Goop / caulk recommendations
Old March 14th 18, 05:22 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Goop / caulk recommendations
My trailer arrived with two soft solar chargers attached to the roof top via a sort of caulk/goop. Two years later the trailer is leaking under the solar panels. Looking for a recommendation for a goop or caulk that is white or clear, and can withstand the sun and heat of the Western USA flying spots?
Old March 14th 18, 06:23 PM posted to rec.aviation.soaring
I use "Goop", whether it is marine, automotive, etc.
Basically it is a silicone (from what I can find online) "RTV", with a thickener. Letting it, or similar, set and then cover (silver/aluminum) tape can extend the life.
Good news, it won't flow all over. It is also cheap from local sources.
Bad news, not much lasts long out in the sun or elements.
Silicone does not take paint well, thus using some sort of tape to cover the seal over time. Latex sealers take paint better, but in my eyes won't last as long even if painted.
Old March 14th 18, 07:15 PM posted to rec.aviation.soaring
sisu1a
Sikaflex 295 is a UV resistant sealant/adhesive
https://www.merrittsupply.com/produc...e-and-sealant/
3M makes one too, called 4000 UV
https://www.westmarine.com/buy/3m--4...96?recordNum=5
Loctite has their own version cleverly named Marine Sealant
https://www.homedepot.com/p/Loctite-...6891/206156418
If you use a paintable formula like the first two you can also put a UV protective topcoat over the sealant which would extend its exposure limit.
Old March 14th 18, 10:17 PM posted to rec.aviation.soaring
I've had good luck with polyurathane. Silicon only gives you one try since it won't stick to itself.
3M 5200 is a classic boat sealant in white, but takes a long time to cure
Loctite is my favorite. I know they have it in black, not sure about white.
Sikaflex is another good brand
Homedepot has all of the above
Old March 14th 18, 11:24 PM posted to rec.aviation.soaring
the 3m 5200 is what we used on my tail wheel skid it cures in about 12-24 hours if there is enough humidity. In AZ I had to drape wet towels over it. it is very sturdy an a little flexible. Best stuff I have ever used and it is white
Old March 15th 18, 12:52 AM posted to rec.aviation.soaring
Scott Williams
3M 5200, available in 7 day cure or 24 hr cure in the boating section of Academy outdoor and Sports
Good luck!!
Old March 15th 18, 01:31 AM posted to rec.aviation.soaring
jfitch
Good luck!!
3M 5200 will yellow in the sun and eventually crack where it is exposed, if that is a worry. 3M 4000 will not yellow or crack - at least for a very long time.
Old March 15th 18, 04:43 PM posted to rec.aviation.soaring
Craig Funston[_3_]
Good luck!!
Jon,
Thanks for the lead on the 3M 4000. I wasn't aware of silane modified polymers & it definitely looks like the better choice for something exposed to UV. Polyurethane (3M 5200) usually isn't a good choice for high UV exposure.
Craig
7Q
Old March 15th 18, 07:16 PM posted to rec.aviation.soaring
AS
I can vouch for the Sika-brand! Just about any gap or joint on wind turbine nacelles or blades gets sealed off with Sikaflex and it lasts for years without fading or cracking. It is a Urethane and it can be painted over. It comes in a variety of colors with white being the most popular.
Uli
‘AS’
Old March 15th 18, 09:05 PM posted to rec.aviation.soaring
Sikaflex is usually the "gold standard" in the RV industry. Any exterior penetration gets sealed with Sikaflex. Excellent caulk.
PDA Recommendations Jim White[_4_] Soaring 16 January 8th 09 09:29 PM
DME recommendations mindenpilot Owning 27 April 11th 05 05:23 PM
Recommendations - near FLL Hilton Piloting 2 March 16th 05 06:04 AM
CHT recommendations Dude Owning 3 December 26th 04 05:07 PM
MFD recommendations Richard Kaplan Owning 13 January 27th 04 04:04 PM
