Group-
I'm curious how Strikefinder technology works. Yes, I know some of the basics, but what's curious to me is the ability of this device to estimate range and direction to/from a lightning strike. What I know thus far is the following: 1. Lightning is nature's version of an impulse function (time domain), and thus it has wide bandwidth (frequency domain). 2. Strikefinder technology originated, I think, because it was observed that lightning strikes showed up as noise in ADF units. 3. Strikefinder technology operates, I think, as a specialized AM receiver that attempts to interpret energy bursts as lightning strikes. O.K., now I'm getting on the fringe of my knowledge. Yes, I'm an electrical engineer, so don't be afraid to dive deep into details. I just hadn't considered theory of lightning detection before and curiosity is getting to me. I'm wondering: 1. How does Strikefinder technology estimate range and direction to a lightning strike (my original question)? 2. If Strikefinder technology operates in the AM band, why? (Lightning contains many other frequency components from which to choose.) 3. How are range and direction to/from lightning strikes determined? (I know that up to around 1/2 wavelength, E and H fields are not in phase. Does the Strikefinder use "Near Field" characteristics to estimate range?) Thank you in advance for your input. -David |
On Sep 16, 4:02 pm, wrote:
1. How does Strikefinder technology estimate range and direction to a lightning strike (my original question)? Direction is measured using ADF technology, with an internal magnetic- heading sensor to compensate for the aircraft's heading changes without a connection to any other instrument. 2. If Strikefinder technology operates in the AM band, why? Plenty of strong static bursts (sferics). 3. How are range and direction to/from lightning strikes determined? Exact range determination would require triangulation using two or more sensors over a wide baseline. All single-sensor lightning detectors on the market (as far as I know) make a rough range estimate by assuming that all lightning bolts are of the same intensity and applying the inverse-square law to derive distance; this can lead to a large range error for a single bolt and radial 'stretching' of the storm cell when there are numerous strikes from a cell. The display therefore has to be interpreted very cautiously and should be used for avoidance, not penetration of a line or area of cells. The Strikefinder web site (http://www.insightavionics.com/manuals.htm) has PDF files of their manuals; look at page 34 of the user's guide to see an example of cell stretching. |
the strikefinder wasnt designed to find lightning strikes.
what was actually designed was the Automatic Direction Finder (ADF) which would point a needle toward a distant am radio transmitter. one of the ADF's weaknesses is the annoying habit of pointing toward any transmission source on the frequency. lightning broadcasts intensively on all frequencies during the strike so the adf swings toward the lightning for the moment that it is transmitting. a bright chap designed an adf with a display that could process the spurious transmissions and display their direction on a screen. cunning serendipity. Stealth Pilot |
I happened to be working a college job for a company (Smythe Research
Associates) in San Diego that had a contract to study lightning back in the early '60s. From that, Ryan Avionics (somewhere in Ohio) built on our research and did the original Stormscope and from that, the Strikefinder folks back in upstate New York did some further refinements. Smythe found that there was an energy peak somewhere around 50 kHz. from most lightning. Not ALL lightning, just most. The nice thing about examining the spectrum surrounding 50 kHz. is that it is quiet. There is nothing else there. Ryan/Stormscope took advantage of that phenomenon and centered their detection system on 50 kHz. Strikefinder took it a step further and said that they wanted to look at ALL frequencies from below 50 kHz. to well above the broadcast band (and I'm not sure at all that there isn't a bandstop filter for the broadcast band to keep you from "detecting" the rockcrusher "clear channel" AM transmitter when you are close to it). How far is "well above"? That is a very closely guarded secret from the Strikefinder folks. The detection system uses the old sense/loop technology from the ADF using a single E-field "whip" (plate) antenna and the classic crossed-loop H-field antenna(s) with the expected 90° phase difference between the two. By a clever digital manipulation of this phase difference, you can tell fairly precisely the direction of the lightning strike relative to the nose of the aircraft. Some of the more advanced models of lightning detectors have a built in magnetic reference so that if the aircraft nose moves, the display moves along with it. As to range, there are several methods, some of which depend on the reflection of that hewmongous pulse of electromagnetic energy from the surface of the earth bouncing from earth to ionosphere and back again, creating a double pulse train from each stroke. Again, using digital signal processing from multiple echoes you can create a "pseudorange" fairly accurately. Nearly as accurate, and nowhere as complicated is to "assume" a value for radiated power from the average lightning stroke and simply do a range predicated on the peak detected strength of the received lightning pulse. Some will be stronger and some will be weaker, which is why all of them don't fall directly on top of one another but form a circular pattern perhaps twenty miles in diameter on the display. Again, microprocessors can massage the data to toss out the responses at the one-sigma point and only give those responses that fall in the expected range. Now as to the practicality. I've flown a Strikefinder for almost a thousand hours. It has YET to give me a false indication and it has YET to give me an incorrect bearing and distance (within expected error) on a really nasty set of cells. Google "storm detection" and "73 magazine". Wayne Green's bunch of bandits came up with some pretty simple and accurate ways of detecting lightning that the average ham could build and use with an XY oscilloscope display. Jim -- "If you think you can, or think you can't, you're right." --Henry Ford wrote in message ps.com... Group- I'm curious how Strikefinder technology works. Yes, I know some of the basics, but what's curious to me is the ability of this device to estimate range and direction to/from a lightning strike. What I know thus far is the following: 1. Lightning is nature's version of an impulse function (time domain), and thus it has wide bandwidth (frequency domain). 2. Strikefinder technology originated, I think, because it was observed that lightning strikes showed up as noise in ADF units. 3. Strikefinder technology operates, I think, as a specialized AM receiver that attempts to interpret energy bursts as lightning strikes. O.K., now I'm getting on the fringe of my knowledge. Yes, I'm an electrical engineer, so don't be afraid to dive deep into details. I just hadn't considered theory of lightning detection before and curiosity is getting to me. I'm wondering: 1. How does Strikefinder technology estimate range and direction to a lightning strike (my original question)? 2. If Strikefinder technology operates in the AM band, why? (Lightning contains many other frequency components from which to choose.) 3. How are range and direction to/from lightning strikes determined? (I know that up to around 1/2 wavelength, E and H fields are not in phase. Does the Strikefinder use "Near Field" characteristics to estimate range?) Thank you in advance for your input. -David |
The Strikefinder does not make the assumption that all strikes are
equal. It does a transform on the incoming signals and determines distance by a top-secret dispersion technique. There isn't a pot or adjustment in the thing. It is broadband, looking at a wide range of frequencies. That way, things like broadcast stations don't affect it. Flying over Loran transmitters or WWV with many kilowatts at 60KHz will cause interference, but you have to be very close. The big problem is dealing with multiple strikes. The SF discards strikes that are corrupted by multiples... so sometimes it doesn't paint every strike. If there is even one, you should sit up. I've learned that azimuth is very accurate. Distance accuracy will vary some depending on the ground characteristics. In dry country, it tends to paint things too far. Near the ocean I've noticed that cells paint closer than actual. It must have to do with ground conductivity. With any spark detection device, you should be flying in directions where there aren't dots anyway, so the exact ranging doesn't become a problem. Bill Hale On Sep 17, 10:05 am, "RST Engineering" wrote: I happened to be working a college job for a company (Smythe Research Associates) in San Diego that had a contract to study lightning back in the early '60s. From that, Ryan Avionics (somewhere in Ohio) built on our research and did the original Stormscope and from that, the Strikefinder folks back in upstate New York did some further refinements. Smythe found that there was an energy peak somewhere around 50 kHz. from most lightning. Not ALL lightning, just most. The nice thing about examining the spectrum surrounding 50 kHz. is that it is quiet. There is nothing else there. Ryan/Stormscope took advantage of that phenomenon and centered their detection system on 50 kHz. Strikefinder took it a step further and said that they wanted to look at ALL frequencies from below 50 kHz. to well above the broadcast band (and I'm not sure at all that there isn't a bandstop filter for the broadcast band to keep you from "detecting" the rockcrusher "clear channel" AM transmitter when you are close to it). How far is "well above"? That is a very closely guarded secret from the Strikefinder folks. The detection system uses the old sense/loop technology from the ADF using a single E-field "whip" (plate) antenna and the classic crossed-loop H-field antenna(s) with the expected 90° phase difference between the two. By a clever digital manipulation of this phase difference, you can tell fairly precisely the direction of the lightning strike relative to the nose of the aircraft. Some of the more advanced models of lightning detectors have a built in magnetic reference so that if the aircraft nose moves, the display moves along with it. As to range, there are several methods, some of which depend on the reflection of that hewmongous pulse of electromagnetic energy from the surface of the earth bouncing from earth to ionosphere and back again, creating a double pulse train from each stroke. Again, using digital signal processing from multiple echoes you can create a "pseudorange" fairly accurately. Nearly as accurate, and nowhere as complicated is to "assume" a value for radiated power from the average lightning stroke and simply do a range predicated on the peak detected strength of the received lightning pulse. Some will be stronger and some will be weaker, which is why all of them don't fall directly on top of one another but form a circular pattern perhaps twenty miles in diameter on the display. Again, microprocessors can massage the data to toss out the responses at the one-sigma point and only give those responses that fall in the expected range. Now as to the practicality. I've flown a Strikefinder for almost a thousand hours. It has YET to give me a false indication and it has YET to give me an incorrect bearing and distance (within expected error) on a really nasty set of cells. Google "storm detection" and "73 magazine". Wayne Green's bunch of bandits came up with some pretty simple and accurate ways of detecting lightning that the average ham could build and use with an XY oscilloscope display. Jim -- "If you think you can, or think you can't, you're right." --Henry Ford wrote in message ps.com... Group- I'm curious how Strikefinder technology works. Yes, I know some of the basics, but what's curious to me is the ability of this device to estimate range and direction to/from a lightning strike. What I know thus far is the following: 1. Lightning is nature's version of an impulse function (time domain), and thus it has wide bandwidth (frequency domain). 2. Strikefinder technology originated, I think, because it was observed that lightning strikes showed up as noise in ADF units. 3. Strikefinder technology operates, I think, as a specialized AM receiver that attempts to interpret energy bursts as lightning strikes. O.K., now I'm getting on the fringe of my knowledge. Yes, I'm an electrical engineer, so don't be afraid to dive deep into details. I just hadn't considered theory of lightning detection before and curiosity is getting to me. I'm wondering: 1. How does Strikefinder technology estimate range and direction to a lightning strike (my original question)? 2. If Strikefinder technology operates in the AM band, why? (Lightning contains many other frequency components from which to choose.) 3. How are range and direction to/from lightning strikes determined? (I know that up to around 1/2 wavelength, E and H fields are not in phase. Does the Strikefinder use "Near Field" characteristics to estimate range?) Thank you in advance for your input. -David- Hide quoted text - - Show quoted text - |
Could you elaborate on what kind of transform it is doing and how it could
determine distance by dispersion? Not contradicting you, just don't understand. Jim -- "If you think you can, or think you can't, you're right." --Henry Ford " wrote in message ups.com... The Strikefinder does not make the assumption that all strikes are equal. It does a transform on the incoming signals and determines distance by a top-secret dispersion technique. |
RST Engineering wrote:
Snip As to range, there are several methods, some of which depend on the reflection of that hewmongous pulse of electromagnetic energy from the surface of the earth bouncing from earth to ionosphere and back again, creating a double pulse train from each stroke. Again, using digital signal processing from multiple echoes you can create a "pseudorange" fairly accurately. Nearly as accurate, and nowhere as complicated is to "assume" a value for radiated power from the average lightning stroke and simply do a range predicated on the peak detected strength of the received lightning pulse. Some will be stronger and some will be weaker, which is why all of them don't fall directly on top of one another but form a circular pattern perhaps twenty miles in diameter on the display. Again, microprocessors can massage the data to toss out the responses at the one-sigma point and only give those responses that fall in the expected range. Now as to the practicality. I've flown a Strikefinder for almost a thousand hours. It has YET to give me a false indication and it has YET to give me an incorrect bearing and distance (within expected error) on a really nasty set of cells. I can't find a reference now, but I thought one of the other refinements made by Strikefinder was to use dispersion as a means for distance measurement. Matt |
"RST Engineering" wrote in message ... Could you elaborate on what kind of transform it is doing and how it could determine distance by dispersion? Not contradicting you, just don't understand. Jim Did you happen to read the links about strikefinders when there was a thread about how strikefinders work, a month or so back? There were some great explanations, that were provided. What you asked, and more, was explained. -- Jim in NC |
No, I must have missed it. Was it in this newsgroup? If so, it went right
by me and that would be strange, since I did a fair amount of work writing about strikefinder, stormscope, and other detection stuff for my column. I also have a library of the articles written in 73 about lightning detection. Jim -- "If you think you can, or think you can't, you're right." --Henry Ford "Morgans" wrote in message ... Did you happen to read the links about strikefinders when there was a thread about how strikefinders work, a month or so back? There were some great explanations, that were provided. What you asked, and more, was explained. -- Jim in NC |
"RST Engineering" wrote in message ... No, I must have missed it. Was it in this newsgroup? If so, it went right by me and that would be strange, since I did a fair amount of work writing about strikefinder, stormscope, and other detection stuff for my column. I also have a library of the articles written in 73 about lightning detection. Might have been the R.A.Piloting group. As much as I hate finding threads, I'll see what I can do. One article stands out in my mind, in particular. It told of the different frequencies of the strikes it looks for, and how cloud to ground and cloud to cloud strikes have a different signature, and how some strikefinders do or do not look for them. On second thought, it might have been more about how ground based systems look for them, to be sent on to other assets for aviation. -- Jim in NC |
| Thread Tools | |
| Display Modes | |
| StrikeFinder Problem | Jonathan Goodish | Owning | 4 | July 17th 07 09:52 PM |
| Upgrading your Strikefinder? | Peter MacPherson | Owning | 2 | September 1st 04 03:32 PM |
| Upgrading your Strikefinder? | Peter MacPherson | Instrument Flight Rules | 0 | August 31st 04 04:45 PM |
| Upgrading your Strikefinder? | Peter MacPherson | Piloting | 0 | August 31st 04 04:45 PM |
| A different strikefinder question | L Smith | Piloting | 3 | July 15th 04 07:18 PM |
