What's Wrong With OLC?
Old May 18th 19, 12:22 PM posted to rec.aviation.soaring
Tango Eight
Default What's Wrong With OLC?
Current hypothesis is that OLC isn't interpreting the 2459 = 0000z daily roll over correctly, but evidently only for CNi products.
The best place for further discussion would be the CNi forum. Thanks
Evan Ludeman
Old May 18th 19, 02:53 PM posted to rec.aviation.soaring
Dan Marotta
But that's 1800 - 1801 local.Â* That doesn't make sense unless I'm
figuring Zulu time backwards.Â* I haven't been airborne that late in
quite a while.
See you on the CNi forum.
Evan Ludeman
Dan, 5J
Old May 18th 19, 02:56 PM posted to rec.aviation.soaring
2359 - 0000z rollover.
Evan Ludeman
Old May 18th 19, 03:11 PM posted to rec.aviation.soaring
Bruce
1800 mountain time is 2400 Zulu or UTC
quite a while.
Evan Ludeman
Dan, 5J
Old May 18th 19, 03:20 PM posted to rec.aviation.soaring
Tango Eight
Good thing I'm not the guy that writes the code ;-)
T8
Evan Ludeman
Old May 18th 19, 03:40 PM posted to rec.aviation.soaring
kinsell
Dan's flight ended 2304 per the log, so doesn't sound like any kind of
rollover problem.
Evan Ludeman
Old May 18th 19, 04:25 PM posted to rec.aviation.soaring
kinsell
Looking at your April 25 flight on SeeYou, the GPS altitude graph shows
tons of dropouts (down to 0 altitude).
This is absolutely not corruption on a USB stick, the file would show as
invalid with the CRC check if it were. It's the logger showing bad
altitude numbers, and at least one out of order time stamp.
If these problems correspond to the jamming, then not much you can do.
But I wouldn't rule out interference from inside the cockpit, maybe even
the two CN antennas mounted next to each other and interfering with each
other. Stranger things have happened.
-Dave
On 5/17/19 11:40 AM, Dan Marotta wrote:
LOL...Â* I predate Windows; PCs and Apples, in fact.
I have separate sticks for each device.Â* It's hard to imagine that both
would fail in the same manner.
As soon as I get a chance to fly again, I'll try three different
sticks.Â* Winds are currently around 20G30 kts.Â* I don't mind landing in
that, but I see no need to take off until things settle down. Ah...
Spring time in Moriarty...
On 5/17/2019 10:47 AM, Charlie M. (UH & 002 owner/pilot) wrote:
Could be a bad stick......
I am from the age of, "Whoa.....a 30mb USB stick.....you know how many
3.5" floppies this replaces!!!!"
First field job.....user PC was Windows NT.....no Frikkin USB
support.........sigh........
Today, big USB sticks are like cheap butane lighters......the stick is
cheap (make sure to format in correct OS/software) so when not sure,
recycle and buy new......
Old May 18th 19, 04:37 PM posted to rec.aviation.soaring
Dan Marotta
I've just replaced the two CN antennae with new, 28 dB gain antennae
with uncut coax leads.Â* They're mounted on opposite canopy rails, at
least 3 ft apart.Â* It's gusting 25 kts at Moriarty right now and
forecast up to 40.Â* I probably won't be flying today.
shows tons of dropouts (down to 0 altitude).
as invalid with the CRC check if it were.Â* It's the logger showing bad
even the two CN antennas mounted next to each other and interfering
with each other.Â* Stranger things have happened.
-Dave
both would fail in the same manner.
in that, but I see no need to take off until things settle down.
Ah... Spring time in Moriarty...
many 3.5" floppies this replaces!!!!"
is cheap (make sure to format in correct OS/software) so when not
sure, recycle and buy new......
Dan, 5J
Pearl Harbor in Art - 14 - wrong place wrong time.jpg (1/1) Mitchell Holman[_9_] Aviation Photos 0 December 7th 17 01:23 PM
What Is Wrong With OLC? Dan Marotta Soaring 49 February 2nd 17 02:54 AM
What Is Wrong With OLC? Dan Marotta Soaring 5 June 15th 16 03:05 AM
what went wrong Dick[_1_] Home Built 14 August 10th 07 03:48 AM
what am I doing wrong gt[_2_] Aviation Photos 8 June 4th 07 01:49 AM
