Worried about a leading edge crack in the fiberglass wing laminate ofmy PW-5
Old February 12th 18, 05:31 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Default Worried about a leading edge crack in the fiberglass winglaminate of my PW-5
Two things caught my attention from the OP.
First, if using a rigger in a crosswind, do everything in your power to have the cradle set and LOCKED at the far upwind side of the axle before rotating the wing to the leading edge down position. Why? Give you the longest arm for overturning moment. Longer axle might help, but not if you are in the middle of it or at the downwind end of it!
Second, you have a glider and no way to haul the trailer around yourself? You said you would have to rent or borrow a vehicle to move the trailer. This seems a bit off to me. But, a car is not required to roll a trailer a wing panel length and turn it 90 degrees so it is pointed into the wind. Then move it back into the tiedown spot after you have rigged or de-rigged. Yes, more work, but minimal risk for damage that way.
Just my observations. Hope you get your wing repaired quickly!
Steve Leonard
Old February 13th 18, 06:39 AM posted to rec.aviation.soaring
On Sunday, February 11, 2018 at 9:20:59 AM UTC-8, wrote:
Hi all.
I own a PW-5. I have a MM Fabrication Wing Rigger I use when put the glider together and take it apart.
Yesterday, a gust of wind caught the wing when it was vertical on the wing rigger, and even though I was holding the wing steady near the spar, the wind force was strong enough to topple the wing rigger and slam the leading edge on the ground (grass). Personally I think these wing riggers need longer wheel bases to provide more moment against moderately strong wind, but that is another story.
An initial inspection for damage showed a 3 inch crack in the fiberglass in the leading edge where it struck the ground. The crack is deep enough to show the square pattern of the underlying fiberglass cloth layer, so it's not just a surface crack. (A PW-5 doesn't have a gel coat anyway. It has a coat of paint over the fiberglass laminate.)
I'm now worried about structural integrity of the wing, of course. Should I be? What should be your next steps? or what would you do next if you were I?
Respectfully,
Charles "Ben" Ethridge
ANY damage to the wing forward of the mainspar MUST be inspected before further flight, repaired as necessary, and a logbook entry made.
Old February 13th 18, 11:49 AM posted to rec.aviation.soaring
I disagree, at least on a MM Wing Rigger. Imagine there is no wind at all. If you lock it on the open side of the wing rigger cradle, then entire weight of the wing now rests just above the wheel and becomes very unstable. (Got that t-shirt.) Now imagine the crosswind again. Yes, you are right, as long as you don't turn the wing so that it is now parallel to the wind, which is going to happen when you put it in the trailer (also parallel to the wind) per discussion above. I agree that it's all about longer moment, but there are different ways to skin that cat. One of them would simply be a longer axle. This WOULD help for sure, even if you lock the in the middle. By locking it in the middle, you mitigate the risk of crosswind toppling it PLUS the risk of toppling it by simply having the wing weight directly over a wheel when you turn it upwind.
I'm curious what Mark of MM recommends on this, i.e. setting the Wing Rigger directly over a wheel.
Second, you have a glider and no way to haul the trailer around yourself? You said you would have to rent or borrow a vehicle to move the trailer. This seems a bit off to me. But, a car is not required to roll a trailer a wing panel length and turn it 90 degrees so it is pointed into the wind. Then move it back into the tiedown spot after you have rigged or de-rigged.. Yes, more work, but minimal risk for damage that way.
Yes, I do. The glider lives in its trailer at the airport. I only have a Honda Civic, so it may seem a bit "off", but it's true. I'm not just making an excuse here. I normally borrow my brother's truck to move it.
Further, all of the gliders are stored in one spot on the airport and they are all lined up quite close to each other so it is impossible to turn mine 90 degrees without first towing it away from the other trailers.
Thus far the best overall solution (in my particular situation) seems to be to get a (a) longer wheel base and (b) keep the cradle locked in the center (so that the wing weight is over the center of the wheel base) and (c) keep the wing horizontal as much as possible. (Here, I'm assuming there is no one around to hold the opposite end of the wing in case it decides to topple.)
I will also try to talk the airport manager into letting me move my glider to a different spot where I can turn the trailer 90 degrees as you say.
Old February 13th 18, 11:51 AM posted to rec.aviation.soaring
I'm trying to imagine how one would inspect this to make sure there is no internal structural damage. X-ray?
Old February 13th 18, 12:48 PM posted to rec.aviation.soaring
"I'm curious what Mark of MM recommends on this, i.e. setting the Wing Rigger directly over a wheel."
Charles- There is no problem with positioning the chassis and wing cradle all the way to one side or the other to counter a crosswind. The PW-5 has a lightweight wing, and when rotated to the vertical position, it becomes a pretty big sail. Moving the vertical column to the UPWIND side and locking the axle (!) can help by giving more lateral support. Remember that you are not actually "setting the WingRigger directly over a wheel." The axle support tube is ten inches long, so the vertical column is offset. (Not so much on the side the saddle is rotated to.) The most important step is securing the lateral movement with the axle lock knob (and checking it before moving!)
However, if you want a longer axle, contact me and we can discuss options.
Old February 13th 18, 04:16 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
However, if you want a longer axle, contact me and we can discuss options..
Yes, Mark and I go a long ways back on riggers. As he said, one key to the design is to make it so you CAN NOT get the CG of the wing over a wheel when the wing is either level or leading edge down. You can accomplish this by not putting the vertical member of the chassis on the center of the axle support tube. I haven't seen one of Mark's recently, but I know I did this on mine something like 15 years ago. And most importantly, LOCK the the rigger to the axle. If not, it will have impressive velocity when it hits the other end of the axle, and away she will go!
If your trailer does not have a "jockey wheel" on the front of it, I would encourage you to consider adding one. This makes it so you can push your trailer out of the row, turn it 90 degrees (if the wind says you should do so), put the plane away, then push the trailer back into the row.
Oh, and I think I have a longer axle on my rigger than most. It isn't an issue for storage as it is still shorter than a collapsed wing stand.
There have been many improvements and refinements over the years as these designs have evolved. And there will continue to be more as time goes on. Good that yours has the support of Mark Mocho. Mine is a one off and it is all on me to refine!
Steve Leonard
Old February 13th 18, 05:04 PM posted to rec.aviation.soaring
George Haeh
Default Worried about a leading edge crack in the fiberglass wing laminate of my PW-5
I'm happy to have a helper when I'm derigging in a breeze.
Station the helper on the downwind side of the rigger when you're rotating
wing to vertical so he can keep the rigger from blowing over.
Simply put if there's a good breeze, you must point the trailer into the
wind or
find at least three strong helpers.
Old February 13th 18, 05:50 PM posted to rec.aviation.soaring
Honda Civic?!?!
I crewed (late '70's?) for a person from near Boston with an original "super Beetle" (oxymoron.......) with a ASW-15 and a large plywood trailer.
Empty trailer on flat ground, I was looking to draft motorhomes to maintain 55-60MPH on a highway........
Loaded trailer......sigh......Frikkin forget uphill........
Your Civic can do well pulling a trailer, just moving it around an airport, sheesh, no issue.
Yes, a helper is great, but not always available.
Old February 13th 18, 06:53 PM posted to rec.aviation.soaring
Bob Whelan[_3_]
On 2/13/2018 4:49 AM, wrote:
Snip...
...The glider lives in its trailer at the airport. I only have a
It took a while, but eventually sufficient rust fell off my memory cell, thus
regenerating a coupla possibly-actionable anecdotes...
- some years ago a soon-to-be friend arrived at my home field (KBDU) towing an
original PIK-20A in an original PIK factory trailer behind a 2nd-generation
Civic. They'd moved from Louisiana with the rig. Not the cutesy 1st-gen
liquid-cooled-engine Civic, but its slightly supersized successor (that soon
allowed Honda to show its after-sale customer support by warranty-replacing
beaucoup rusted-through front fenders). It was years before he replaced that
particular tow-vehicle. Anemic in the mountains, but he never killed it
mechanically by using it in that manner. Memory sez he had some sort of
generic tow hitch installed on the vehicle.
- even more years ago (1973!) I bought a generic tow hitch (from Sears!) to
install on my 1972 Maverick. It didn't fit properly, but I was lucky enough to
have Wil Schuemann as an officemate, who welded-it-to-necessary-length, plus
welding on 2 triangulation braces. Trouble-free towed gliders with that
car/hitch until I sold it in 2009!
- ~2000-ish I installed a generic hitch on my eventual-wife's 1987 4-banger
Mustang which she used for several years to tow a 1-26, including to/from Air
Sailing (NV) and Dalhart (TX) from eastern CO. Health forced her to sell the
1-26 ~6 years ago; the 'Stang's original engine/tranny/running gear are
presently returning from the moon with ~275k miles on 'em.
Bob W.
This email has been checked for viruses by AVG.
http://www.avg.com
leading edge templates glider[_2_] Soaring 6 August 25th 10 10:43 PM
Wing Leading Edge Refinishing Jan Eldem[_2_] Soaring 4 June 17th 08 02:40 PM
Leading edge protection search Tim Hickey Home Built 0 June 28th 04 02:45 AM
-7 wing leading edge 'glitch' ? Charlie England Home Built 0 March 7th 04 12:27 AM
leading edge flaps Arquebus257WeaMag Military Aviation 105 January 14th 04 04:11 AM
