Mounting tires on 3" solid tailwheels
Old April 25th 18, 01:08 AM posted to rec.aviation.soaring
Default Mounting tires on 3" solid tailwheels
I'm one of the club fixit guys, and I got a little obsessed with the task of mounting a tire on a Tost 3" dia. solid tailwheel. I tried all the good advice offered on this and other forums with zero success. Most likely I lack superhuman hand strength and three extra arms.
Success took the form of a $43 Harbor Freight mini-tire changer and Ru-Glyde tire mounting lubricant from NAPA Auto. It's not as easy as the harbor freight promotional video:
https://www.youtube.com/watch?v=v7o-i4tQyfY
but it isn't a hideous trial either. With the tool the most difficult part is getting the inner tube emplaced and managing the valve stem.
Brian R
127MM
PS, If you used the tool regularly you'd probably make some modifications, since it theoretically is for wheels 4" dia. and greater.
PPS, I bought a split wheel for my own glider. Expensive, but you have some recourse if you get a flat when away from the shop.
Old April 25th 18, 04:24 AM posted to rec.aviation.soaring
Brian R
127MM
Tire talc makes it much easier:
http://www.aircraftspruce.com/catalo...s/tiretalc.php
Old April 25th 18, 05:53 AM posted to rec.aviation.soaring
Baby powder works just fine too for lubricating tubes
Old April 25th 18, 02:34 PM posted to rec.aviation.soaring
WD40 sprayed on the tire bead when installing helps immensely.
Old April 25th 18, 03:01 PM posted to rec.aviation.soaring
Just a general comment that oils and solvent based products are not very compatible with rubber. Ask any tire shop. Water based products are the safest.
Old April 25th 18, 04:29 PM posted to rec.aviation.soaring
Dan Marotta
I use baby powder, smells funny but is a lot cheaper and your wife
probably has some in the closet.
I change the tires on my Harley with tire irons and have considered
using a couple of C-clamps to mount tail wheels.Â* Instead, I bought a
brass split wheel for my Stemme since I needed some weight in the tail
(rather than giving up beer).
Dan, 5J
Old April 25th 18, 04:56 PM posted to rec.aviation.soaring
Soapy water is a reasonable lube.
Do this job a few times and you will have some damaged tubes(easily pinched and torn), and a real motivation for multi piece wheel. It is hopeless if you are in a rush.
One part Tost wheels do make good paper weights.
FWIW
UH
PowerFlarm mounting question, and an idea for mounting devices brianDG303[_2_] Soaring 2 October 23rd 11 06:51 PM
Source for new Schweizer tailwheels? [email protected] Soaring 9 August 12th 06 11:40 PM
Tailwheels on ebay Victor Bravo Home Built 0 July 27th 05 02:52 AM
Tailwheels on ebay Victor Bravo Aviation Marketplace 0 July 27th 05 02:52 AM
Tailwheels on ebay Victor Bravo Restoration 0 July 27th 05 02:52 AM
