Altimeter
Old May 22nd 19, 07:23 PM posted to rec.aviation.soaring
Andrew James[_2_]
Default Altimeter
Wanted 57mm Altimeter
Old May 29th 19, 06:16 PM posted to rec.aviation.soaring
John DeRosa OHM Ω http://aviation.derosaweb.net
Default Altimeter
As always checking http://glidersource.com when you are looking for used glider instruments/avionics is the first/best place to look. There is a 57mm altimeter for sale there right now.
Old May 29th 19, 09:39 PM posted to rec.aviation.soaring
Default Altimeter
Why not just post to sorta new/current thread for parts wanted?
Likely most peeps won't search here, so your your new thread sinks into the mud....
Old May 30th 19, 12:07 AM posted to rec.aviation.soaring
Default Altimeter Wanted (57mm)
On Wednesday, May 29, 2019 at 12:16:54 PM UTC-5, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
I should have also added that you can post a "wanted" add at http://glidersource.com.
tso altimeter Phoenixmotoman Soaring 24 December 8th 10 12:55 PM
WTB: used 57mm Altimeter OR swap for 80mm Altimeter joesimmers Soaring 0 November 3rd 09 11:59 AM
Looking for TSO Altimeter Rob Turk Home Built 0 June 9th 07 03:52 PM
Altimeter off kevmor Instrument Flight Rules 11 March 26th 07 12:11 PM
low altimeter and FL180 Michael 182 Piloting 26 October 31st 03 04:29 AM
