I have run several flights through the PowerFlarm range tool, and my coverage seems adequate, but I am wondering if anyone has a method of determining 3D coverage? The tool shows a decent depiction of horizontal coverage, but I wouldn't mind having an idea of the coverage above and (especially) below.
Also, in a previous thread, one poster (mark...@lennoxengineering) mentioned he had developed a tool to splice together several flights. Is this available for others' use? |
On Mon, 16 Nov 2015 08:15:56 -0800 (PST), Mark628CA
wrote: I have run several flights through the PowerFlarm range tool, and my coverage seems adequate, but I am wondering if anyone has a method of determining 3D coverage? The tool shows a decent depiction of horizontal coverage, but I wouldn't mind having an idea of the coverage above and (especially) below. Also, in a previous thread, one poster (mark...@lennoxengineering) mentioned he had developed a tool to splice together several flights. Is this available for others' use? If you are comfortable with old DOS commands, you can use the following to concatenate multiple IGC files and submit the result to the Range Analyzer. - Put the IGC files of interest in a temp directory - Open a 'cmd' shell in the directory of your IGC files. - Enter the command: type *.igc all.igc - Upload all.igc to the range analyzer There is an upper limit to the size of the file the Range Analyzer can handle, so the number of files concatenated is not unlimited. Bob |
Old discussion:
https://groups.google.com/forum/#!searchin/rec.aviation.soaring/wx$20flarm/rec.aviation.soaring/xPaHe0jK5Tk/g-WNEik8iBsJ Google "concatenate" for commands in different operating systems |
| Thread Tools | |
| Display Modes | |
| PowerFlarm Butterfly Display not changing range | [email protected] | Soaring | 2 | May 1st 14 05:54 PM |
| PowerFlarm: 2.7 Vertical Range | [email protected] | Soaring | 8 | April 10th 13 12:27 AM |
| PowerFlarm Range Analysis | Richard[_9_] | Soaring | 0 | March 25th 13 05:43 PM |
| PowerFlarm BRICK range issues - are we alone???? | Mark | Soaring | 79 | October 17th 12 01:17 PM |
| PowerFLarm expected range | [email protected] | Soaring | 6 | August 30th 12 04:43 PM |
