PDA Recommendations
Old January 7th 09, 11:15 AM posted to rec.aviation.soaring
Jim White[_4_]
Default PDA Recommendations
My 3970 that runs Winpilot has died and I need to replace it. I have a 3900
cradle fitted to the cockpit. What can you guys recommend that will run
Winpilot?
I believe the 5500 series IPAQ will fit in the same cradle. Can anyone
confirm this? What about other models?
The IPAQ 214 is more powerful but I would have to feed it by bluetooth.
Has anyone done this?
Which model has the brightest screen? I am getting older and the eyes
don't work as well as they did!
Will Winpilot run on the HP314? This has a big bright screen and is very
cheap.
Suggestions based on experience would be very welcome.
Thanks
Old January 7th 09, 11:45 AM posted to rec.aviation.soaring
nimbus
The cradle should not be your major argument for selecting a PDA.
Luminosity, power consumption and size of screen should be....
Today, my favourite selection would be the Loox N560 (it has an
incorporated GPS antenna). It works perfectly with SeeYou and XCSoar.
Bruno
Old January 7th 09, 12:33 PM posted to rec.aviation.soaring
Paul Remde
Hi Jim,
Please see my notes below.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
"Jim White" wrote in message
3900
Winpilot?
- Your cradle will work with any iPAQ h3800, h3900 or h5000 series Pocket
PC. Many glider pilots consider the h3800 to be the easiest of those to
read in sunlight. You can probably find a good used one on eBay.
- I have done testing with both a CF Card Serial Port and using the K6 Bt
BlueTooth Adapter in my iPAQ 210. The serial port option is less "elegant"
looking, but works well for all communications and with all soaring
software. The K6 Bt connection works well with software that has been
written to work with it. I don't know if WinPilot supports the K6 Bt.
SeeYou Mobile does.
- Unfortunately, no PDA is great in sunlight. The iPAQ h3800 would be
slightly easier to see than your h3900. The iPAQ hx4700 is bigger, higher
resolution and a little brighter and the iPAQ 210 is a the same size and
resolution as the hx4700 and a little brighter. I think the iPAQ 310 is the
brightest option.
cheap.
- The K6 Bt BlueTooth Adapter works great with the iPAQ 310/314, but I
- If I were you I would first try to find a used h3800 on ebay.
- If you want a "wired" connection I recommend the iPAQ 210 with a CF
Serial Card. You can see details on that he
http://www.cumulus-soaring.com/nimbus.htm
- If you find the WinPilot will work with the K6 Bt BlueTooth Adapter then
you may want to consider the iPAQ 310/314. You can see details on the K6 Bt
he
http://www.cumulus-soaring.com/k6.htm
Thanks
Old January 7th 09, 02:41 PM posted to rec.aviation.soaring
Eric Greenwell
he
I suggest you ask Winpilot if they will be supporting the HP 314 and
taking advantage of it's much more powerful hardware. SeeYou is adapting
SeeYou Mobile to run on it (Mobile is available in beta version now for
the 314), and says the 10 to 20 times more powerful processor will allow
features not possible on the Ipaqs. A new, low cost, bright screen, high
performance display for the cockpit is compelling, I think, even with
the extra hassle of using Bluetooth. And you can use it to help get you
the airport, too!
Old January 7th 09, 04:02 PM posted to rec.aviation.soaring
Richard[_9_]
On Jan 7, 3:15*am, Jim White
Winpilot?
cheap.
Thanks
Jim,
I am the US WinPIlot dealer and recommend the Ipaq 5555 with a clear
touch antiglare screen protector or an Ipaq 4700. . WinPilot ADV &
PRO will run on both. The Ipaq 5555 uses the same cradle as your
3900, the 47xx requires a different cradle.
If you have any other questions please call or email.
Thanks
Richard
www.craggyaero.com
Old January 7th 09, 04:05 PM posted to rec.aviation.soaring
Tuno
Eric or Paul, can you briefly summarize whether/how the 314 would/
could get the RS232 data from a Cambridge 302? (iow is there a RS232-
to-Bluetooth device, and where does it get its power and how much does
it consume?)
Old January 7th 09, 04:56 PM posted to rec.aviation.soaring
Mike[_8_]
On Jan 7, 5:33*am, "Paul Remde" wrote:
Hi Jim,
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.http://www.cumulus-soaring.com
3900
Winpilot?
*- Your cradle will work with any iPAQ h3800, h3900 or h5000 series Pocket
PC. *Many glider pilots consider the h3800 to be the easiest of those to
read in sunlight. *You can probably find a good used one on eBay.
*- I have done testing with both a CF Card Serial Port and using the K6 Bt
BlueTooth Adapter in my iPAQ 210. *The serial port option is less "elegant"
software. *The K6 Bt connection works well with software that has been
written to work with it. *I don't know if WinPilot supports the K6 Bt.
SeeYou Mobile does.
*- Unfortunately, no PDA is great in sunlight. *The iPAQ h3800 would be
slightly easier to see than your h3900. *The iPAQ hx4700 is bigger, higher
resolution as the hx4700 and a little brighter. *I think the iPAQ 310 is the
brightest option.
cheap.
*- The K6 Bt BlueTooth Adapter works great with the iPAQ 310/314, but I
Checking the XCSoar forum it seems that some folks using the HP 310
are not that impressed with the display in sunlight.
It turns out to be no better than a good IPAQ in comparison.
The HP38XX series seems to be best.
The link below will show photo comparisons and opinions from users.
http://www.nabble.com/Adding-a-seria...o20825419.html
*- If I were you I would first try to find a used h3800 on ebay.
*- If you want a "wired" connection I recommend the iPAQ 210 with a CF
Serial Card. *You can see details on that hehttp://www.cumulus-soaring.com/nimbus.htm
*- If you find the WinPilot will work with the K6 Bt BlueTooth Adapter then
you may want to consider the iPAQ 310/314. *You can see details on the K6 Bt
hehttp://www.cumulus-soaring.com/k6.htm
Thanks
Old January 7th 09, 05:00 PM posted to rec.aviation.soaring
Richard[_9_]
it consume?)
Ted,
I have tied a Gridconnect firefly serial to blue tooth converter. The
firefly is on the 302. I have not been able to get a valid GPS signal
on either a Ipaq 5555, 4700 or 310.
Richard
www.craggyaero.com
Old January 7th 09, 05:09 PM posted to rec.aviation.soaring
Steve Koerner
Tuno: your questions are completely answered at the link that Paul
indicated to his very nice website:
Old January 7th 09, 05:17 PM posted to rec.aviation.soaring
Tuno
D'oh! How'd I miss that. Looks very nice.
Now all I need is for WinPilot to run on the 310! (Hint Jerry HINT
HINT HINT)
2NO
DME recommendations mindenpilot Owning 27 April 11th 05 05:23 PM
Recommendations - near FLL Hilton Piloting 2 March 16th 05 06:04 AM
CHT recommendations Dude Owning 3 December 26th 04 05:07 PM
MFD recommendations Richard Kaplan Owning 13 January 27th 04 04:04 PM
Kit recommendations another fool Home Built 9 November 10th 03 03:29 PM
