Hello everyone. I just upgraded my PowerFlarm firmware from 6.42 to version 6.60 this past weekend. After flying I uploaded my .igc file to the PowerFlarm Range Tool to see if anything had changed for the better or worse. Interestingly, the 6.60 generated log file shows zero FLARM data points of any kind in the tool. I can look at the .igc in a text editor and see numerous LFLA records in the file. I know the FLARM was working because I was seeing traffic alerts all day long on my FLARM displays. For grins, I ran a log file generated under FW 6.42 and the Range tool showed many data points. Looking through the log files I see that the 6.42 log file has several encrypted LFLA entries (like LFLA20042502nJMrwj?wwwqyZgn]m#j]HSOIPya) that don't exist in the 6.60 generated log file.
Any ideas? Robert |
On Monday, August 27, 2018 at 4:58:11 PM UTC-4, wrote:
Hello everyone. I just upgraded my PowerFlarm firmware from 6.42 to version 6.60 this past weekend. After flying I uploaded my .igc file to the PowerFlarm Range Tool to see if anything had changed for the better or worse. Interestingly, the 6.60 generated log file shows zero FLARM data points of any kind in the tool. I can look at the .igc in a text editor and see numerous LFLA records in the file. I know the FLARM was working because I was seeing traffic alerts all day long on my FLARM displays. For grins, I ran a log file generated under FW 6.42 and the Range tool showed many data points. Looking through the log files I see that the 6.42 log file has several encrypted LFLA entries (like LFLA20042502nJMrwj?wwwqyZgn]m#j]HSOIPya) that don't exist in the 6.60 generated log file. Any ideas? Robert I just ran two files generated after I updated to 6.60; both worked with pretty well identical results to 6.42 using the FLARM Range Analyzer Tool. You might try a factory reset, then install new firmware and flarmcfg.txt. You will lose stored igc files. # Complete factory reset. Use in a one-line flarmcfg.txt file $PFLAR,99 Dan |
| PowerFlarm range tool | Mark628CA | Soaring | 2 | November 17th 15 06:24 AM |
| PowerFlarm: 2.7 Vertical Range | [email protected] | Soaring | 8 | April 10th 13 12:27 AM |
| PowerFlarm Range Analysis | Richard[_9_] | Soaring | 0 | March 25th 13 05:43 PM |
| PowerFlarm BRICK range issues - are we alone???? | Mark | Soaring | 79 | October 17th 12 01:17 PM |
| PowerFLarm expected range | [email protected] | Soaring | 6 | August 30th 12 04:43 PM |
