truth lies in the rather slim fuselage of the
Corsair, plus a degree of (laudable) coservatism on Voight's behalf
- the blow-down gear for the undercart must have eaten into wing depth,
but it undoubtedly saved lives. OTOH the original hood design was /not/
a good one, nor was the undercart valveing..
*Weapon as distinct from aeroplane. Hans was always insistent on that
point. The Gladiator and the Fulmar were aeroplanes. The Corsair was a
weapon. The Tiger Moth was an abomination.
Andy Breen ~ Interplanetary Scintillation Research Group
http://users.aber.ac.uk/azb/
"Who dies with the most toys wins" (Gary Barnes)
  #53
Old July 16th 04, 02:11 PM
On Sun, 4 Jul 2004 21:46:07 +0000 (UTC), hobo wrote:
This website was my sole source for the claim that the Corsair had a 3
blade prop. Perhaps a 4 blade was later added, but it seems odd that a 3
blade was ever used if ground clearance was so pivotal to the whole
design.
Prop design is extraordinarily complicated. The Corsair, like several
of the high powered, high speed fighters of WWII had a high enough
performance to reach the boundaries of propeller powered design.
The problem was how to harness all that power. You can use a multi
blade prop with a smaller diameter, but acceleration and climb may be
compromised.
The people who designed the Corsair understood that you loose whatever
thrust was being developed by the inner diameter of the prop because
the thrust is masked by the cowling housing the engine. One way of
getting around the large cowling is to make a large prop. The large
prop allows good takeoff and climb performance. The ability of the
Corsair to haul large loads into the air was likely one of the reasons
it was still flying for the Navy by the time of the Korean war, even
though it had been designed in 1938.
There were actually several reasons for the inverted gull wing design:
This was to be a Navy carrier fighter. Carrier fighters have to land
on board aircraft carriers and this landing is often so harsh that
it's been likened to a barely controlled crash. The landing gear had
to be very very sturdy to take the severe G forces when the airplane
smacked down on the deck.
The design of the fuselage, as was typical for the day, involved a
round cross section. Mating a wing to a round cross section required
a large fairing to reduce drag at the wing to fuselage intersection.
The fairing was not necessary if the wing could be mated at a 90
degree angle to the fuselage.
Finally, the prop being proposed was the biggest ever attached at the
time to a fighter, because the design was to use the Pratt and Whitney
R-2800 engine which at the time was one of the most powerfull ever
developed.
The elegant solution to all three problems was to use the inverted
gull wing. This kept the landing gear short, or at least shorter than
it would have been with a straight wing, made the wing to fuselage
intersection possible without a fairing, and gave the necessary
clearance for that huge prop.
It was not without it's problems however.
Corky Scott
All I Wanted For Christmas Were Inverted Spins [email protected] Aerobatics 3 December 29th 04 07:40 PM
VP-II wings available in Oregon, USA (Or, "How I was coconuted...") Roberto Waltman Home Built 2 October 29th 04 04:21 PM
inverted spin recovery explanation Alan Wood Aerobatics 18 August 19th 04 03:32 PM
Double covering fabric covered wings [email protected] Home Built 9 May 9th 04 08:39 PM
Crooked or Wavy Trailing Edges of Wings and Control Surfaces Larry Smith Home Built 3 October 24th 03 02:31 AM
