I finally got my new radio wired, the audio seems a little quiet compared to the old Dittel 71. Same speaker, 4 ohm as spec'd. I remember the Dittel being pretty loud, kept the volume knob set to the lower half of rotation. The Becker even at 100% is far from earsplitting, and maybe not loud enough at speed or with the engine running. Both the Becker and Dittel spec'd at 4W audio power into 4 ohms.
Has anybody experienced this? |
Do you have a back seat repeater installed? Might check the volume knob there if so.
At 21:23 18 May 2018, jfitch wrote:
I finally got my new radio wired, the audio seems a little quiet compared t= o the old Dittel 71. Same speaker, 4 ohm as spec'd. I remember the Dittel b= eing pretty loud, kept the volume knob set to the lower half of rotation. = The Becker even at 100% is far from earsplitting, and maybe not loud enough= at speed or with the engine running. Both the Becker and Dittel spec'd at = 4W audio power into 4 ohms. Has anybody experienced this? At risk of asking the obvious, is you speaker wired across P1-1/P1-14 and not the headset pins? I the configuration: Is speaker ticked in IN/OUT CFG1/2? Is SPKR VOL SRC set to Primary? |
My 4201 is quit too.
DC |
My 4201 is quiet too.....
DC |
On Saturday, May 19, 2018 at 1:15:08 AM UTC-7, Tim Newport-Peace wrote:
At 21:23 18 May 2018, jfitch wrote: I finally got my new radio wired, the audio seems a little quiet compared t= o the old Dittel 71. Same speaker, 4 ohm as spec'd. I remember the Dittel b= eing pretty loud, kept the volume knob set to the lower half of rotation.. = The Becker even at 100% is far from earsplitting, and maybe not loud enough= at speed or with the engine running. Both the Becker and Dittel spec'd at = 4W audio power into 4 ohms. Has anybody experienced this? At risk of asking the obvious, is you speaker wired across P1-1/P1-14 and not the headset pins? I the configuration: Is speaker ticked in IN/OUT CFG1/2? Is SPKR VOL SRC set to Primary? Speaker is correctly wired and turned on in CFG. There is no back seat, and no second control - though it is mounted remotely using one control. "SPKR VOL SRC set to Primary?" - that I will check. I can vary the volume with the knob, it just doesn't go very high. At 100%, it is about as loud as the Dittel was on 1/3, using the same speaker. |
At 21:23 18 May 2018, jfitch wrote: I finally got my new radio wired, the audio seems a little quiet compared t= o the old Dittel 71. Same speaker, 4 ohm as spec'd. I remember the Dittel b= eing pretty loud, kept the volume knob set to the lower half of rotation.. = The Becker even at 100% is far from earsplitting, and maybe not loud enough= at speed or with the engine running. Both the Becker and Dittel spec'd at = 4W audio power into 4 ohms. Has anybody experienced this? At risk of asking the obvious, is you speaker wired across P1-1/P1-14 and not the headset pins? I the configuration: Is speaker ticked in IN/OUT CFG1/2? Is SPKR VOL SRC set to Primary? 'Is SPKR VOL SRC set to Primary?' Bingo! You, Sir, win the toaster oven. That parameter was set to "Both" and the moment I set it to "PRI" it practically blew me out of the cockpit. Now have the volume set at 25% which is about as loud as the Dittel was. Intuitively it seems like Both should have worked the same but practically, it doesn't. |
Becker AR3201 Radio need help | [email protected] | Soaring | 4 | July 31st 14 03:06 AM |
Becker radio repair | [email protected] | Soaring | 7 | March 10th 10 03:14 PM |
Becker 3201 Radio | [email protected] | Soaring | 8 | December 8th 05 03:08 PM |
Becker Radio Repair | Steve Leonard | Soaring | 2 | August 23rd 05 05:00 PM |
Becker radio AD | Tom Serkowski | Soaring | 3 | November 2nd 04 01:43 AM |
