Round out and flare with fully open spoilers in a PW-6? Other gliders?
Old March 27th 18, 10:13 PM posted to rec.aviation.soaring
Default Round out and flare with fully open spoilers in a PW-6? Other gliders?
On Monday, March 26, 2018 at 7:47:36 PM UTC-4, son_of_flubber wrote:
The PW-6 has very effective spoilers, and some other gliders have even more effective spoilers. Assuming C.G. is within limits and runway is level, is it possible to round out and flare with the spoilers fully open? Does one need extra airspeed? How much extra? (Yep. I know it is advisable to reduce spoilers before entering roundout.)
How do you teach steep descent to students? How steep? How fast?
I saw this question come up in a discussion of a fatal accident in a SZD 51-1 Junior. Student pilot opened 'full spoilers' and failed to flare.
Is a 'full spoiler flare' required to obtain glider certification in EASA?
And finally, does the PW-6 have spoilers or airbrakes?
Charlie , you hit the nail on the head! I also has a 20A L, that I would make some very short landings and my best friend Alfonso, AKA E9 would applaud me for my sticking to his approach to landing scenario. Trust me, no one did it better than the Fonzie! One better be prepared for what will certainly someday happen, and the best rule of logical thinking is that if you think it might happen, it probably will. Practice doesn't make perfect as we have all been told, but perfect practice results in perfect results. Bob
Old March 27th 18, 10:26 PM posted to rec.aviation.soaring
Dan, the wall was very high, looked like they wanted people to stay, but I was inside the wall and wanted to get out! The cop was a real Barney type, looked like he came straight from Newberry except he must have stopped at every donut shop in Arcadia. Only think he was most concerned about was my drivers license. It was a great approach, just over the fence and into the inmate ballpark. They came with their guns drawn and sirens sounding, you would have thought that I would have planned some sort of prison break. I even asked the cop how many inmates do you have to help me take this thing apart? It was the end of an interesting day. Bob
Old March 28th 18, 12:49 AM posted to rec.aviation.soaring
Nick Kennedy
I think the OP has got the terms wrong. I don't think you Flare a glider into a landing. I think you roundout and then just hold it off until it lands itself.
I think Flaring is something you do in a C-172. Or most power airplane. If you try and flare a glider your likely to hit the tailboom hard and / or pound in. Tailboom first landings are the way the euro's try and land, but Flaring? I don't think so.
Am I wrong?
I think any pilot going XC should be able to spot land his glider with full Spoilers out and flaps too if you have them.
I don't know of any glider that can't be landed with everything hanging out to the max but I'm sure someone here will correct me on that point. My ASW20 was and my LS3a is, easy to land with everything out to the max. It is good to practice this a couple of times a year in good conditions thou.
Old March 28th 18, 07:49 AM posted to rec.aviation.soaring
Richard McLean[_2_]
I think "flare" and "round out" are exactly the same thing .. a change in
attitude to enable a low-energy landing. Powered or glider makes no
difference. That's how it works here downunder anyway!
in=
land=
s itself.
If
po=
Fl=
Am I wrong?
full=
out=
ASW=
is
Old March 28th 18, 11:20 AM posted to rec.aviation.soaring
John Wells[_2_]
And the corollary is true... if you try to reduce flaps/airbrakes near
the ground on many gliders, you'll get an unpleasant surprise.
On my Mini Nimbus for example, full flap & airbrake approaches are
recommended, but don't try closing the airbrakes "a little" near the
ground -- all that does is keep the trailing edge airbrakes open but
reduce flap, which can get exciting.
glider
in=
land=
s itself.
airplane. If
or
po=
but
Fl=
Am I wrong?
with
full=
hanging
out=
point. My
ASW=
max. It is
thou.
Old March 28th 18, 05:59 PM posted to rec.aviation.soaring
Jim[_33_]
in=
land=
s itself.
If
po=
Fl=
Am I wrong?
full=
out=
ASW=
is
This is mostly a matter of terminology I guess. For me, "flair" is something I do in tricycle gear power aircraft to raise the aircraft's nose a bit to avoid having the nose wheel contact the ground on touch down. This is not what I do in landing a glider. I "round-out" ( progressively transition from final approach to the "hold-off" and let the glider land itself. When I have goofed this up (frequently) and raised the glider's nose too high ("flair" in my lingo) the glider touched down tail wheel first. Hardly a problem if the touchdown is gentle but I can't think of a reason to do it - if the approach airspeed is not too high.
Old March 28th 18, 06:40 PM posted to rec.aviation.soaring
kirk.stant
Same maneuver, different names. Flare is more US, Round-out more British, I think. Both mean the same thing - change aircraft attitude from approach to landing; this reduces sink rate and sets up for the specific type of landing touchdown being done: fully-held off low energy (tail and main at same time) or flown on main only (Blanik, Schweizers). Tailwheel airplanes can do 3-point, wheel landings, or one main wheel crosswind landings. And in an F-4 or F-18 you don't even have to bother, just drive it onto the runway (or, as my navy friends used to say back before PC: "Flare to land, squat to pee"). In my LS6 I can get the tail wheel to touch just before the main if really going for min energy; a "one wheel" landing?
And "flair" is how stylishly you accomplish the "flare".
66
Old March 28th 18, 06:42 PM posted to rec.aviation.soaring
Edward Lockhart[_4_]
in=
=20
attitude to enable a low-energy landing. Powered or glider makes no=20
=20
glider
in=3D
land=3D
s itself.
airplane.
If
=3D
or
po=3D
but
Fl=3D
Am I wrong?
full=3D
hanging
out=3D
My
ASW=3D
It
is
=3D
thou.
somethi=
bit
n=
transition=
Whe=
high
p=
"Flair" is either a natural aptitude for something or a synonym for
panache.
Flare is rounding out the end of something, think flared trousers or flared
tubing. In our case it refers to the transition from a (relatively) steep
approach path to a brief period of flight parallel to the landing surface.
Whether you land on the mainwheel or both wheels together is irrelevant, &
purely a matter of choice.
One reason for landing on both wheels is that it's virtually impossible to
bounce back into the air again.
Old March 28th 18, 09:02 PM posted to rec.aviation.soaring
Yep, on my iPad, sorta a PITA to multi quote.
Final may be a "high decent rate, followed by varying horizontal movement to remove energy before touchdown".
My first thought, did you stop before some unmoveable object?
Yes?, great.
No?, sucks.
Flare, flair, roundout, WTF........you are transitioning between a potential high decent rate to a horizontal maneuver where you dissapate the remaining energy. Yes, for those of you that do "Queens English", I left out some letters. ;-)
If you have GREAT brakes, this helps.
Energy management is paramount. Even if you have great brakes, they "may" fail when you count on them the most.
Always, keep in mind, "does it look good, does it sound good, does it feel good?". Yep, I know.......I "thought" I had dumped a full load of water in a -20C going into a field.
Found out LATER, we did work on the system, the dump lever didn't go over center, thus, even though I did my bit, I still landed with FULL WATER in a field on the ridge in PA.
It didn't feel right, didn't sound right, I kept a decent speed.
Old March 29th 18, 01:47 AM posted to rec.aviation.soaring
Jim[_33_]
66
Yes, of course. I can't spell any better than I can land.
New open class gliders at Aero Dave Nadler Soaring 5 April 20th 11 09:13 AM
Open Cockpit Gliders? DL152279546231 Soaring 17 December 25th 08 08:14 AM
Comparison of older Open Class gliders SoaringXCellence Soaring 5 March 15th 08 05:02 PM
Open Spoilers Alarm on tow tango4 Soaring 12 March 17th 04 06:18 PM
Aviation art website fully functional Christopher Drew Aviation Marketplace 0 January 29th 04 10:43 AM
