Electric Brakes On Komet Trailer
Old February 16th 19, 12:21 PM posted to rec.aviation.soaring
Bob Youngblood
Default Electric Brakes On Komet Trailer
I am trying to get away from the surge brakes and has anyone converted their trailer to electric brakes?? Thanks
Old February 16th 19, 02:32 PM posted to rec.aviation.soaring
But why change a simple and entirely appropriate device against something complex and in need of fine-tuning (laden vs. empty trailer)? Fix or adjust your surge brakes (Spindelberger website has details) and you'll be fine. Nobody in Europe has electric brakes on glider trailers.
Old February 16th 19, 04:13 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Bob
I converted my cobra to Dexter Axle Torflex with electric brakes. I measured the axle bolt holes spacing, tire bolt scheme and distance from wheel to wheel. Purchased online from a trailer company they welded the brackets to fit. The easiest way is to take to a trailer dealer that carries Dexter Axles and have them replace the axle.
It was about 15 years ago as I remember $450 included shipping from Florida to CA. Call if you have questions.
Richard
www.craggyaero.com
Old February 16th 19, 04:50 PM posted to rec.aviation.soaring
Clay[_5_]
What is your tow vehicle? You will need to wire in a trailer brake controller, easier to do on some vehicles than others.
Old February 16th 19, 05:24 PM posted to rec.aviation.soaring
BobW
Howziss for covering all the bases?
"What Herb K., Richard P., and Clay said!" *and* consider - if your rig is
"nice-n-light" and your "geographical situation/traffic warrants"... simply
going the (easy-peasy) Torflex route while leaving the rig brakeless. (Gasp!)
Been there/done that on a 15-meter glass ship/trailer combo that - for decades
- I towed w. a 2,600 lb, unboosted/drum-braked, vehicle, throughout the high
plains and intermountain west...with nary a (negatively) exciting moment
behind the wheel of that particular combo. That was after some years of towing
the same rig w. an early version of "a Torflex-like" welded-spring, brakeless,
axle whose spring-attach-welds broke on both sides of the axle.
I've also installed an electric brake controller on wifey's Tacoma (easy
enough)...but heard "some Fords" are bears in that particular department.
YMMV!
Bob W.
This email has been checked for viruses by AVG.
https://www.avg.com
Old February 16th 19, 06:29 PM posted to rec.aviation.soaring
Karl Kunz[_2_]
The problem with keeping the Komet system is the availability of parts in the U.S. My brake system has been inop since I've owned the trailer and as BobW have found no issues even with heavy braking. I have thought of converting to the more modern axle-less system and electric brakes.
Old February 16th 19, 07:01 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
BobW wrote on 2/16/2019 9:24 AM:
"nice-n-light" and your "geographical situation/traffic warrants"... simply going
Been there/done that on a 15-meter glass ship/trailer combo that - for decades - I
towed w. a 2,600 lb, unboosted/drum-braked, vehicle, throughout the high plains
and intermountain west...with nary a (negatively) exciting moment behind the wheel
of that particular combo. That was after some years of towing the same rig w. an
early version of "a Torflex-like" welded-spring, brakeless, axle whose
What do you use for a parking brake, if the trailer is brakeless?
Old February 16th 19, 07:05 PM posted to rec.aviation.soaring
AS
Chocks....
Uli
'AS'
Old February 16th 19, 08:12 PM posted to rec.aviation.soaring
BobW
is "nice-n-light" and your "geographical situation/traffic warrants"...
simply going the (easy-peasy) Torflex route while leaving the rig
brakeless. (Gasp!)
decades - I towed w. a 2,600 lb, unboosted/drum-braked, vehicle,
throughout the high plains and intermountain west...with nary a
(negatively) exciting moment behind the wheel of that particular combo.
That was after some years of towing the same rig w. an early version of
(easy enough)...but heard "some Fords" are bears in that particular
department.
Chocks....
Uli 'AS'
"What Uli said." Also - after my tow vehicle eventually became relegated to
strictly a towing vehicle (purchased a 2nd/econobox commuting vehicle) - I
often simply left it on the tow hitch. Of course, living on flat land and
parking almost exclusively on the same (e.g. airports), even chocks were
(arguably, and "for most practical purposes") unnecessary.
Even at the Boulder (CO) A/P, ~3 miles from the Front Range, as in where
thanks to downsloping winds, it often "blows like stink", and trailer parking
is nose-into-the-winds, those times I left the trailer at the field, if the
parking spot had (say) an axle pounded into the ground, I'd chain the tongue,
but not every slot did, and when in those slots I simply chocked it.
In "real" tornado country, I generally kept it on the vehicle and "kept an eye
on the weather," when no tongue tiedown was handy. In any event the trailer
(still) has no aft-end tie rings.
YMMV.
Bob W.
https://www.avg.com
Old February 16th 19, 08:34 PM posted to rec.aviation.soaring
JS[_5_]
What's so wrong that it must go away?
Chocks are fun when you need to maneuver the trailer on a not-so-level surface. Done that.
Recently saw weather move chocked trailers around in the tiedowns. Several were damaged. One punched a hole in the hangar that stopped it.
Electric brakes with the parking brake option may be fine when the whole package is in tune and present, but useless if towed behind a car without the right controller.
Believe Dexter now has hydraulic brake axles with a parking brake option. Perhaps not as easy to set up as the mechanical ones, but far less vehicle-dependent than electric.
Do AlKo axles for Spindelberger Cobra trailers fit Anschau Komet trailers? Believe Wings and Wheels has some of those in stock.
Otherwise, perhaps it just needs new brake shoes, drums resurfacing or replacing, and set up properly. While you're at it replace the bearings.
Komet Trailer [email protected] Soaring 7 August 7th 17 05:34 AM
Trailer tires for old (1981) Komet Trailer [email protected] Soaring 3 May 13th 09 10:24 PM
Old Komet Trailer thermalrider Soaring 7 October 11th 08 04:13 PM
Electric Trailer Brakes, (Revisited) sisu1a Soaring 14 June 9th 08 07:32 PM
Trailer brakes Bert Willing Soaring 1 October 31st 03 07:55 AM
