Open Spoilers Alarm on tow
Old March 16th 04, 08:47 AM
tango4
Default Open Spoilers Alarm on tow
Microswitch on release mechanism, microswitch on brakes. Pressure switch (
very low! ) in ASI circuit
Bistable arming circuit with 15 minute timeout.
Arm circuit with leading edge of tow activation. ( Open release to install
hook, circuit goes active )
While armed if brakes are opened buzzer goes off.
Circuit is disarmed when 40kts reached.
Ian
Old March 16th 04, 11:22 AM
Uri Saovray
Jim,
So you are suggesting to measure the force on the tow tope, assuming
it would rise dramatically if the spoiler is open?
Sounds like a good idea, but:
1) Will it trigger in a ground launch? Won't opening the spoilers
REDUCE the load?
2) Would it trigger when the handle is just unlocked, and the spoilers
aren't actually out (yet)?
Uri
illspam (Jim Vincent) wrote in message ...
What about the towhook? Magnetic sensor? where? How? Other ideas
Install a strain gauge internal to the fuselage right up against the hook
mount. Get Peter Masak to design a simple circuit that trips an electronic
relay when the strain exceeds a certain amount. Knowing Peter, it should take
him less than an hour.
Jim Vincent
CFIG
N483SZ
illspam
Old March 16th 04, 01:51 PM
Jim Vincent
Uri,
The strain gauge would just indicate that the tow rope is under any load,
regardless of the amount, but triggered above some reliable value, perhaps 5
lbs. This would indicate that the tow hook is being used.
Jim Vincent
CFIG
N483SZ
illspam
Old March 16th 04, 01:43 PM
Bob Lepp
I'd go for 'spoiler open' alarm sounding when open IF my hand is not
on the actuator. On tow or off tow, if they are open and I did not
open them I'd want to know. I've had both situations happen. My fault
both times.
Might make wiring a bit simpler.
Bob
Jim Vincent
CFIG
N483SZ
illspam
Old March 16th 04, 01:46 PM
Jim Vincent
on the actuator
I'd rather have my hand near the tow release instead, especially during the
first part of the tow.
Jim Vincent
CFIG
N483SZ
illspam
Old March 16th 04, 09:31 PM
Mark James Boyd
Most of the gliders I've flown have the tow release way
too far from my hand. Granted, I have short
arms (not a boxer), but do others commonly notice they
need to lean forward a little or twist shoulders to
pull the release on many gliders?
Mark Boyd
Avenal, California, USA
Old March 16th 04, 10:39 PM
Jim Vincent
Get yourself a ski boot carrier. Its a length of 1/4" nylon cord with a
plastic handle. Wrap the cord around the existing release knob, and Voila, 8"
extra reach. Works great in my Jantar where the existing release is way
forward. Another benefit is I can loosely hold the plastic handle in my hand
with little risk of pulling the release by accident if I hit turbulence since
there is a lot of slack.
BTW, IMO, your hand should never be holding the release on the panel.
Instead, keep your hand just behind the release, basically with your knuckles
touching the release. This way, if you're waved off, you don't have to look
for the release, it is already at hand.
Jim Vincent
CFIG
N483SZ
illspam
Old March 17th 04, 03:45 AM
Bob Lepp
Me too, what I meant to convey was.... if the spoilers are open and my
hand is not on the spoiler control handle it might be nice to have an
alarm sound. To me it matters not whether there is pressure on the tow
hook or not. It only matters that the spoliers are open and I am not
holding them open. I guess I'm thick, I haven't caught on why tow hook
pressure is important.
Old March 17th 04, 03:52 AM
Jim Vincent
alarm sound.
Interesting approach! I like it. Could easily be done.
Tow hook pressure was one parameter discussed in a spoiler warning solution.
Frankly, I like your idea of the hand sensor more.
Jim Vincent
CFIG
N483SZ
illspam
Old March 17th 04, 04:20 AM
Bill Daniels
"Bob Lepp" wrote in message
om...
If I understand your proposal for a sensor to detect the pilots hand on the
spoiler handle correctly, it should fulfill the "spoiler open on tow"
warning function assuming no pilot would deliberately open the spoilers
while still on tow.
I do see a few problems that need a thoughtful review.
I have had pilots open the spoilers instead of pulling the release at the
top of a winch launch. A warning here would be nice.
It would create a problem if the pilot must move his hand from the spoilers
to the flaps to select a negative setting just after touchdown to maintain
aileron control. It would be a real nuisance to get a warning horn at that
busy moment.
Some gliders must start their takeoff roll with the spoilers open to augment
aileron control at low airspeeds. Again, it's a bad time to be distracted
by a audible warning. This is where a low airspeed lockout would be needed.
I think the system would need three sensors to give a useful warning -
airspeed above a certain value, ring in hook and spoiler open.
Bill Daniels
Open Letter to Kofi Annan and George Walker Bush Matt Wiser Military Aviation 2 March 12th 04 04:05 PM
An open letter to Illinois Attorney General, Lisa Madigan Larry Dighera Owning 0 November 4th 03 10:22 PM
L-13 Spoilers Scott Soaring 2 August 27th 03 06:08 AM
Tango One Open House at KFFZ (Falcon Field, Mesa, AZ) Tango One Aviation KFFZ Owning 0 August 1st 03 10:51 PM
Tango One Open House at KFFZ (Falcon Field, Mesa, AZ) Tango One Aviation KFFZ General Aviation 0 August 1st 03 10:42 PM
