Altimeter off
Old March 20th 07, 08:53 PM posted to rec.aviation.ifr
kevmor
Default Altimeter off
How can you adjust an altimeter if the pressure isn't correct in the
window for the altitude? I started talking to my examiner about it on
the checkride and he said that a lot of people adjust it themselves
(not an avionics shop, etc), and he said you take the front off (I
think) and theres a screw to adjust it? The plane would be used for
VFR only...
Is there an adjustment that can be made to the encoder as well if it's
off?
Old March 20th 07, 10:16 PM posted to rec.aviation.ifr
Jim Macklin
Not legal, you'll screw it up. Even an A&P is not allowed
to "adjust" instruments internally. You should take it to a
certified repair shop if it won't pass a IFR check. The
encoder is factory set at 1013.2 mb/29.92 and there are no
field serviceable adjustments.
If the static systems is wrong, the altimeter system and
airspeed will also likely be wrong.
"kevmor" wrote in message
correct in the
about it on
themselves
front off (I
be used for
| VFR only...
well if it's
| off?
Old March 22nd 07, 08:13 PM posted to rec.aviation.ifr
kevmor
There's no adjustments on the encoder? I can set the altimeter on the
ground to the airport elevation, so I know it should be really close
to the correct altitude, but then ATC may see my altitude as being a
hundred feet off... The encoder never needs to be recalibrated? It
just sees what is at the static input?
On Mar 20, 2:16 pm, "Jim Macklin"
correct in the
about it on
themselves
front off (I
be used for
| VFR only...
well if it's
| off?
Old March 22nd 07, 08:43 PM posted to rec.aviation.ifr
Bill
correct in the
about it on
themselves
front off (I
be used for
| VFR only...
well if it's
| off?
|- Hide quoted text -
- Show quoted text -
The encoder sends data as if it was always set to 2992. The ground
adjusts it for local altimeter setting.
Bill Hale
Old March 22nd 07, 08:56 PM posted to rec.aviation.ifr
John R. Copeland
That is correct - there's no adjustment on the encoder.
Your encoder reports density altitude to ATC.
ATC computes an altitude correction factor for their own displays.
Some cockpit instrumentation computes the identical correction,
allowing the pilot to know what altitude ATC is displaying.
"kevmor" wrote in message oups.com...
correct in the
about it on
themselves
front off (I
be used for
| VFR only...
well if it's
| off?
Old March 22nd 07, 09:20 PM posted to rec.aviation.ifr
Peter Clark
There's no user-adjustable settings on the encoder, but there are
adjustments on the encoder (assuming an encoder, not an encoding
altimeter) which can be made, assuming the unit itself is not just
busted, by an avionics shop and a transponder test set which will
bring it back into spec.
On Thu, 22 Mar 2007 15:56:42 -0400, "John R. Copeland"
correct in the
about it on
themselves
front off (I
be used for
| VFR only...
well if it's
| off?
Dave Butler
Make that "pressure altitude".
Old March 22nd 07, 09:31 PM posted to rec.aviation.ifr
John R. Copeland
"Dave Butler" wrote in message ...
Oops! I really *do* know that.
I just screwed up. Thanks, Dave.
Old March 22nd 07, 09:36 PM posted to rec.aviation.ifr
kevmor
Thanks all for your advice, I also had a problem once or twice with
this transponder on the last digit not showing correctly on their
side. ATC asked to confirm my squawk a couple times, and then I
suppose he got a supervisor who said "the last digit of your
transponder...what does it read?" He told me to rotate the knob around
a few times, which fixed it. The airplane was set on 1200 and never
changed for a decade, maybe it just needed to be cycled some
Old March 22nd 07, 10:52 PM posted to rec.aviation.ifr
Jim Macklin
"John R. Copeland" wrote in
message ...
Your encoder reports density altitude [PRESSURE ALTITUDE]
to ATC.
displays.
correction,
altimeter on the
really close
as being a
recalibrated? It
allowed
to a
no
correct in the
examiner
about it on
it
themselves
front off (I
would
be used for
| VFR only...
as
well if it's
| off?
Altimeter 3066 M Piloting 24 December 4th 06 07:46 PM
ATC Altimeter Settings O. Sami Saydjari Instrument Flight Rules 81 April 11th 05 09:07 PM
Altimeter Disassembly Dick Home Built 3 April 2nd 05 02:27 PM
encoding altimeter mcfrog Owning 3 May 30th 04 08:39 PM
low altimeter and FL180 Michael 182 Piloting 26 October 31st 03 05:29 AM
