Russia 5M tire and tube?
Old March 13th 18, 06:21 PM posted to rec.aviation.soaring
Waveguru
Default Russia 5M tire and tube?
Where can we get tube and tire for a Russia?
Boggs
Old March 13th 18, 06:51 PM posted to rec.aviation.soaring
Papa3[_2_]
Boggs
Paul Manafort.
Couldn't resist.
Old March 13th 18, 07:09 PM posted to rec.aviation.soaring
Boggs
Check out the Russia Sailplanes Yahoo Group. (Albeit I havn't gone there in a while since Yahoo Groups has become a rather painful environment.) When I needed to replace the tire on my Russia I was told there to use the same tire that goes on a 1-26. The width of that tire at the hub hole seemed way too narrow for the (metal) hub on my (prototype) Russia AC4a, but after inflation it worked out. For a tube, after some misadventures with smaller ones, I went for a larger one (I'd have to look up the size code at home), since it gets stretched so far near the hub. Also, for my hub at least, I needed a tube with an angle stem, PLUS a stem extender. Warning: check your tire pressure (with a gauge) every couple of months, since it can get low but still look OK. With sub-optimal pressure, hard braking can result in enough rotation between the tire and hub to shear the stem of the tube.
Old March 14th 18, 01:54 AM posted to rec.aviation.soaring
If the tire on the 5m is the same as the 4c, then you can you use a 126 tire and tube from desser. The original tire is hard as a rock with zero pressure.
Old March 14th 18, 04:59 PM posted to rec.aviation.soaring
On Tuesday, March 13, 2018 at 9:54:46 PM UTC-4, wrote:
... The original tire is hard as a rock with zero pressure.
- exactly, the original tire feels hard even with zero pressure, that's why I learned to check it with a pressure gauge every couple of months. Despite the hassle, as (on the AC4a) I need to remove the wheel fairing, and add a valve extender, just to use the gauge. But the alternative is a ruined tube, or worse.
Looking to buy a 12x4/300x100 tube and tire... Steve Loudon Soaring 0 July 21st 16 02:19 AM
What's the best way to install a new tire tube ? [email protected] Soaring 14 March 9th 09 11:46 AM
FA: Aircraft tire and tube, New, 500 x 5 [email protected] Home Built 1 February 3rd 06 10:42 PM
FA: Aircraft tire and tube, New, 500 x 5 [email protected] Aviation Marketplace 1 February 3rd 06 10:42 PM
Puchacz Tire and Tube [email protected] Soaring 1 September 14th 04 06:17 AM
