what went wrong
Old August 7th 07, 11:07 PM posted to rec.aviation.homebuilt
Dick[_1_]
Default what went wrong
Having spent 4-1/2 hours removing and 1 hour replacing a leaking split seal
on the front of my flanged crankshaft C-85 , my first flight today still
shows leakage....
Never really doing those old Chevy two part split seals well, I guess I'm
still inept G.
I think I'll be able to better the aforementioned time durations but would
appreciate any hints at doing a better job this time.
Thanks, Dick
Old August 7th 07, 11:38 PM posted to rec.aviation.homebuilt
Capt. Geoffrey Thorpe
"Dick" wrote in message
news:c26ui.7629$dD3.905@trnddc07...
seal on the front of my flanged crankshaft C-85 , my first flight today
still shows leakage....
still inept G.
Thanks, Dick
OK, I aint no A&P...
but, what kind of shape is the crankshaft surface in?
Is the crankcase vent flowing without obstruction?
What did you use to re-install the new seal?
Geoff
Old August 8th 07, 12:56 AM posted to rec.aviation.homebuilt
Dick[_1_]
no visible scratches or marks on crank; vent is flowing; slightly oiled
perimeter and pushed into engine case with wood handle of screwdriver...seal
split is at about 1pm position.
placing spring ends together and getting up into the seal insides was
difficult.. Can I assume once up there the spring stays??? Anybody know ??
"Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message
news:OvWdnS8oJJ_7aSXbnZ2dnUVZ_rmjnZ2d@wideopenwest .com...
still inept G.
would appreciate any hints at doing a better job this time.
Thanks, Dick
Geoff
Old August 8th 07, 03:47 PM posted to rec.aviation.homebuilt
Should have used rubber cement (3M's 847) on the outer
perimeter and in the engine case bore. The spring might have popped
off if you didn't keep the split ends lined up as you pushed the seal
in.
Dan
Old August 8th 07, 08:28 PM posted to rec.aviation.homebuilt
Dick[_1_]
how would I get this new unglued seal out for another try? I destroyed the
old one getting it out. New one had the tightest split I had ever
experienced but finally was able to push enough to get the entire seal into
the bore.
do you think I should go ahead and order another seal?
screwdriver...seal
in.
Dan
Old August 8th 07, 09:13 PM posted to rec.aviation.homebuilt
the bore.
I wonder if a little air pressure up the breather might help
that seal come out again? And then check the bore to see that there
isn't some dried adhesive in there that may be interfering with the
sealing of the seal against the case.
But just a little pressu you don't want to start blowing
gaskets or tachometer drive seals.
Dan
Old August 9th 07, 09:05 AM posted to rec.aviation.homebuilt
Cy Galley
Continental which used the same type seal as the Lycoming and Franklin
recommends the split be at 11 or 1 o'clock.(case spilt is at 12. My
recommendation is to use "super glue" on the ends. Make sure the recess is
clean and dry. Use a sealer on the outside. I like Loctite 515 and remember
to replace the garter spring and grease the lip. Look at Continental M76-4
for the complete Continental instructions.
Cy Galley - Chair,
AirVenture Emergency Aircraft Repair
A 46 Year Service Project of Chapter 75
EAA Safety Programs Editor - TC
EAA Sport Pilot
still inept G.
Thanks, Dick
Old August 9th 07, 11:38 AM posted to rec.aviation.homebuilt
Dick[_1_]
thanks for M76-4 copy and everyone's advice. am going to order another seal
and do better.
"Cy Galley" wrote in message
news:FVzui.55189$Fc.32497@attbi_s21...
is clean and dry. Use a sealer on the outside. I like Loctite 515 and
remember to replace the garter spring and grease the lip. Look at
Continental M76-4 for the complete Continental instructions.
Cy Galley - Chair,
EAA Sport Pilot
still inept G.
Thanks, Dick
Old August 9th 07, 03:08 PM posted to rec.aviation.homebuilt
Dave[_16_]
and do better.
Cy Galley - Chair,
EAA Sport Pilot
still inept G.
Thanks, Dick
Does Continental have a solid seal for the engine? The type you force
over the prop flange?
I've used those before and have seemed to do a good job.
Just a thought.
Dave
Old August 9th 07, 03:22 PM posted to rec.aviation.homebuilt
On Aug 9, 8:08 am, Dave wrote:
and do better.
Cy Galley - Chair,
EAA Sport Pilot
still inept G.
Thanks, Dick
Just a thought.
Never seen one, at least for the small engines. That's Lycoming's
method.
Dan
what am I doing wrong gt[_2_] Aviation Photos 8 June 4th 07 01:49 AM
Wrong Vario!!! Mike Hostage Soaring 0 March 30th 05 01:39 AM
What's wrong with this engine? Fred the Red Shirt Home Built 6 May 3rd 04 04:49 AM
ATC says wrong position Greg Esres Instrument Flight Rules 28 April 30th 04 05:37 PM
Saying the wrong thing...! Paul Sengupta Piloting 3 January 23rd 04 03:58 AM
