Opinions on NASA lift theory?
Old July 2nd 18, 11:02 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Default Opinions on NASA lift theory?
On Mon, 02 Jul 2018 15:38:52 -0600, Dan Marotta wrote:
So how does all of this (lift demons, CDU, etc.) explain the fact that
British aeroplanes [sic] also fly?Â* They make some of the ugliest planes
in the world, except for the Spitfire, there must have been a Frenchman,
an Italian, or an American involved in that design.
Yep, most Blackburns and some planes from Fairey were ugly, but there are
even uglier so, after due consideration, I'd have to give the ugly prize
jointly to various prewar French and Russian aircraft, particularly their
big multi-engine stuff.
Martin | martin at
Gregorie | gregorie dot org
Old July 3rd 18, 05:19 AM posted to rec.aviation.soaring
Larry Suter
This article contains the best physical argument for lift I've seen. The author simply explains why any shape that introduces curvature into the flowfield necessarily generates lift.
http://www3.eng.cam.ac.uk/outreach/P...wwingswork.pdf
WRT wings, you do need to accept attached airflow as an article of faith.
Larry
Old July 3rd 18, 07:38 AM posted to rec.aviation.soaring
That article appears to be a reasonable effort.
Doug McLean in his book, "Understanding Aerodynamics", spends 37 pages to describe the various means used to define lift, along with the shortcomings of most of them. These pages then finish with his thoughts on how to define lift. This highlights the sheer number of ways that his has been explained.
This book is quite good, but I only suggest it to a serious aerodynamicist.
Old July 3rd 18, 03:23 PM posted to rec.aviation.soaring
Dan Marotta
On a more serious note, the folks who design and build gliders probably
have a good idea of what creates lift.Â* Why not ask them? Or do you
suppose that they know "how" but not necessarily "why"?
Dan, 5J
Old July 3rd 18, 03:58 PM posted to rec.aviation.soaring
Push forward and the trees get bigger, pull back and the trees get smaller, pull WAY back and they get bigger again. Anything beyond that from a pilot is mental masturbation. I'm going flying.
Old July 3rd 18, 06:01 PM posted to rec.aviation.soaring
Jim[_33_]
I'm dumb as a post about this stuff. Fortunately it seems I do not have to know HOW lift is created as long as I know that lift IS created - and how to manage it.
I am satisfied that it is differential pressure between the upper surface and lower surface of a wing - and the resulting down-deflecting of a mass of air - that results in the creation of lift. Newton seems to describe the process clearly.
What I have yet to come across is an explanation I can understand of why there is relatively lower pressure across the top of a wing. Maybe it actually is described in the calculus. Unfortunately I can barely balance my checking account so calculus is not accessible to me.
Old July 4th 18, 05:25 AM posted to rec.aviation.soaring
Craig Funston[_3_]
Old July 4th 18, 05:46 AM posted to rec.aviation.soaring
"They make some of the ugliest planes
an Italian, or an American involved in that design."
Yeah the French:
https://www.flickr.com/photos/varese2002/15650504868
Italians:
https://en.wikipedia.org/wiki/Stipa-Caproni
and Americans:
https://en.wikipedia.org/wiki/Boeing_X-32
sure design nice aircraft, unlike the aesthetically challenged Brits:-)
https://en.wikipedia.org/wiki/Avro_Vulcan
https://www.baesystems.com/en/heritage/hawker-hunter
As to lift theory all I'm can say for sure is that if someone's explanation of lift begins and ends with Bernouilli and the statement that the shape of the airfoil making the air travel a longer path over the top surface and thus reducing the pressure above the wing is what lets a plane fly, you can probably ignore the rest of what they say.
Old July 4th 18, 01:28 PM posted to rec.aviation.soaring
The Handley-Page "Victor" has to be in the running for "Top Dog."
https://www.google.com/search?q=hand...UcahnoNfvE-PM:
Old July 4th 18, 02:44 PM posted to rec.aviation.soaring
john firth
On Sunday, July 1, 2018 at 10:08:44 AM UTC-4, Matt Herron Jr. wrote:
Interesting read...
https://www.grc.nasa.gov/www/K-12/airplane/wrong1.html
At the molecular level, try this.
Air molecules have random motions and velocities; they bounce off randomly
at all angles to the surface.
The lower surface is flatter than the upper surface, and more molecules
will bounce off close to normal to the airstream ( the free stream, not the local) than on the top surafce.
Hence more push up than push down= lift!
JMF
Afterthought; maybe heating the lower surface will provide more push
as the recoil will be enhanced. a flat wing with zero AoA, with a hot lower and a cold upper surface will produce lift.
BTW, the flow could be almost 100% laminar.
The student should calculate the power needed for an electric aircraft
to fly using the thermo-electric effect in a flat bi-metallic wing.
Theory John Cochrane[_2_] Soaring 9 October 10th 11 08:47 PM
Theory Exam Alan Erskine[_3_] Aviation Photos 0 November 24th 08 02:55 PM
The 777 crash - another theory D Ramapriya Piloting 82 January 25th 08 03:27 PM
[Q] Strikefinder Theory of Operation [email protected] Home Built 11 September 19th 07 04:47 PM
so much for the big sky theory soxinbox Piloting 5 April 24th 06 08:07 PM
